Wheel Removal & Installation - Page 2 - Ducati.ms - The Ultimate Ducati Forum
post #11 of 15 (permalink) Old Oct 14th, 2010, 11:29 pm
Images: 13
Any recommendations from qualified blokes about what grease should be used on the rear axle? Front? What about on the nuts? Caliper mounting bolts? Caliper pins?
I've got some of this for the caliper pins. Do I use itonthe mounting bolts too?http://www.permatex.com/products/Aut...ne_Formula.htm
Can't seem to find shell retinax hdx2. Any similar recommendations?
Thanks
'03 Monster 620 Dark: Bought it, rode the piss out of it, sold it, binned it. (Yes, in that order.) RIP
'01 748 Red: Bought it, met a girl and left San Francisco for Syracuse, now longing for Bay Area roads...
crozzer is offline
post #12 of 15 (permalink) Old Oct 15th, 2010, 1:10 pm Thread Starter
Old Wizard
Shazaam's Avatar
Any name-brand moly-based general purpose automotive grease will work. The idea here is that, unless otherwise specified by the manufacturer, the components should be assembled and torqued dry.
When the manufacturer specifies a torque value that requires that a lubricating grease be used, like on the rear wheel nut, the specified torque value is 10% lower than what would be if it was assembled dry.
So don't grease any fastener unless required and don't torque any greased fasteners to dry values.
Shazaam is offline
post #13 of 15 (permalink) Old May 21st, 2013, 2:55 pm
Super Duper Member
CptFunnypants's Avatar
Hi Shazaam. Great post! Just a quick question...
LT Snyder's manual is basically the same, but it says when putting the axle in to slide it "almost all the way in". I've got mine in with the ears of the tool into the slots of the forks and the axle, so it's all lined up. But, as far as I can tell, it's all the way in. What would be the purpose of not putting it in all the way?
Taken out of context, this post sounds wierd/creepy. Anyhow, you know what I mean.
concordeagle likes this.
Kansas City, KS
1998 Ducati 748 Mono Black Edition
Quote of the day - "FUCK IT!"- My drunk redneck neighbor
CptFunnypants is offline
post #14 of 15 (permalink) Old Nov 5th, 2017, 5:16 pm
Iwannaduc's Avatar
Thank You!!!
Thank the internetz, the web gods...whom ever you pray to if you're religious for Shazaam, the hall of wisdom and this forum.
I recently removed my forks and took them to a specialist for rebuild. I noted when I removed the front wheel that the axle was pretty difficult to remove. I got my forks back yesterday and after installing them in the triple clamps and torquing all the bolts I got back to the wheel and axle.
I had a very difficult time sliding the axle even part way in to the fork tube lower, much less the wheel bearing. I deduced that the axle had been struck by something during a previous disassembly or reassembly.
After thoroughly examining the axle, I could see where the shape of the hole in the fork tube lower had been impressed into the metal. Hmmmm.....pinch bolts must have been over tightened at some point also.
After going through the hall of wisdom, I happened upon this post and voila' everything is explained. I read through Shazaam's post about the proper torque and assembly sequence and everything became clear.
I fished out the axle tool from the tool kit and found THAT was what had been used to drive the axle either in, or out or both. It was mushroomed on both ends and would no longer fit into the axle.
I managed to correct the deformed axle with a mill file and a very delicate touch. It will now at least slide in and out of the wheel bearing and the fork tube lower. The tool on the other hand, I did not have nearly the same success with, and will likely have to either find a new one or go back at it further at a later date with a mill file. Or maybe find someone with a lathe.
About the only thing I didn't do was grease the axle up on install. Someone previous to my ownership applied liberal amounts of white lithium grease that had hardened up and gotten sticky. I got so much WD40 on the axle and the wheel bearing bores cleaning that out that I decided to just skip the grease for now.
In the end, I got it all done, and didn't have too much difficulty mostly due to reading this thread first. So, as I stated at the beginning, Thank You. Thank You Shazaam, as always, your sage advice is worth more than the words I can type on this page. If I'm ever down in the San Diego area again, I owe you a beer at the very least..............sean
My garage: Twins:2000.5 Mille R, 2000 996, 1994 EX500 basket case 1993 900SS. Suzukis: 2004 GSXR600, 1992 GSXR750 oil boiler, 1983 XN-85 Turbo
Iwannaduc is offline
post #15 of 15 (permalink) Old Sep 11th, 2018, 7:17 pm
You want to put molybdenum grease on the axle. This makes putting the axle in much easier, and the same with taking it out. Using the axle tool I can get it by just twisting and gentle pressure - no tapping. I'm guessing it also prevents galling. Over time it dries to a powder coating so it won't pick up dirt and grit.
appliance57 is offline
748 rear wheel removal problem Kgizzle1 Superbikes 14 Jul 14th, 2007 9:33 am
rear wheel removal and putting it back on macduc Supersport 9 May 17th, 2007 1:08 am
Front Wheel Removal? jh225 Sport Touring 17 Sep 6th, 2006 2:28 am
Wheel Removal Question... jh225 Sport Touring 3 Sep 2nd, 2006 6:13 pm
ST4s Wheel Removal CapnJack52 Sport Touring 19 Jan 25th, 2006 3:14 pm
