.003 Closer shims - Ducati.ms - The Ultimate Ducati Forum
post #1 of 3 (permalink) Old May 10th, 2012, 4:32 pm Thread Starter
.003 Closer shims
7500 miles and I just got my valve clearances measured. 3 openers are in spec, 1 is .005 and will get replaced. My problem is that all three of my closer shims I measured, and remeasured, are at .003. Here is my question:
I've heard that new half rings will add +.001 to the clearance. Should I try and replace just half rings and ride with .002, replace all 4 shims and NOT the half rings (anticipating the new ones will "break in" and increase the clearance again), or replace all 4 shims and half rings.
I don't constantly hit the rev limiter and ride this bike around town for 75% of the mileage. Perfect tolerance is less of a concern here but I want to do things right, not looking to save a dollar. I just think the half rings are suspect when my openers are generally in tolerance and my closers are generally out of tolerance by the exact same amount...
Any knowledge/experience is helpful
LukeandMiller is offline
post #2 of 3 (permalink) Old May 10th, 2012, 8:50 pm
Hazzbin's Avatar
Get it exactly right, and to the old specs, not the new ones. Also, when I did mine, I did not experience the new half rings changing things a full .001.
Hazzbin is offline
post #3 of 3 (permalink) Old May 14th, 2012, 2:06 pm
Ric
Ric's Avatar
Slightly off topic.I find the springs on my 1100 a LOT harder to compress when working on the closers.Is anyone using a tool of some kind to compress the rocker? And i don't mean the silly thing that looks like a nut driver.I use that to do the shims on my 944.It's easy to change them.
2001 Goldwing 1800
2009 Hyper 1100S
Ric is offline
Measuring Closer Shims ducatimike Hall of Wisdom 0 Apr 26th, 2011 10:59 am
Removing closer shims - ST3 kaysystems Sport Touring 15 Feb 17th, 2011 5:06 pm
Closer shims stuck debby Superbikes 8 Dec 28th, 2009 10:08 pm
Snading closer shims Ric Ducati Motorcycle Chat 8 Mar 20th, 2009 4:17 am
