Picking up a '95 900SS Sunday - Page 5 - Ducati.ms - The Ultimate Ducati Forum
post #41 of 75 (permalink) Old Apr 24th, 2019, 10:48 pm
steveb64's Avatar
Images: 2
Originally Posted by Peevedkitten View Post
Good to know on the belts. We will just go ahead and do them while we're in there, not worth the risk.
Any recommended threads/guides/kits for stud replacement? I wasn't planning on taking the heads off, can it be done with them on?
There is a bunch of threads here about replacing the studs - just search 'replacing studs'. It's a popular subject... But it's also one of those "If it ain't broke, don't fix it" cases, because it's a curse of a job to do.
https://www.ducati.ms/forums/57-supe...-breakage.html
https://www.ducati.ms/forums/57-supe...ml#post6063073 - has links to 3 other threads on replacing studs.
One of the things to check with the studs is whether they have a letter stamped on the end - my OEM (now replaced) studs had a 'M' (or a 'W' depending on orientation) stamped on them.
One consideration for your front end upgrades - a heavier linear spring will make the front of the bike ride significantly higher, which will make it steer like a barge... The cheap fix is a SSie rear shock, which is a bit longer than the carbie one - or else the afore mentioned Ohlins (which has a ride height adjuster), or any other ride height adjustable unit, to raise the rear height, and bring the turn-in back to what it should be.
One thing you may want to consider is upgrading the silly filament dash lights to LED - so you can see them in the daylight... This thread will help - https://www.ducati.ms/forums/57-supe...-95-900ss.html
'95 900 Superlight IV #064
Mods are: K&N filter, airbox lid on with rubber trumpets removed, MBP collets, full SMI (SilMoto Italia) spaghetti exhaust with 'open' carbon cans, 41mm FCR's - #182 mains!, Barnett alloy clutch basket, Oberon slave cylinder, Ohlins fork springs, Ohlins rear shock, Verlicchi swingarm.
steveb64 is offline
post #42 of 75 (permalink) Old Apr 25th, 2019, 11:33 am Thread Starter
We will check the studs, but I'm not in a huge rush on it. If I don't have to remove the heads I'm not going to. Thanks for the links, I will definitely check out the LED dash upgrades.
As for work on the bike; We pretty much have the shop completely re-done. I've started working on restoring the carbon fiber cans because I have the materials on hand already to do that. I cracked the lid on the carbs and immediately closed them back up. I'll need new diaphragms for both carbs unfortunately, along with complete gasket rebuild kits. It was expected, but it's still disappointing.
I expect we'll be stalled out for a bit on the 900 while we wait for funds. We're still waiting on the car to sell. In the mean time, we've just been cleaning it repeatedly. Some parts of the bike are just caked in grime and grease that's been there for years it seems. We'll get there eventually, we're focusing more on a resto and less on mods for the most part.
82 CM200T(Basket case), 04 DRZ 400SM (sold, best bike ever), 01 VFR800 (went kablooey), 09 Concours 14 (RIP - nobody needs coffee that badly), 15 Multistrada, 95 900SS
Peevedkitten is offline
post #43 of 75 (permalink) Old May 5th, 2019, 1:44 pm Thread Starter
Some progress
Ok, so I've gotten a few things done. The shop is finally usable again. We had just remodeled our living room and it was an absolute disaster. My daily now has a nice spot and the 900 is enshrined in it's own little maintenance spot right beside the beer tap!
As far as bike progress I finished restoring one of the carbon fiber cans. I went with a satin finish exhaust clear coat, I like the finish a lot more in person than on camera. I though I would share some pics. I wasn't super concerned about the banding since the can will go back in the same spot.
In other news I raided the couch cushions and full gasket kits and new diaphragms for the carbs have been ordered. When they show up I'll clean & rebuild the carbs. Then I'll probably fit them and rig up an aux tank for a test fire. I haven't gotten a straight answer on when he last cranked and ran it. We'll see how it goes and I'll shoot some video!
post #44 of 75 (permalink) Old May 6th, 2019, 10:58 am
This all looks GREAT mate. Youll probably get back to putting the carbs on before I do......if you could post some pics of the hose setup that would be a great service to the 900ss carby community. I don't know why, but I haven't been able to find a single diagram that shows every hose in and out of the carbs.
Erics75218 is offline
post #45 of 75 (permalink) Old May 6th, 2019, 12:53 pm
The cans look good. What prep did you do to them before painting? What brand of paint and where did you pick it up? Much thanks.
'96 900SS/CR;'94 Honda NSR250R/SP; '93 NSR250R/SE; '02 Yamaha WR426; '07 Aprilia RXV450
Racer117 is offline
post #46 of 75 (permalink) Old May 6th, 2019, 1:21 pm
BobbyBoy's Avatar
Images: 3
Love SS build threads, subscribed.
