Searching for piston rings - Ducati.ms - The Ultimate Ducati Forum
  • 2 Post By 117
post #1 of 3 (permalink) Old Aug 26th, 2018, 6:33 am Thread Starter
117
117's Avatar
Hello all. I have a 1993 900ss that was converted to a 944 back in 1995 with what I believe to be the Ducati Performance/Gio.Ca.Moto 944 kit made by Gilardoni. I've got the engine apart now to replace the crankshaft oil gallery plug (grrrrr!) and it looks like the rings could use refreshing. Any ideas for finding them? I've measured and the top 2 rings are 1.50mm wide and the oil ring is 3mm wide. These are for 94mm pistons.
117 is offline
post #2 of 3 (permalink) Old Aug 26th, 2018, 8:16 am
Images: 4
Any chance ST2 or ST3 rings will work ? At any rate they would be ridiculous price wise. I’d contact companies that sell aftermarket 944 kits and see if those rings might fit, they’re bound to be cheaper.
duc96cr is online now
post #3 of 3 (permalink) Old Aug 26th, 2018, 4:59 pm Thread Starter
117
117's Avatar
At least the gallery plug won't be backing out again!
ductech and psyopper like this.
117 is offline
Trouble changing split rings and checking valve clearances. Classic_Duc Sport Classic 8 Aug 17th, 2017 4:11 am
need help fuel injector o rings charlesbx99 Superbikes 1 Apr 26th, 2017 9:41 am
Valves adjustment: Stock Half Rings & deformation mvric Supersport 14 Jun 27th, 2016 6:49 pm
st tank o rings djzander Sport Touring 5 Mar 22nd, 2016 7:39 pm
93 900ss rear shock o rings mdobin Supersport 4 Jan 8th, 2016 11:43 pm
