To bleed or not to Bleed!? The clutch that is. - Ducati.ms - The Ultimate Ducati Forum
post #1 of 9 (permalink) Old Aug 31st, 2012, 11:24 am Thread Starter
IKARUS404's Avatar
Deciding whether or not to bleed the clutch as it is working fine and finally got used to the engagement/disengagement, but the fluid looks like this...
To bleed or not to Bleed!? The clutch that is.-imageuploadedbymo-free1346430107.810562.jpg
Heard of people bleeding the clutch and not having the same feel as they did before. Will I be fine leaving it the way it is, or bleed the system to rid it of the chocolate milk?
Sent from my iPhone using MO Free
08' 1100 Hypermotard, Motovation frame & front axle sliders, Termignoni slip-ons, DP racing ECU, DP airbox lid, K & S mirrors, DP gel seat, Crown Moto Carbon Fiber front fender, shrouds, clutch cover, EVR red pressure plate.
IKARUS404 is offline
post #2 of 9 (permalink) Old Aug 31st, 2012, 11:29 am Thread Starter
IKARUS404's Avatar
Compared to the front brake reservoir...
To bleed or not to Bleed!? The clutch that is.-imageuploadedbymo-free1346430530.391592.jpg
post #3 of 9 (permalink) Old Aug 31st, 2012, 12:07 pm
Super Moderator
Chuckracer's Avatar
Images: 2
It ain't broke...yet.
2011 KTM 990 SMT
2012 KTM 350 XCF-W
Chuckracer is offline
post #4 of 9 (permalink) Old Aug 31st, 2012, 1:10 pm
Mine looked like that. I bled it and it work the same afterward although the fluid was nice and clear. A couple hundred miles later it looked like that again.
2014 Multistrada S Pikes Peak, 2017 KTM 1090 Adventure R, 2009 KTM 250XCWe
GRR_Hyper is offline
post #5 of 9 (permalink) Old Aug 31st, 2012, 1:11 pm
vroooom's Avatar
bleed. if you introduce air into it then it would feel different.... but if it's correct to begin with and you bleed it properly then it shouldn't change the way the clutch (dis)engages.
2010 Hypermotard 796 with Termi 22 slip-ons + LV Decat + reflashed ECU + KN filter + 14T sprocket + Shorai LFX18A1 + Woodcraft Rearsets
vroooom is offline
post #6 of 9 (permalink) Old Aug 31st, 2012, 5:01 pm
I've been wondering the same thing. Bike has 2300 miles on it, clutch fluid is pretty much black.
I'm going to have the shop bleed it when it's in for new fork springs.
mike the snake is offline
post #7 of 9 (permalink) Old Aug 31st, 2012, 6:08 pm
trailerpark's Avatar
I like clear fluids. Here's a good how-to video.
2010 Hypermotard 1100 evo
Termi 2-2
LV decat
14 tooth front sprocket
trailerpark is offline
post #8 of 9 (permalink) Old Aug 31st, 2012, 7:07 pm
Termi 2-2
LV decat
post #9 of 9 (permalink) Old Aug 31st, 2012, 8:35 pm Thread Starter
IKARUS404's Avatar
Thanks all for the feedback. Will bleed sometime this week using the reverse bleed method.
Clutch bleed question/help Motozen Multistrada 8 May 16th, 2011 5:17 pm
MC Leak After Clutch Bleed??? arai_speed Monster 0 May 29th, 2009 1:01 am
Clutch bleed problems gmarshman Ducati Motorcycle Chat 4 Dec 22nd, 2007 10:16 pm
clutch bleed help scott748mono Superbikes 5 Jun 22nd, 2007 8:11 pm
Do i need to bleed my clutch? ericeash Superbikes 3 Apr 15th, 2007 8:15 am