'06 999s
'03 SS 1000 (Sold)
BobbyBoy is offline
post #47 of 75 (permalink) Old May 6th, 2019, 1:29 pm Thread Starter
So, work on the cans is as follows:
  • De grease and clean
  • Sand down can with 400 grit sandpaper - focus on any pitting or blems, but make absolutely sure not to penetrate the clearcoat
  • Filled pitting with Duralco™ 4460 epoxy
  • Sand epoxied area's until they match with the surrounding clearcoat (ie are smooth and indistinguishable when running your hand over it)
    Code:
    Repeat 4-5x:
    Clean any dust/residue
    Spray with high temp clear coat - light coat
    Bake on per instructions
    Sand with 1200-1500 grit in between coats to remove any pooling or runs
    Return to repeat
  • Finishing sand with 1200 grit then 1500 grit
  • Use a buffer and rubbing compound to remove any fine scratches and marks left by sanding
  • Use polishing compound to finish the can off
  • wipe any lasting residue off and you're done!
Install cans!
The clearcoat I'm using is the high temp satin finish from Autozone.
post #48 of 75 (permalink) Old May 11th, 2019, 9:51 pm Thread Starter
Carb parts are here
The carb parts showed up today. I'm going to start working on them tonight. I'm more excited than I expected to be honestly.
The wife has Ok'd a number of future projects and plans involving Ducati's, but I'm not sure if I want to delve into all of those plans just yet. I just wanted to take a moment and mention her impact on this project.
I was not a Ducati fan before I bought my multi, I wanted a Triumph Tiger. She talked me into the multi and after riding the bike, I can honestly say I'm a fan. I've ridden this 900 before but never as my own bike. Having put a few thousand miles down on the Multi I'm sold. I've ridden every make of bike from Aprilia to Yamaha and the Multi just puts this stupid grin on my face I can't explain. My wife and I are in agreement that we need more of that in our lives.
I'm off to help my wonderful wife dye her hair blue now...
post #49 of 75 (permalink) Old May 26th, 2019, 12:33 am Thread Starter
Not dead yet
I'm not dead yet and neither is the build. It has not been a pleasant couple weeks. My wife and I both got the flu and then I broke a wisdom tooth which I'm still recovering from. However, Nyquil is amazing and should be used more responsibly... I have all the front end suspension parts ordered and on their way.
My wife and I have an agreement that we are not half-assing anything on this project. So as a result things are taking a little longer. I don't really go out to the shop unless I'm willing to put in the effort and take my time.
Carbs are being rebuilt this weekend. I chose to go all the way and have ordered a synchronization tool and stripped the carbs entirely. I'll return everything to the same measurements from before I disassembled it and tune it from there. The carbs were in worse shape than I expected. I think it's likely I was the last person to rebuild them almost a decade ago...
So here's a couple shots of the progress:
Nasty dirty road grime all over them.
Debris in the bowl, this concerns me more than a little bit.
Dirty on the left clean on the right.
I do need a hand finding a gasket. There are little rubber gaskets that fit in between a plastic shared rail. It's the rail that holds the retainer for the floats. They are completely and totally shot.
post #50 of 75 (permalink) Old May 26th, 2019, 9:07 am
Iwannaduc's Avatar
Suzuki part #13673-44B00. Used on almost all the old carbureted GSXRs. I have one so I had a complete set on hand for rebuilding the rack of 4 on it. You can still get them from Suzuki or you can try Ron Ayer's online. Not sure who was more expensive though. They were around $3 each IIRC but that was a while back.......sean
edited to add: I just remembered...my local Suzuki shop would not sell me just the 4 that I needed. They would only order them in a box of 10 so I got 10 rather than just the 4 I needed. If I were to do it all over again, I'd probably just measure the o-ring and see if I could find one elsewhere. Honestly, it should cost around 10 cents rather than $3.
My garage: Twins:2000.5 Mille R, 2000 996, 1994 EX500 basket case 1993 900SS. Suzukis: 2004 GSXR600, 1992 GSXR750 oil boiler, 1983 XN-85 Turbo
Iwannaduc is offline
900SS SP, maybe...? J.B. Supersport 23 Aug 17th, 2018 12:51 pm
FS: 916/900SS PARTS: 916 Shock / Biposto Sub - Tons of 900SS Parts - DSLR PICS! samadhi Parts and Accessories 4 Apr 15th, 2018 4:32 am
FS / CA: 96' 900SS - Selling Fairings + Tons Of Parts samadhi Parts and Accessories 2 Oct 18th, 2017 5:48 pm
Picking up my 749 this sunday!! What to look for? 4 Day count down! jiigan Superbikes 10 Jun 26th, 2017 4:59 pm
WTB and FS: Bevel 900ss header pipes robax Parts and Accessories 0 Aug 12th, 2016 7:00 am
