New startermotor for 900ss. Need more power? - Page 2 - Ducati.ms - The Ultimate Ducati Forum
post #11 of 13 (permalink) Old May 17th, 2019, 5:19 am
BelgianDuc900SS's Avatar
Originally Posted by DonDuke View Post
Belgianduke you are right. I will install bigger cables later on. But that wasnt the problem today. Even with serious starter cables, directly to the startter motor it still didnt crank hard enough.
If you're starter motor is broken, bigger cables will of course not fix that but they might help to prevent problems in the future with your new starter motor.
1997 Ducati 900 SS Full Fairing
BelgianDuc900SS is offline
post #12 of 13 (permalink) Old May 20th, 2019, 4:15 am Thread Starter
Thanks for your replies and tips guys
DonDuke is offline
post #13 of 13 (permalink) Old Jun 4th, 2019, 1:08 am
Originally Posted by casor View Post
These guys make nice stuff for re-cabling using million strand wire
https://motolectric.com/makes/ducati.html
Welding cable works great for this application. It too, is high strand count copper.
While I totally understand that not everyone is capable (or willing) to make their own cables, and these kits are just the right kind of solution for them ... $120+ bucks is a lot of money for three lengths of cable w/terminations, a few zip ties, a little bit of heat shrink tubing, and an alcohol swab.
As far as the trick cable in those kits, it all comes down to pounds-per-foot of copper. All that high strand count provides is more copper per foot in a smaller diameter cable, and increased flexibility. If one wishes to DIY this, as I mentioned, welding cable is an excellent substitute. There's actually only about $15 bucks worth of components in those cable kits. I can offer assistance for making a solid crimp on the copper eyelets if anyone wants to look into the DIY solution. Send me a private message if you need help with how to crimp those copper eyelets. I'd be happy to help.
Another thing that may help is stuff known as "gas tight paste" which is impregnated with metal crystals (zinc). The metal crystals cut through the mico-thin layer of oxidation on the eyelets and the terminal posts that forms in less than a few milliseconds after the surface(s) are machined/sanded/brushed/whatever clean. The crystals cut through that layer of oxidation, then the "gas tight" substrate seals the connection from air/oxygen to prevent oxidation from creating resistance (which increases load on the battery, and decreases voltage to the starter). When voltage goes down, current goes up. And when that happens, windings on the starter's armature and stator are carrying more current than they were designed to, leading to component failure.
I build modular synthesizers, I hand make bus bars and power cables in the custom power distribution system. And as you may have guessed, I use gas tight paste on all of the DC connections and terminations. Modular synths are highly sensitive to voltage drop and voltage differences from one end of the distribution to the power supply. Using the methods I've described reduces those issues to near null.
So even if your starter is working ok for now, uprating to cables with more copper per foot is a solid preventive measure.
That's a fact, Jack!
"Why is there never enough time to do it right, but always enough time to do it over?"
Yeeeyup.
casor likes this.
Never Quit, Die Falling Forward
1996 900 CR. ... LOW ZOOT
Rex Coil 7 is online now
Diagnosing Alternator - 2010 848 forsythem Tech Forum 74 Nov 12th, 2018 3:06 pm
748 loss of power issue - Help Clearwater748 Superbikes 11 Sep 3rd, 2018 3:22 am
748 power loss - crank position sensor? dwizum Superbikes 15 Aug 25th, 2018 9:36 am
accessory hack (power, iphone nav, and noise cancelling, all in the tank bag) v12gte Multistrada 4 Feb 16th, 2018 4:57 pm
attaching GPS power to 2015/2016 multistrada and multistrada enduro md1day Multistrada 36 Nov 2nd, 2017 10:56 am
