Need to replace my head studs - Page 2 - Ducati.ms - The Ultimate Ducati Forum
post #11 of 14 (permalink) Old May 12th, 2019, 9:49 pm
I replaced the studs on my '92 TWICE. Second time a stud was broken below the case interface so required a lot of time and money (about $US 900 in 1995) to repair it. So if you wait until it breaks you may be faced with it breaking in an inopportune spot and have a more expensive repair. However, they don't all break. So if I was going to have to take the motor apart for other reasons, I would replace the studs (and deal with the galley plug). Other than that I would just leave it alone and ride it.
PhilBoncer likes this.
spacey is online now
post #12 of 14 (permalink) Old May 12th, 2019, 10:07 pm
PhilBoncer's Avatar
It's a crapshoot how long they last. I'd probably leave them alone as long as none are broken (assuming you're not depending on it as your sole transportation to work, etc.). If/when a stud breaks, though, I'd suggest replacing them all as long as you're in there.
I bought an M900 new in 1993, and broke the first stud pretty much right away (horizontal cylinder, in 1995 at 19K miles). We didn't know yet this was a wider problem, so just replaced that one. Then a couple months later another one broke (also horizontal cylinder, at 22K), so we replaced them all (I thought). Due to a miscommunication, I thought that we had done all 8 studs then, but he just did them all on that cylinder. 16 years later (in 2011 at 196K miles), I got a base gasket leak in the vertical cylinder, and in repairing that, found that that cylinder still had the original studs, so replaced those then.
PhilB
1993 Ducati Monster M900, bought new, 265K miles, killed by minivan 30Oct17. 1995 M900, was ex-wife's bike, now mine again.
PhilBoncer is offline
post #13 of 14 (permalink) Old May 12th, 2019, 10:13 pm
Images: 4
If a horizontal stud breaks, no engine removal needed. Maybe Iím lazy ( ok, yes I am lazy) but Iím not dropping the motor for the unbroken vertical studs. Iíll take the gamble.
duc96cr is online now
post #14 of 14 (permalink) Old May 13th, 2019, 7:45 am
Originally Posted by stoshmonster View Post
Well it's your bike so it's totally up to you how you spend your money Rennsportmotorrad but the general rule of thumb is if it ain't broke don't fix it.
That being said I'm with Duc96cr,I'm not knocking Nichols products here either,but there are cheaper alternatives that will do the job every bit as good.
California Cycleworks sells American Performance Engineering (APE) heavy duty cylinder head studs for the 900SS engine. APE heavy duty cylinder head studs are most commonly used in drag racing bike engines. These studs are $13.00 apiece,so basically $104.00 for the set of 8 that you'll need to replace them all.
Realistically our little 900SS engines only make a modest amount of horsepower in stock form. The APE heavy duty cylinder head studs should be much stronger than you'll ever need.
Click me.>>>Ca Cycleworks Cylinder Studs (each) | ca-cycleworks.com
Well just so you know I am one of those people that if I am going to fix a problem or just do preventive service I am not going to cry about the cost I do the repair correctly not cheep out and go to the hardware store to find something that may work --I am a BMW Motorcycle Master Certified Tech, so when I do something it is done as it should be or better-cost be damned
1991 Ducati 900ss, 1991 Ducati 907ie. BMW's too many to list
rennsportmotorrad is online now
Head Stud Pulling Out? BobintheMtns Supersport 4 Sep 17th, 2018 5:42 pm
Head Studs...If or When? motolust Supersport 10 Feb 27th, 2018 7:24 pm
916 Head Gasket Stuck ajrockoff Superbikes 9 Sep 10th, 2016 10:26 pm
Early Monster / Supersport Steering Head bolt moto Vendor Deals 0 Jan 23rd, 2016 8:48 pm
