800ss - Anyone Try 15/45 Sprocket Setup? - Page 2 - Ducati.ms - The Ultimate Ducati Forum
post #11 of 16 (permalink) Old Jul 19th, 2019, 11:37 pm Thread Starter
Duc800ss1's Avatar
ducvet - Thank you for the reply. I didn't realize comparing different years were apple and oranges and now will definitely take that into account. I like your idea to try first with the same chain and different setups before making a full change. I think I was just trying to save overall cost by using Gear Commander numbers as a gauge.
belter - Thank you for your reply as well. I actually didn't consider a tune. Also not sure the cost there, but I will look into that.
800ss
Duc800ss1 is offline
post #12 of 16 (permalink) Old Jul 21st, 2019, 1:35 pm
Originally Posted by Duc800ss1 View Post
SalkinSalkin - Thank you for that feedback. Did you have to still feather the clutch at low speeds after the change?
Yes, I still need to feather the clutch at low speed, just not as much as before. Especially in smaller roundabouts.
Gearing seems fine for motorway driving, though, approx. 120 km/h at 4000 rpm.
200 km/h at approx. 7000 rpm.
900SSie 2002 - Senna
SalkinSalkin is offline
post #13 of 16 (permalink) Old Jul 22nd, 2019, 5:07 am
BelgianDuc900SS's Avatar
Hi All,
I am looking to change my rear sprocket to either 43 or 45 tooth setup while retaining the 15 front sprocket. I have a 2005 800ss, pretty much just ride in the city and am not a fan of the low speed chugging.
I have read a bunch of posts here and looked at gear commander as well. Seems like 15/43 is a popular setup. Has anyone tried the 15/45 setup? Also please let me know your general thoughts as well.
Thanks!
Same thing here execpt on a '97 900SS. (stock is 15/37)
I was thinking about changing the rear sprocket to a larger one but (just like you) I didn't know how much larger to go.
So instead of changing the rear sprocket to a 39 or 41 I changed the front to a 14.
The idea was that this way I could test the ratio change in a cheap way (no new, longer chain needed and a front sprocket is cheaper than a rear).
Ratios:
15/37 (stock): 0,405
15/39: 0,384
14/37: 0,378
15/41: 0,365
So with the 14/37 I'm pretty close to the 15/39 ratio and I'm happy with the way the bike acts. So next time I change the chain and sprockets I go for a 15/39 setup. The reason that I will go back to a 15 teeth front sprocket is that with a 14 teeth sprocket you have to keep an eye on the chain guard on the swingarm to prevent the chain eats itself through that guard into the swingarm. So for now I make sure to keep my chain on the correct tension and check the chainguard weekly for excessive wear.
This method translated to your bike would give:
15/39 (stock): 0,384
14/39: 0,358
15/43: 0,348
15/45: 0,333
So in your case you could test a 14/39. That's just above the 15/43. If you're happy with the result the 15/43 will probably be the best setup. If a 14/39 sprocket doesn't give you by far the change you're looking for go for a 15/45.
I think this is the easiest, fastest and cheapest way to test another ratio.
(with a big thx to ducvet, who suggested me this method of testing)
1997 Ducati 900 SS Full Fairing
BelgianDuc900SS is offline
post #14 of 16 (permalink) Old Jul 22nd, 2019, 5:30 am
I should have read the whole thread more carefully before replying.
That way I should have seen ducvets reply... which I now basically repeated.
:shame:
post #15 of 16 (permalink) Old Jul 22nd, 2019, 1:16 pm
ducvet's Avatar
:shame:
I disagree, some times it is how something is worded so even though the basic part is repeated you may write it in a way that someone else can understand better than how I left it.
belter and BelgianDuc900SS like this.
ducvet is offline
post #16 of 16 (permalink) Old Jul 22nd, 2019, 5:54 pm Thread Starter
Duc800ss1's Avatar
BelgianDuc900SS - This is really helpful and appreciate the response. I agree with ducvet that it does help to hear things written differently and also nice to hear feedback with similar advice. I am all for the cost savings approach and trying the 14 front sprocket and then moving to 15 again and having a 43 rear with new chain if I am happy with the feel. Also I am considering using the G2 throttle tamer as well as it seems to have great feedback from this forum community. After all this is done, I am just going to ride and enjoy my motorcycle.
ducvet - As always...appreciate the help.
SalkinSalkin - Thank you also for the follow up answer.
Thanks!
BelgianDuc900SS likes this.
800ss
