Another charcoal canister thread (98' 900 SS/FE) - Sorry - Page 2 - Ducati.ms - The Ultimate Ducati Forum
post #11 of 13 (permalink) Old Aug 15th, 2019, 5:37 pm
ducvet's Avatar
The silver aluminum check valve coming out of your tank is all you need, it is a one way valve. Yes air needs to pass into the tank and fuel should not come out the hose under braking, you will find a arrow on the valve. It is not a super strong check valve so if you blow hard enough you get air through in both directions so least resistance going into the tank.
redpato likes this.
ducvet is offline
post #12 of 13 (permalink) Old Aug 15th, 2019, 5:48 pm Thread Starter
jbirdsaway2's Avatar
Perfect! Thanks for the info. I'll be pulling most of the plumbing out this evening and will leave the silver check valve... with the tube going into the center of the tree, and route it down where all the other drain tubes live. Cheers!
redpato and ducvet like this.
jbirdsaway2 is offline
post #13 of 13 (permalink) Old Aug 16th, 2019, 9:07 am Thread Starter
On thing I love about this forum is that people ask for help, get some good guidance, then pop back on and share the results. All benefit this way. Here's the end of my story. I pulled the canister and associated plumbing out completely. I went to O'Reilly Auto Parts and got a set of vacuum caps for a couple bucks. Installed. Pulled the check valve, inspected it and put a new hose on it. Installed the hose down the hole in the tree. And done. See pix if interested (postmortem canister and plumbing, vacuum caps on the vacuum ports, and finished product. Easy money. Time investment? 5 minutes. Thanks to everyone who helped. Cheers.
ID:	951129   Click image for larger version
ID:	951131   Click image for larger version
redpato and spongocoel like this.
