tyre tubes or tubeless ... and why care? - Page 2 - Ducati.ms - The Ultimate Ducati Forum
post #11 of 20 (permalink) Old Oct 18th, 2010, 2:48 pm
SPORT_CLASSIC_SPECIALTIES's Avatar
Careful with these.
I did extensive research and they could never give me a clear answer to the heat tolerance or speed rating of this process.
Plus the goop they use to seal the wheels will add weight and will affect the balance of the wheels greatly.
If one of these wheels do lose a seal it is complete loss of air very quickly.
Someone posted something about this a few years ago and lived to tell about it.
If you ever have to true the rims any movement of the nipples will break the seal. The original intention for the sealing method was created for Harley wheels.
Harley's barley sustain a extended 100 Plus MPH speeds for long periods. The heat and beating a wheel takes at those speeds are not intended for a sealed set of regular spoked wheel in my opinion
After the research and the pro's and cons of this I bought Alpina's
and eventually became their Distributor. I was a customer first.
I am not trying to sell you alpina's I am just a little skeptical with this process as they could never answer my questions about heat and Speed tolerance nor answer any liability issues.
Scary Stuff IMHO
JC
Originally Posted by Youkai View Post
In preparation for attending Reg Pridmore's school on the Streets of Willow at the end of the month, (and because Nicky Hayden didn't draw my ticket at Laguna Seca) I took my wheels and a set of Dunlop Q2s to Ride Wright Wheels in Anaheim, CA last week.
Naturally, the weather has precluded any serious runs on the butt dyno but I can say that the proprietor of Ride Wright, Mr. Sam Wakim is a pleasure to do business with and he sealed my rims for not much more than the price of a pair of tubes.
Anyway, about four pounds of inner tubes are in my garage instead of in my tires and as said before, if you are going to lose weight on your bike, there is no better place than inside the tires.
SPORT_CLASSIC_SPECIALTIES is offline
post #12 of 20 (permalink) Old Oct 18th, 2010, 9:44 pm
Youkai's Avatar
Originally Posted by JCPakBikes View Post
Careful with these.
Scary Stuff IMHO
JC
Wow, how to respond?
Forums seem to be quite often posted upon by illiterate insomniacs who would do the rest of us a favor by sticking to surfing porn. I am not suggesting that you are one of those. But to say that because a company that sells wheels in Garden Grove got an F on their report card means that the product of a company in Anaheim is scary? If you are going to assess a risk, you need more than dark, disturbing doubts. You need to look at not only the severity of consequence, (totally agree, flat tire at speed bad), but at the likelihood of occurrence. Looking at your laundry list of reasons against sealing spoke wheels, it is essentially the same as you posted a year ago (and about two years ago). This suggests a lack of research. You argue using, “they, goop, someone,” and, “in my opinion”. Where are your facts? If you’ve ever watched an eight hundred pound bagger grinding off their floorboards on the PCH, you wouldn’t honestly suggest that Harley wheels can’t have a stressful life. As an example of actual “extensive research”, Dietrichpfeifer has posted very well reasoned descriptions of problems as well as documented what has and hasn’t worked when he has tested solutions. He has not only educated and entertained us, he has so far survived to post 2,250 times with way more fun than profit. GTRossi has also had good results with sealing his rims. OBTW, Silicone glue has a continuous service temperature rating of 400 degrees F. Read that off the tube, I did.
fastfinch likes this.
Ken
06 Sport Classic with gas tank #3, Sealed stock rims by Ride Wright, Fat Duc Mixture Control, Zard slip-ons, Sel-Motion damper, minor air box tweak, Cycle Cat adjustable bars, Whistler Cruisader, 15mm preload in the forks, "comfort seat", and my own fender elimination with Lite'N Boltz for the plate.
Youkai is offline
post #13 of 20 (permalink) Old Oct 18th, 2010, 10:01 pm
I guess it is a difference of opinion
And "if" you sell your bike with these wheels on them, please tell the buyer.
