900ss vs 900ss cr - Page 3 - Ducati.ms - The Ultimate Ducati Forum
post #21 of 38 (permalink) Old Aug 14th, 2019, 10:22 am Thread Starter
thank you all for the answers! Truelly appreciated.
Now i just need to figure out, if and how much iam willing to pay. Its my first real bike as i said, and allthough the CR i found here is in rough shape? it goes and runs ok, just need some TLC, one guy has the 900ss full fairing with fila stickers all over the side plus some carbon cans.
The CR is a bit cheaper, but needs overhauling a bit more then the full fairing does..
Hmm....
post #22 of 38 (permalink) Old Aug 14th, 2019, 10:36 am Thread Starter
Thank you guys for all the answers, truelly appreciated.
So, if i would go with the old 900 or the newer 900ie.
here are the options
900 ss full fairing :
1994
41000 km
916 clutch and brake master
alcantara seat
carbon front fender and clutch cover
termi pipes
900 ss CR :
1993
55000 km
needs a good clean and service but it runs and goes.
900 ss IE :
Mint condition, with aftermarket exhaust, duc red and 30.000km
ID:	950941   Click image for larger version
post #23 of 38 (permalink) Old Aug 14th, 2019, 10:52 am
That CR has more to it than you may think. It has a single piece handlebar conversion which requires a new upper triple clamp, handlebar risers, new 7/8" one piece handlebars (instead of clip on handlebars), probably longer throttle cables/clutch line/wiring. That is an expensive upgrade when all things are taken into consideration. The one piece handlebars create a more upright riding position so you are not hunched over the fuel tank.
That CR also appears to have an aftermarket front fairing. That would make sense since the higher handlebars probably need more space in the handlebar cutouts of the fairing to be able to steer the front wheel all the way from lock to lock. That fairing appears to be a single piece (probably fiberglass, but could be carbon fiber). The stock Ducati CR fairing is actually three separate pieces ... the front and the two sides. From that one picture it appears to have been finished quite well (sanding smooth, and painted to match the stock red paint on the fuel tank and rear fender).
All together, the handlebar conversion and the one piece front fairing + paint is probably worth at least $1,500 USD if you had done all of that yourself. Maybe even $2,000 USD.
On the SS, you could convert the full fairing to the CR fairing by just replacing the side pieces. As I said above, the CR fairing is actually three separate pieces. The center piece of the 1990s SS and the CR are the same, so you'd only need to replace the side pieces of the full fairing and install just the sides of the CR fairing to convert the SS/full fairing to the CR style fairing. HOWEVER ... there are probably many nits and bits that would also require changing that I've not mentioned here.
EDIT: On second look, the full fairing on that one bike appears to also be a one piece setup. So it is difficult to say what it would take to convert it to the CR style fairing.
2nd EDIT: The CR also appears to have Showa forks (rather than Marzocci), the small hex on the fork caps is how you can tell.
'96 CR. Square peg among round holes.
Comply or be shunned .. comply! .. Comply! .. COMPLY!
Rex Coil 7 is online now
post #24 of 38 (permalink) Old Aug 14th, 2019, 11:00 am Thread Starter
yes, your right about the handlebars on the CR. allthough, i have to say, I do prefer the look of the clip on. allthough this is more comfy
Would you say the 900ss IE is a " no go" or ?
only considering this because of the direct injection, and in generel easier bike to own.
offcourse the CR is the cheapest of the 3, the newer 900ss ie only about 500 dollars more then the 900 full fairing.
post #25 of 38 (permalink) Old Aug 14th, 2019, 11:05 am
I am unwilling to make that decision for you. The two bikes you posted pictures of (above) look like equal values. That choice is going to be something you will need to make. I prefer carbs and simple bikes, but that is my own preference. I don't care for computer controlled motorcycles ... but again, that is my own preference. I really don't even know you well enough to be able to help you with that choice. I'm sorry.
post #26 of 38 (permalink) Old Aug 14th, 2019, 11:08 am Thread Starter
no offcourse, iam split as well, just curious to hear meanings about the different machines.
I do also like simple machines, but i also want to go ride and less working ( for now) so definately, a difficult choice.
hopefully this forum and this thread can make my choice, easier
post #27 of 38 (permalink) Old Aug 14th, 2019, 11:27 am
My preferences:
Air cooled.
No computer.
No Anti lock brakes.
No traction control.
No anti-wheelie.
Carbs instead of electronic fuel injection.
The more simple the bike, the less there is to go wrong.
