Fuel pump issues '93 750ss? - Page 13 - Ducati.ms - The Ultimate Ducati Forum
post #121 of 130 (permalink) Old May 1st, 2019, 2:28 pm Thread Starter
ifly65's Avatar
Originally Posted by FredSmoot23 View Post
In STL, there is MotoEuropa, located by the Moto Museum, and Donelson's in St. Ann, for Ducati parts. I have bought Ducati parts from both places, so there are parts available locally. No shipping charges when you walk in the doors...
Fred
MotoEuropa is very cool. Super nice guys too! The bikes there are beautiful.
I just test drove the bike and its better than ever! I will give it the highway test soon.
Thanks again guys!
Ducati 1993 750ss/cr
The past: Honda 1000RR Fireblade F2 Yamaha R6 xj700 xs400 Suzuki GSXR600 Kaw 750 550
ifly65 is offline
post #122 of 130 (permalink) Old May 18th, 2019, 3:05 pm Thread Starter
ifly65's Avatar
UPDATE: The bike ran great after the new fuel pump and filters, but now it is leaking fuel from a carb after a couple of rides. It looks like the float overflow?
I would guess I need to do carb rebuild since my tank was so loaded up with debris?
-What carbs do I have on a stock '93 750ss, Mikuni BDST 38-B70?
-Where do I find a rebuild kit for it?
-Do I need to do a jetting for the 2-1 DND exhaust conversion I did? When its running properly, it doesn't seem to need it, but I find it hard to believe that it doesn't need it. Are there better Main and Pilot Jet sizes for this exhaust?
Thanks guys!
ifly65 is offline
post #123 of 130 (permalink) Old May 18th, 2019, 5:45 pm
FredSmoot23's Avatar
Images: 18
'93 750SS.....
You are welcome to borrow my Haynes Manual 600,750,900 2 valve V-twins '91-'96. Could be of help to you. You have my number. Texted you the rebuild kit info @ 5:40pm.
Fred
ifly65 likes this.
1996 SS/SP B52 40k miles
MBP collets / 748 front rotors / 4.5" rear wheel / Sharkskins / Nichols frame bolts
FredSmoot23 is offline
post #124 of 130 (permalink) Old May 18th, 2019, 9:23 pm
Thanks guys!
Probably either the circumferential o-ring gasket that fits in the groove in the bowl has dried out and/or the float valves not sealing that let fuel into bowl. The latter have a conical rubber seal that seats against the brass seat in carb body and stop the flow of gas when the floats push against it - works like a toilet bowl float. The valves are notorious for failing with the shit fuel we have. It could also be that the floats themselves have failed and are filling with gas - thus making them not floats any longer, allowing gas to continue to run into the bowl. Take them out and see if there is fluid in them - but not a common problem.
Failure is not an option 1995 Duc 916,1994 Bim DB2,1986 Duc MHR Mille, 1974 Duc 750 Sport, 1965 Duc Monza
casor is offline
post #125 of 130 (permalink) Old May 18th, 2019, 9:30 pm
I misspoke in my last, the carb gasket is a rather complex shape made specifically for the BDST 38.
Can be seen here along with the rest of the annoying parts needed:
https://www.ebay.com/itm/2x-Ducati-9...item4b6021b5bb
ifly65 likes this.
casor is offline
post #126 of 130 (permalink) Old May 19th, 2019, 2:59 am Thread Starter
ifly65's Avatar
Fred
Thanks again Fred! Ill find out more tomorrow hopefully. Great chatting and Ill let you know how it goes.
ifly65 is offline
post #127 of 130 (permalink) Old May 19th, 2019, 3:08 am Thread Starter
ifly65's Avatar
Thanks again casor. That link has a great price for 2x kits. My mechanic partially rebuilt these a year ago for the previous owner. My tank really cleaned up nice, but I didn't rinse all the debris out of the small tubes good enough. I had some left over rust flakes in the feed tubes or tank valve that the outside micro filter caught, then the carb started leaking again. I want to see whats up for myself now for sure.
ifly65 is offline
post #128 of 130 (permalink) Old May 20th, 2019, 11:43 am Thread Starter
ifly65's Avatar
Carbs are out! I grabbed this kit. Thanks again Fred and casor!
I noticed my tank valve is leaking when its closed.
Mornington shows this part #
https://www.ebay.com/itm/1997-Ducati...53.m1438.l2649
Do I need the entire valve assembly or is there an o ring I can change out instead?
Does this change the performance when open if its leaking when closed?
ifly65 is offline
post #129 of 130 (permalink) Old May 20th, 2019, 5:21 pm
It would be helpful to know where it's leaking, such as where it fits to the tank or though the body of the valve. If just where it fits up, Belmetric has a ton of metric orings and seals. From the Ebay link, it looks like you need a hollow crush washer which actually crushes under torque, thus providing a superior seal. Measure the old one accurately.
I have never taken one of these apart, so if it's the body of the valve leaking, take your chances and disassemble it if it can be. Rubber seals should be Viton
https://www.belmetric.com/drain-plug...kets-c-11.html
ifly65 likes this.
casor is offline
post #130 of 130 (permalink) Old May 26th, 2019, 8:59 pm Thread Starter
ifly65's Avatar
Update: Thanks again Fredsmoot23 and Wounded Duc. I just finished installing a different set of much nicer carbs off of a 1995 900ss. Rebuild kits for 750ss.
ifly65 is offline
2005 multistrada 1000s ds fuel pump issues Chris Lange Multistrada 7 Aug 17th, 2019 12:40 pm
Fuel Pump issues GTnyc Sport Classic 4 Sep 6th, 2018 4:41 pm
2001 750SSie - horizontal cylinder airbox backfire after fuel pump replacement The Blue Rider Supersport 0 Jul 7th, 2017 11:47 pm
