The bavarian medical team did some surgery to remove an ulcer from the inner pipe… the patient sounds much better now!
We removed the catalytic converters as they are useless for converting something due to their placement + they constrain the free gas flow.
At least 1/2 of the exhaust gas passes them by as there is a large gap between the cats and the outer skin of the silencers…
The glass wool is not to be seen on the first pic… it is positioned between the cat and the end cap and was totally contaminated…
The cats are of very cheap quality and have been replaced by some stainless steel tube…
The inner pipes have been wrapped with stainless steel wool to create a barrier that prevents the new high tech fiber wool from getting blown out.
The original DB Eaters were substituted by an improved version with much more airflow…
Now the gas can expand in the cans without getting squeezed through the constriction created by the catalytic converters.
I have a slight rattle in one at rev and been contemplating opening one up. I was under the assumption it would have more fiber installation then that. Now I know what my project will be this weekend!
Wonder if a tune is required after removing the cats? Thanks for sharing!
Be sure to take stainless steel wrapping for the perforated inner pipe and 600 grams per can of high quality loose fiberglass wool especially made for exhausts.
Avoid stuffing it too dense…
OK , set up looks really good ...
Uhmmmm I was looking at the picture of the new one and noticed a SMALL pinhole at the end of the weld on the left one...
Splitting hairs here OK...
When welding if he drags his torch off the weld then quickly snaps off the arc then goes back and continues to smoother it with the inert gas till cool PRESTO!!! ...No Pin hole!!!
Really no big deal just saying ...cause I'm a pipefitter and that would be a flaw on a pressure system ...Don't mean squat on an exhaust system tho...
Again good stuff thanks for posting and I'm not trying to be an a$$
I peered down my Termis with a flashlight. I saw straight through and saw the two welds where the pipes turn down. This means I don't have a cat since I can see the downturn, which is far too narrow for a cat and is outside the mufflers. If there was a cat present I would see a honeycomb blocking my view of the exhaust pipe bends.
Having to drill out the rivits just to check if there's a cat present is too much.
Haven't read all the posts on this thread but has anyone ever removed DBs from a zard system? Any words of advise, like.... You'll go deaf if you do it!?
Any pictures would be really useful, because they look pretty well fixed in there and I'm not convinced they will come out.
The bavarian medical team did some surgery ........
You can contact Keimol as he's got a fabricator willing to make baffles. Poolagent also knows one but his fabricator wasn't available to do this (last I heard).
As for me, I've finally procured three sets of OEM baffles. I am sending two sets to a fabricator who will cut two sets and re-weld the end portions, where the holes are, back to a resulting shorter lengths. Therefore I will have a short length, mid-length, and one set of original length. As you can see in the attached photo, I've marked down where the end portions will reattach.
I plan to use a decibel monitor to measure difference in decibels. Since I need to have my bike dyno'ed, I'll try to see if get concrete performance results.
I'm certain that there's some formula in terms of frequency wavelengths of sound and gas flow, so obviously this is not based on any fact and perhaps foolish. But as a few others seem to have done this successfully, I thought I'd try myself. Besides, this re-welding option is cheaper than fabbing from scratch and preserves the orientation & size of holes, if that matters any.
For me I'm searching for compromise between loudness and performance gain, maybe I won't figure anything out from this all, but its a fun experiment/ curiosity.
FWIW, it's obvious that no two baffles are the same, the angles of the baffles and lengths are slightly off and safe to say, Termi baffles are not made automated production system. Gives more credence that this is not an exact science and flexible tolerances.
Hi guys - posted on this topic last week, half way through ceramic coating headers and cans.
This thread goes some way to answering a few queries I raised in the other post, mainly the strange looking thing on one of the inner pipes (sounds like a cat converter - but weird I only have one on one tube only ?)
Other query I raised was in regard to the stainless steel wool at the base of one tube ? I'm guessing this should in both ? But still not sure of purpose.
Anyway - good thread and photos, has helped with the process.
If you don't mind me asking....around how much did it cost to get them coated. This is one of the things I plan on doing next. I've got 3 sets of headers and one pair of exhaust cans I plan on having coated.
The bavarian medical team did some surgery to remove an ulcer from the inner pipe? the patient sounds much better now!
At least 1/2 of the exhaust gas passes them by as there is a large gap between the cats and the outer skin of the silencers?
The glass wool is not to be seen on the first pic? it is positioned between the cat and the end cap and was totally contaminated?
The cats are of very cheap quality and have been replaced by some stainless steel tube?
The original DB Eaters were substituted by an improved version with much more airflow?
Related Threads
2.5M posts
93.6K members
Since 2005