It would be the responsible thing to do
Alpina's are DOT and TUV approved.
Have a nice one
JC
post #14 of 20 (permalink) Old Oct 19th, 2010, 4:20 am
DADDA's Avatar
it's about the weight!!!!! I installed some Carrozzeria rims and the weight savings and its impact on the handling was fantastic. Big improvement.
Oh, I have had several flats with tubes back in the '80's - scared the shit out of me every time and twice damn near sent me sliding down the road. And that was back when sport tires were about as crappy as the stock Phantoms Ducati put on these bikes.
I did not realise these bikes had tubes when I bought mine. Pissed me off when I found out because I have personal experience with how dangerous they can be.....
The Ducati Sport Classic is like the perfect wife. She's a classic and sporty. Oh, and my wife IS perfect.
Added an MTS1000S to take the wife when the Sport Classic stays at home
DADDA is offline
post #15 of 20 (permalink) Old Jun 11th, 2019, 5:53 pm
FYI, finding tubes in our size is getting harder. I just had to replace mine on my GT1000 and it was a bit of an ordeal. Looking to seal up my rims on my PS1000.
2006 Ducati PS1000.
sylens is offline
post #16 of 20 (permalink) Old Jun 22nd, 2019, 2:22 pm
I put Oz Racing wheels on mine and the difference in handling was astounding
Brass Monkey likes this.
gusman77 is offline
post #17 of 20 (permalink) Old Jun 22nd, 2019, 7:20 pm
Images: 4
I’m going to seal the wire wheels on my ‘77 Triumph Bonneville at the next tire change. I haven’t read about any catastrophic failures, just a couple of slow leaks that required re sealing. I was actually ready to do this myself when I started hearing about it being done successfully. So now the experimenting has been done for me. Tubes are a major pain in the ass. I’m willing to risk having to reseal a wheel after spoke maintenance. Anyone contemplating sealing spoke wheels should make sure the wheels are true and the spokes are tight before sealing.
duc96cr is offline
post #18 of 20 (permalink) Old Jun 24th, 2019, 11:42 am
svc.bmh.mc
telekon's Avatar
Picked up a nail in the middle of nowhere 400 miles from home back in 2009 -- still had the stock wheels + inner tubes at that time. I'll refrain from a bunch of foul language here and simply say it was an incredibly painful ordeal.
"Never again" was my conclusion. Made an investment in Alpinas and carry a BestRest cycle pump + tire plug kit with me at all times.
Present
2007 Ducati GT1000 Sport Classic -- Metallic Black + Crème
2012 BMW K1300S -- Magma Red + Black
2008 BMW R1200RT -- Biarritz Blue Metallic
telekon is offline
post #19 of 20 (permalink) Old Jun 24th, 2019, 12:00 pm
Super Moderator
Chuckracer's Avatar
Images: 2
I've sealed every wire wheel I've owned. Even my dirtbike has tubeless wheels.
Death to tubes!
Chuckracer is offline
post #20 of 20 (permalink) Old Jun 25th, 2019, 2:15 pm
Riderjeff's Avatar
I picked up a nail in my FRONT tire back in 1972 on I-5; that thing went flat so fast you wouldn't believe it. If I'd been in the mountains: forget it, I probably wouldn't be here.
Sealing wire wheels seems like the smart choice if you're not doing solid wheels. 3M Sealing tape. I love my OZ wheels!
Hi, my name is Jeff, and I'm a Ducatiholic.
Riderjeff is offline
New tubeless kit? ConBurros Sport Classic 18 Jun 18th, 2008 3:51 pm
running tubeless blevy1 Sport Classic 14 Feb 7th, 2008 4:49 pm
Going tubeless?? hungryeye Sport Classic 12 Aug 15th, 2007 5:55 pm
GT 1000 Tubeless? CafeMoto Sport Classic 3 Jun 3rd, 2007 12:50 am
How safe is a repair on a tubeless tyre (tire). xopher Sport Touring 19 Feb 24th, 2007 1:23 am
