What Did You Do To Your SC Today? - Page 137 - Ducati.ms - The Ultimate Ducati Forum
post #1361 of 1416 (permalink) Old Apr 14th, 2019, 11:14 am
ebsilon's Avatar
Originally Posted by Duccout View Post
The WM say's not to use loctite on the belt tensioner screws.
Hmmmmmmmmm, then I am afraid that I have done something wrong........
I have tightened the belt tensioner screws to the 26 Nm as listed in the WM.
Please see the attached image of the C3 section from the WM.
If I have read the WM wrong what is the torque for the belt tensioner screws then?
Please chime in before I am going for a ride.
Ciaoooo
Moller
ebsilon is offline
post #1362 of 1416 (permalink) Old Apr 15th, 2019, 4:31 am
Now I'm baffled! I'm sure that I read somewhere that Ducati say not to use Loctite on the adjustment screws. In the 620 manual it only lists Loctite for the fixed tensioner screws.
I remember that the first time that I tightened up the tensioner screws I used Loctite, then read later that it should not be used, only lightly lubricated threads, so have never used Loctite since. Now I don't know.
Ducati GT1000, Ducati 900S2 Bevel
Duccout is offline
post #1363 of 1416 (permalink) Old Apr 15th, 2019, 8:06 am
Further to that: in the WM for the GT1000 it does not list Loctite for either of the belt tensioner screws:Timing belt idler pulley:
M8x1
20
18
22
Timing belt tensioner pulley
M8x1.25
26
23
29
Baffling? You bet!
Duccout is offline
post #1364 of 1416 (permalink) Old Apr 15th, 2019, 9:54 am
ebsilon's Avatar
Baffling? You bet!
I hear you
The WM for the Sport Classic 1000 (mono) is 100% identical to the WM for the Paul Smart.
But that make sense (maybe) since both the WM for the PS AND the Sport 1000 (mono) are from the same year........!!??
Any way, I did NOT use Locktite and I DID torque the tensioner to ~ 26Nm - so I hope I am good
Ciaooooooo
Moller
ebsilon is offline
post #1365 of 1416 (permalink) Old Apr 17th, 2019, 6:42 am Thread Starter
Official Retired Person
ncgt1000's Avatar
Images: 7
Cleaned it.
Sent from my P008 using Tapatalk
2007 GT1000
Semantics is the difference between "knowing your shit" and "knowing you're shit."
ncgt1000 is offline
post #1366 of 1416 (permalink) Old Apr 17th, 2019, 11:48 am
ebsilon's Avatar
......did change the oil (Motul 300V 10w40) and filter (K&N 153).
I while back I chanced the sprockets (Supersprox 15/42) and chain (DID 520EVR) so I did lube it with Dry Lube (Dr. Wack S100).
Let’s see how it works with Dry Lube
Ciaooooo
Moller
flyingchappy likes this.
ebsilon is offline
post #1367 of 1416 (permalink) Old Apr 17th, 2019, 6:22 pm Thread Starter
ncgt1000's Avatar
Images: 7
Been thinking about this for some time now. Never did care for the looks of the license plate light. I took the stock unit off a few years ago and have been using bolts with integrated LEDs called Lighting Bolts. They're OK. But still not to my liking.
Finally found a used tail light and a piece of clear plastic. Cut a section out of the bottom of the lens, cut a piece of the clear to fit and used some clear silicone to seal it.
I like it! Seems more period correct.
2007 GT1000
ncgt1000 is offline
post #1368 of 1416 (permalink) Old Apr 22nd, 2019, 3:57 pm Thread Starter
ncgt1000's Avatar
Images: 7
Changed oil & filter, changed brake fluid front & rear, cleaned & gapped the spark plugs, checked belt tension and adjusted the chain. I should probably change the fork oil but ran out of time today.
All set of ECM X, at least I think it's X this year.
poolagent likes this.
2007 GT1000
ncgt1000 is offline
post #1369 of 1416 (permalink) Old Apr 23rd, 2019, 11:39 am
Riderjeff's Avatar
Removed the Scotts Permanent Oil Filter. This entails removing the "special" filter mounting nipple I had to install when I originally purchased the filter. I'm not unhappy with the filtration performance of the mesh filter, but realize with experience I prefer the performance and ease of a traditional paper filter. I really just installed the Scotts because it looked cool!
Went with the K&N. Nice filter. And filled 'er up with Red Line Motorcycle 10-40.
Next chore is to bleed the brakes and do a custom install on some Rizoma reservoirs. I'll post some pics, this should be cool.
And BTW ncgt1000, nice job on the tail light! Very clean, and perfectly retro.
ncgt1000 and Coconut like this.
Hi, my name is Jeff, and I'm a Ducatiholic.
Riderjeff is offline
post #1370 of 1416 (permalink) Old Apr 24th, 2019, 5:11 pm
tristan tumble's Avatar
New Ohlins rear shocks added for the season.
tristan tumble is offline
My bike featured today at Ducati news today.com bulldog002 Superbikes 20 May 18th, 2015 12:36 am
Loyalty Program Kicks off Today! Get Double Points Today ONLY! desmoworks Southern California 2 Nov 16th, 2010 9:20 pm
I saw 134 MPH today, has anyone seen more?? 08hyper HyperMotard 120 Feb 20th, 2010 11:12 am
749 on 99 Today scott Northern California 2 Jul 22nd, 2006 8:48 pm
Saw This Today! BimotaDB4 Bimota 1 May 17th, 2006 12:30 am
