1000DS Pistons in my 900 - Page 10 - Ducati.ms - The Ultimate Ducati Forum
post #91 of 98 (permalink) Old Mar 21st, 2010, 8:03 am
Banned
it is not the header that heats up the heads, but the hot exhaust
gas that travels through the exhaust port.
the SS1000DS has got shorter exhaust ports for that reason,
and they are sliced for some ventilation too.
a close to stock road engine does not need any further modifications,
get it back together and running, it is well develloped as is, ready to
enjoy with nothing to worry about.
Muschi is offline
post #92 of 98 (permalink) Old Mar 21st, 2010, 10:12 am Thread Starter
LeoLegend's Avatar
This thread certainly went down a different road, but all the information is certainly interesting.
Got it all put back together. I think it was a good thing that I took it apart. The vertical cylinder was caked with oil, maybe from the broken rubber valve seal. When I took the piston out, it looked like the valve had contacted the piston at some point, see pic. Maybe the contact with the piston caused the piston to rock and preceded to blow by oil.
Anyway the bike was running ok except for the loss of about .5 qt every 2k miles.
I inspected the bores for any disturbance, ovality, and taper. Everything seemed to be inspec, so in went the new pistons.
Started up, smoked off the assembly oil, and all is well except for a slightly rich vertical cylinder. No oil is getting through on the vertical anymore thankfully.
LeoLegend is offline
post #93 of 98 (permalink) Old Mar 21st, 2010, 11:25 am
Banned
Well, I and others are finding evidence of cooked oil around the area of the exhaust valve. This means that this area probably gets over 300 deg F. To me, that is a design flaw and I intend to do what I can about it. I need to figure out the most likely cause first of course.
Also, if it was true that this engine was fine as it came from the factory, then why did my valves leak so badly that I need to lap them again? There are many things that are "wrong" with this bike. Other people have had problems with things like early valve guide wear.
dirkwrong is offline
post #94 of 98 (permalink) Old Mar 21st, 2010, 11:28 am
Banned
Wow, it's a good thing you took that engine apart!
How did you determine that the vertical cylinder is running rich?
post #95 of 98 (permalink) Old Mar 21st, 2010, 11:48 am
Chilehead
st2lemans's Avatar
Images: 115
Wear, corrosion, deposits from burning oil due to leaky rings or valve guides, etc.
It's normal, at least in my 2V Ducatis and Guzzis, as well as air-cooled VWs I've owned in the past.
Tom
1985 LeMans
1986 LeMans w/ sidecar
1992 XV250
1998 ST2
2003 SS1000DS
2003 999R #29
www.motogiro.com
st2lemans is offline
post #96 of 98 (permalink) Old Mar 21st, 2010, 12:53 pm Thread Starter
LeoLegend's Avatar
Pulled the plug after a short trip just to check things out, black soot, but not wet so I know it's not oil.
post #97 of 98 (permalink) Old Mar 21st, 2010, 5:32 pm
Banned
Other than an ignition issue on that one cylinder, I really don't have a solution for you, sorry.
Oh, I meant to ask if you checked that valve for trueness. If it hit the piston, then it could very well be bent.
After looking closely at that damaged valve pocket in the piston, I would be very surprised if that valve was not bent!
post #98 of 98 (permalink) Old Mar 21st, 2010, 5:37 pm
Banned
Tom
None of the above, as far as I know. The bike only has 5,000 miles on it, give or take. The guides, rings, etc are good. No oil burning. After lapping the valves, the intake on the vertical cylinder clearance for the opening rocker was too tight, so I opened it up a little, to 0.1 mm (from 0.05). The ECU does have an issue with running too rich, but I hope to have that fixed soon. I suppose the excessive carbon deposits from running too rich could be a problem for the valves in my case.
Are Ducati red letter belts really kevlar for 900 SS? wobblyas Supersport 24 Apr 29th, 2010 7:51 pm
what's faster:monster or SS w/ 1000ds or 944 w/ hi comp pistons? silas Monster 4 Sep 15th, 2008 6:39 pm
2004 Ducati Supersport 1000ds rotors fits 900 Carbie? snellen Supersport 4 Jun 15th, 2008 4:42 pm
966 kit 95 mm pistons jmmmrm Monster 6 Dec 28th, 2007 9:09 am
966 kit 95 mm pistons jmmmrm Supersport 3 Nov 23rd, 2007 4:38 pm
