Help, please. Where did this pin come from? - Page 2 - Ducati.ms - The Ultimate Ducati Forum
post #11 of 12 (permalink) Old Aug 4th, 2019, 6:21 am
Originally Posted by belter View Post
that's the end of the gearshift linkage elbow spring.
Yup.
Never Quit, Die Falling Forward
1996 900 CR. ...Go, Blow, Or Put A Hole In The Fence.
Rex Coil 7 is online now
post #12 of 12 (permalink) Old Aug 4th, 2019, 10:23 am Thread Starter
Originally Posted by Rex Coil 7 View Post
.OP, so there is absolutely no chance that it was in your drain pan before you started your oil change? 100% no chance?
No, it came out stuck fast to the drainplug magnet, which was doing its job! Quite a surprise, though.
I'm relieved the consensus is it's not an engine part and may well have been lying low inside the cases since assembly. That's what I was hoping you'd say. Intriguing, Sheff928, that you found the same thing. I'll ride on, fingers crossed. Thank you all.
_______________________________
Then:
1947 Vincent 1000
1960 Norton Dominator 600
1968 Velocette 500
1972 Commando 750
Now:
2007 GT 1000
Brass Monkey is offline
