power commander 2002 900ss ie - Ducati.ms - The Ultimate Ducati Forum
post #1 of 15 (permalink) Old May 11th, 2019, 8:13 am Thread Starter
As I begin the rebuild of my 2002 Ducati 900ss ie, I'm looking for the correct power commander, based on the advice of Doug Lofgren. I see a lot of 1999 PCIIIs available, but want to make sure they are compatible with my 2002 ECU. Can anyone help? Are all the FI 900 bikes the same?
"I push, and I push, and I'm happy with what comes out." - V. Rossi
tangobravo is online now
post #2 of 15 (permalink) Old May 11th, 2019, 9:23 am
They are. The pc only intercepts the injection pulse signal, interprets and returns a modified signal. And it also picks up the tps voltage.
xracer is offline
post #3 of 15 (permalink) Old May 11th, 2019, 6:26 pm
Excel Addict
Punch's Avatar
Caution using PC III with 15M A8 ECU
The ECU pins on the A8 differ slightly from the A0, which is what is listed on the PC web site.
The PC web site does not list A8 models.
See the attached for the pin differences and what you have to do if you want to install an A8 ECU in a bike with a harness for an A0.
Download and remove the .pdf extension. That is why I did it originally, however it is useful here.
As xracer wrote the PC III intercepts the injection signal and all important ECU pins are the same for the PC III. to function.
This is what needs to be checked on the PC III harness connectors and I expect it is not the case.
If all pins, apart from the N/C not connected that match on each model, "pass through" the PC III harness then you will be OK.
The pins of concern are 15, 16 and 19. I have included another tab in the Excel workbook to show which pins are which.
Test the PC III harness with a multimeter on the resistance scale.
There should be zero resistance between pin 15 into the PC III and pin 15 out of the PC III. Same for 16 and 19.
If the resistance is infinite, then there are not wires in the PC III harness and it will not work with an A8 bike, such as yours as there will be no required connection between your ECU and your bike's harness.
An alternative with more mapping granularity using the full 16 TPS and 16 RPM breakpoints as opposed to 10 TP breakpoints in the PC III is as follows.
Buy the Lonelec cable for GuzziDiag, JPDiag etc. About 25 Pounds Sterling.
https://www.lonelec.co.uk/Guzzidiag-...nterface-Cable
Download and donate to GuzziDiag - download IAW 15x Reader and IAW 15x Writer.
https://www.von-der-salierburg.de/download/GuzziDiag/
Download in the Downloads area and donate to Tunerpro.
The basic version is fine, so you do not need the RT version.
https://www.tunerpro.net
You can the modify your map in Tunerpro then use IAW Writer to flash your A8 ECU.
I have attached the required XDF for the A8 ECU and the bin file that I am using in my bike, which has open airbox, enlarged crossover and DP exhausts.
It still needs a bit more work, but it is better than the DP bin file that came in the ECU.
Just remove the .pdf from each after downloading.
File Type: pdf 15M A8 900SS 750SS M900 and 15M A0 900SS.xlsx.pdf (473.2 KB, 3 views)
xracer likes this.
Richard Collins - 2001 900SSie I have a 2 strike policy - 2 no responses from a poster = no more responses from me to any post by them. I have a good memory!
Punch is online now
post #4 of 15 (permalink) Old May 12th, 2019, 5:41 pm Thread Starter
So I checked, I have an A8 ECU... so I guess the PCIII won't work. I'm more of a carb guy, to be honest, and me and technology (as in the laptop kind) don't always get along. Also, the only tuning shop for 1000km only does power commander... I asked about Tune ECU and GuzziDag and got a blank stare. Any idiot-proof youtube videos to help someone out?
James
post #5 of 15 (permalink) Old May 12th, 2019, 6:26 pm
Excel Addict
Punch's Avatar
I knew you had an A8.
The PC will work if the pins I mentioned pass through the PC.
This is from my phone on the way to work. Tonight I will get some stuff together if I can.
I have written a guide that covers some of what you want to know in the data logging and mapping thread.
Around post 177 from memory.
Edit - this is the link.
https://www.ducati.ms/forums/5774025-post177.html
Last edited by Punch; May 12th, 2019 at 7:12 pm. Reason: Added link to the guide in Datalogging and mapping
Punch is online now
post #6 of 15 (permalink) Old May 12th, 2019, 7:12 pm Thread Starter
Thanks Punch, I appreciate it!
post #7 of 15 (permalink) Old May 14th, 2019, 3:40 am
Excel Addict
Punch's Avatar
Hi I have been busy at work, but might have time tomorrow to get some stuff together.
What is the configuration of your 900?
Stock or open airbox aftermarket and/or DP exhausts.
If the latter, then you could just write/flash the bin I developed with Andreas and you will be happier.
Just had an email from Georg Siotis in Greece and he is over the moon!
Quoting Georg.
"It's the best .bin file for years! very carefully trimmed, one can clearly get the same feeling (like back in the Days) after getting your Engine with the carburettors trimmed from a real PRO.
The hesitations around 3.500 rpm are gone, and it pulls like a train from 5000 rpm and up. Clearly the improvement one was looking for.
K&N filter and Micron exhaust cans, quite open.
This is what it should have looked like from the beginning, when Ducati designed it."
Punch is online now
post #8 of 15 (permalink) Old May 14th, 2019, 6:19 am Thread Starter
Hi Punch -- not stock -- pof K&N filters from California cycleworks, and a Bimot 2-1 header system (from a DB4) into a megaphone exhaust from Cone engineering. Otherwise stock...
Thanks!
post #9 of 15 (permalink) Old May 14th, 2019, 7:01 am
Excel Addict
Punch's Avatar
Thanks!
OK
What bin file/map are you using at the moment?
Stock or a DP bin file?
If it is stock then you will be running lean.
Even if you are running a DP map, it will not be as good as it should be, but will be better than stock.
By the way, I am no tuning "expert"
All I am doing is applying my math (s) skills to analysing data to achieve a desired outcome.
Just great that I can combine Excel with bikes.
Excel is an addiction or some similar wording.
Punch is online now
post #10 of 15 (permalink) Old May 14th, 2019, 6:21 pm Thread Starter
Currently bone stock ECU, and with the airbox delete and exhaust, I too am worried about an overly lean condition!
851/926: Power Commander frustration! seven4niner Superbikes 6 May 1st, 2018 10:00 pm
Power Commander going bad????? Ratkiller HyperMotard 1 Sep 29th, 2017 7:52 pm
FS: Moto MFG paddock stand, Power Commander 5, Hypermotard JohnnyCakes Parts and Accessories 3 Sep 4th, 2017 10:36 am
