Mikuni Rebuild - Ducati.ms - The Ultimate Ducati Forum
  • 1 Post By bigbadbass2
post #1 of 9 (permalink) Old Dec 17th, 2017, 3:29 pm Thread Starter
walduc's Avatar
Mikuni Rebuild
Im replacing all the seals on my 900ss carbs. I was wondering if anyone has replaced the throttle shaft seals? I have the butterfly out, but the shaft seems secured behind an external welsh plug. I thought Id ask before I destroy the plug and possibly the carburetor. I have the shaft seals and carb kit purchased from Litetek. Any ideas??
Ride quickly, Ride often.
walduc is offline
post #2 of 9 (permalink) Old Dec 17th, 2017, 9:16 pm
bigbadbass2's Avatar
you've separated (split) the carb set?
'95 900SS/SP , '07 SS800 , '98 VFR800 , '19 CBR650R
bigbadbass2 is offline
post #3 of 9 (permalink) Old Dec 18th, 2017, 9:09 am
Images: 4
My advice would be to leave it alone unless you see some sign of leaks. Ive never heard of it being a problem. Just seal over the plug if youre concerned .
duc96cr is offline
post #4 of 9 (permalink) Old Dec 18th, 2017, 10:59 am
litetek website lists "assembly guide" right under your throttle shaft seal listing. Instruction is right there. Here's a link.....
Guide to Placement of Mikuni BDST Throttle Shaft Seal
Stick likes this.
post #5 of 9 (permalink) Old Dec 18th, 2017, 2:39 pm
Stick's Avatar
Wow, let's all pray that the above website never goes to the WWW hell gremlins! (Site not found....)
That's some serious detail on redoing the carbs!
Stick -~~~- Need an adrenaline rush? Shove a DUC between your legs.
Present DUCs: 2013 MTS1200S GT, 2003 ST4S, 2001 ST2, 1996 900 SS/CR, 1996 900 SS/SP
Stick is offline
post #6 of 9 (permalink) Old Dec 18th, 2017, 5:05 pm Thread Starter
walduc's Avatar
Yes, apart.
walduc is offline
post #7 of 9 (permalink) Old Dec 18th, 2017, 5:13 pm Thread Starter
walduc's Avatar
Yes, but the photo and procedure is generic for BDST 38 and I’ve read and am familiar with the directions. The shaft won’t pull out per the instructions. I believe it’s secured behind the plug unbeknownst to the author. I’m concerned that the other end is peened over like the throttle end and not secured with a nut.
walduc is offline
post #8 of 9 (permalink) Old Dec 18th, 2017, 7:22 pm
One photo clearly shows throttle shaft removed, one seal and washer only... yet welsh plug still installed on carb body.
I think the throttle shaft, with some *very gentle* persuasion...should pull out.
Otherwise, consider contacting the vendor for clarification.
post #9 of 9 (permalink) Old Dec 19th, 2017, 5:29 pm Thread Starter
walduc's Avatar
Thanks, will do!
walduc is offline
Rear Brake Capilper rebuild kit? KB02 Sport Touring 1 Oct 21st, 2017 3:47 pm
FS, CA: 900SS Rear Wheel + Tire, Stage 2 Mikuni Carb + Factory Pro Carb Parts samadhi Parts and Accessories 1 Sep 13th, 2017 10:37 am
FS: CA: 900SS Rear Wheel + Tire, Stage 22 Mikuni Carb + Factory Pro Carb Parts samadhi Parts and Accessories 0 Sep 1st, 2017 5:51 pm
Ducati 900SS Parts: Rear Wheel + Tire, Stage 22 Mikuni Carb + Factory Pro Carb Parts samadhi Parts and Accessories 0 Aug 17th, 2017 12:55 am
ST2 Top end rebuild ChrisJ748 Sport Touring 24 Feb 14th, 2016 3:51 pm
