What Did You Do To Your SC Today? - Page 134 - Ducati.ms - The Ultimate Ducati Forum
post #1331 of 1398 (permalink) Old Sep 12th, 2018, 5:55 am
Foezzi's Avatar
Brandnew fork legs ... and some other stuff.
And yes, I know.
The spacers will be removed once the brake lines will be installed.
sunstar557 and fastfinch like this.
Foezzi is offline
post #1332 of 1398 (permalink) Old Oct 18th, 2018, 2:01 am
After a loooog wait but it was worth it!
Axis Iron !
ID:	930994   Click image for larger version
Riderjeff, motoFiend and Metman like this.
kevlar11 is offline
post #1333 of 1398 (permalink) Old Oct 24th, 2018, 6:38 am
Put it up for sale
Listed it in the Classifieds "Bikes for Sale". It was a lot of fun owning and modifying it. A great group on this forum!!!!
tackhammer is offline
post #1334 of 1398 (permalink) Old Oct 28th, 2018, 1:46 pm
_MaD's Avatar
Removed the oem rectifier to replace it with a Shindengen FH012DA (off a BMW S1000R). Now I have to build a custom mounting for the FH012.
The oem r/r looks like crap and I'm lucky, it did not burn my bike.
ID:	931513   Click image for larger version
Knowledge is very special: You don't have less if you share it.
_MaD is offline
post #1335 of 1398 (permalink) Old Oct 28th, 2018, 3:20 pm
RubensHub's Avatar
How about what I did with an SC part on my duc?
I designed and 3D printed a bracket (to be later made in steel) and manage to fit an SC seat to my monster frame.
I finally managed to bring the bike to work and got the bracket made in steel.
Its a tight fit and its solid and stable on the road.
sunstar557 likes this.
2001 M750, 2001 748 SBK
RubensHub is offline
post #1336 of 1398 (permalink) Old Oct 28th, 2018, 8:29 pm
blasphemy !!
fastfinch likes this.
mikethepole is offline
post #1337 of 1398 (permalink) Old Nov 4th, 2018, 9:28 pm
Multiplier's Avatar
Rearsets conversion and a few other bits
I did a 900ss rearsets conversion on my 07 biposto and got rid of those funky black triangles.
Parts list:
900ss rearsets (just the brackets and footpegs), ebay
999 rear master cylinder bracket, ebay
999 rear brake lever, ebay
999 rear brake line, ebay
Gear shift lever, M-factory, ebay (still waiting on this piece)
Single post exhaust hangers from stradafab.com (Randy is awesome, does killer work)
added some titanium stradafab frame plugs as well
also going to have the brackets and pegs powder coated black before it leaves the garage.
ID:	931931   Click image for larger version
ID:	931933   Click image for larger version
ID:	931935   Click image for larger version
ID:	931937   Click image for larger version
motoFiend likes this.
Multiplier is offline
post #1338 of 1398 (permalink) Old Nov 5th, 2018, 3:00 am
Monstyr's Avatar
That looks great, I have exactly those parts sitting in my garage for the last few years and never had the time or opportunity to actually fit them.
"The problem with quotes on the Internet is that you can't tell whether or not they're genuine" - Abraham Lincoln
Monstyr is offline
post #1339 of 1398 (permalink) Old Nov 5th, 2018, 12:49 pm
Multiplier's Avatar
You should have a crack at it! It was a lot easier than I expected it to be. I put the bike on the pitbull rear stand, bled the rear brake, removed the rear reservoir, pulled the rear master cylinder, then proceeded to remove the triangles. Once I had them off I installed the new exhaust hangers and assembled the rear brake bracket and master cylinder off the bike. Once it was together I put it on the bike, pulled the old brake line off, installed the new shorter one, reinstalled the reservoir after rerouting the tube, bled the line (used a suction brake bleeder so I didn't run into any of the issues I've heard other guys talk about in regards to stuck bubbles).
One thing to note though - one of the bottom LH triangle mounting bolts also holds the kickstand in place. I didn't realize this, so when I went to take the bike off the rear stand I looked to confirm the kickstand was down (it was) and lowered the bike. When I realized it was starting to lean further than it should I quickly moved to the side and guided it gently to the ground. I took a moment, wept, pulled myself together, and then lifted it off the ground and put it back on the rear stand. Luckily there was zero damage aside from a tiny scratch on the end of the clutch lever. I think the frame slider saved the day. I had a proper size bolt laying around so I installed that on the kickstand and all was well. Was a bit of a FML moment though. Thought long and hard about just running out into traffic and ending it there
Anyway, long story short it was a very easy job.
post #1340 of 1398 (permalink) Old Nov 12th, 2018, 7:30 pm
MOTOKITER's Avatar
Took my Red 1000S off the market
Fell in Love again and decided to keep her after throwing a little more money into her.
-Monster Fork Legs with Ohlins internals
-Ohlins Steering Damper
-Alpina Wheels
-Pirelli Diablo Rosso Corsa tires
-Moto D 90* Valve Stems
-LED taillight
-LED front blinkers from MotoGadget and Stainless Steel adapters from DesmoBros
-Corse Dynamics license plate holder
-Speedy Moto Frame slider
-Fresh High End Paint job for the Fairing
-Bar End Mirrors
Next Year a Corbin Seat and Ohlins for the rear.
ID:	932193   Click image for larger version
ID:	932195   Click image for larger version
ncgt1000, nzdave and Coconut like this.
If I'm not riding my bike I'm flying my kite....
Paul Smart 1000le
BMW R1200GS
Red SC1000S
MOTOKITER is offline
My bike featured today at Ducati news today.com bulldog002 Superbikes 20 May 18th, 2015 12:36 am
Loyalty Program Kicks off Today! Get Double Points Today ONLY! desmoworks Southern California 2 Nov 16th, 2010 9:20 pm
I saw 134 MPH today, has anyone seen more?? 08hyper HyperMotard 120 Feb 20th, 2010 11:12 am
749 on 99 Today scott Northern California 2 Jul 22nd, 2006 8:48 pm
Saw This Today! BimotaDB4 Bimota 1 May 17th, 2006 12:30 am