Personally, I don't find carburetors difficult to deal with. If you buy a bike with gummed up carbs there are a number of carb services that can fix them ... I chose Ducatiman to do mine. They came out wonderful, and he sets them up to run properly without the owner having to fuss with them. He even sends all of the parts that were replaced back to you so you may see how bad they were. ~About~ $250 USD, but I would imagine shipping them back to you from the US to Europe would need to be paid by you. Or not. Best to ask him.
First picture = "before" ... all the rest are after he serviced them.
Name:	1996 900SS-CR - carbs before rebuilding - 2.jpg
ID:	950945   Click image for larger version
Name:	Ducati 900CR - CARBS - 03.jpg
ID:	950947   Click image for larger version
Name:	Ducati 900CR - CARBS - 06.jpg
ID:	950949   Click image for larger version
Name:	Ducati 900CR - CARBS - 08.jpg
ID:	950951   Click image for larger version
Name:	Ducati 900CR - CARBS - 05.jpg
post #28 of 38 (permalink) Old Aug 14th, 2019, 12:08 pm
I myself recently bought (i.e., overpaid for) a 1996 900SS SP. It did run, but it was in a pretty ratty shape, and needed a lot of attention. As with old bikes of relatively unknown history, I did all the basic stuff - carbs, valve shims, belt, bearings, chain/sprockets, fluid, fuel filter/pump, etc., etc. The point is, though parts are plentiful, it could add up pretty fast, something to keep in mind. I honestly can't tell you which is better, but there's not much there between CR and SS SP that's not already said. I bought SP just because that was the one that popped up when I was looking for one, I would have been just as happy with CR (though I definitely prefer the throwback look of slab-sided SP). Fuel-injected model is nice, too. I'd have been happy with that, too, if I was a bit more smitten by the Terblanche look of it, which, I'm not. If you can though, you should test ride them, and see how you like them. I think you'll enjoy it regardless of which one you pick.
P.S. Service record is a huge bonus, but you already know that.
P.P.S. I'd get the cheapest, the lowest millage one. Or, the most expensive, totally sorted out one. I did neither.
J.B. is online now
post #29 of 38 (permalink) Old Aug 14th, 2019, 1:58 pm
Shortround's Avatar
So you did all of that to it, but still have the non-adjustable forks? Is there some reason for that?
Personally, I'd chose to stay with the 4.5" rear wheel and a 160 rear tire. Much less rotational weight, less unsprung weight, and more nimble performance. But that's my own opinion, everyone has their own reasons for doing what they do. The only reason I've even brought it up is to point out various options to the OP.
old pic. i swapped them out for a set of showa adjustable units. i still run the 4.5 rear with a 160.
Shortround is offline
post #30 of 38 (permalink) Old Aug 14th, 2019, 3:20 pm
ducvet's Avatar
Service records on any?
what a bike looks like can be second to condition and care it has, I see plenty of "perfect" bikes destroyed by over washing so ask for records of what has been done to keep them running well.
On the carbys I would inspect
frame for cracks
studs for chrome
swingarm for cracks on the aluminum version and wether it is a early or late model.
Do they both run and run well?
which one has 10 year old tires that are now plastic?
rubber brake lines on either, should get changed.
Belts done what year?
The tube bars would be a big minus for me but I am not buying the bike.
The solo seat would be a plus if I wanted a solo bike
The better CR forks (showa) is a plus.
nice slip ons on the 900 non-cr/sp
Sticker bike looks good enough I might not change it.
CR looks close to oem outside of the tree change/mods
to have a a multi model price differentiation in the ss model range they put the 900ss engine/carbs/exhaust (americans just love the big engines) into the 750ss chassis with half fairing and that is exactly what the 900ss/cr is.
Just to clarify in the US the 750ss carby had the same aluminum swingarm as the 900 so really the forks,rear wheel width and engines were the chassis differences in the US. For us the steel swingarm started with the 900cr and was carried over to the 750ie in 1999.
Nothing wrong with the 900ie at all but which will you be happiest paying too much money for and putting in your kitchen when the wife is not home?
For me it would likely be decided by condition after a good close look/listen to them all. If all three have good frames,studs and swingarms then it is down to body style and service history. A bike that is stored with old contaminated oil is in much greater danger of having a bearing failure so who took care of the bikes? From poor pictures of one angle I would lean towards the mono but thats me, if the CR has been better cared for than that could change but I do not like a supersport/monster I would rather have a supersport AND a classic monster than the worst of both worlds.
ducvet is offline
