Broke my turn signal switch - Ducati.ms - The Ultimate Ducati Forum
post #1 of 4 (permalink) Old Apr 8th, 2008, 11:55 am Thread Starter
Don't know how I did it but I clicked it to signal right and it just got jammed over there. I pushed to cancel and the light stopped blinking but the switch stopped working for righthand turns - and it's kinda angled and jammed too.
What's the compatibility of other model/year Duc signal controls working on a '02ie?
spikedlemon is offline
post #2 of 4 (permalink) Old Apr 8th, 2008, 3:09 pm
Take it apart, you may well find that you can fix it; they're pretty simple things.
One (short handled) phillips head screwdriver is all you need. Left had switch gear off any late model SS will work, probably also 916, 996 possibly others.
99 SSie
75 860 GT
Oldduc is offline
post #3 of 4 (permalink) Old Apr 8th, 2008, 6:14 pm Thread Starter
I suspect you're right... Ducati is a small enough company to make them all the same.
post #4 of 4 (permalink) Old Apr 8th, 2008, 7:13 pm Thread Starter
Took it apart; sprayed it with silicone and filed the edges where it hits the spring loaded ball (hope to make it a smoother transition). And straightened out the lever (it was a little bent)
Signals like a champ now.
Replacing turn signal switch kneedrachen Supersport 3 Jun 8th, 2007 6:25 am
1993 900ss Turn Signal Switch icemetal900ss Supersport 5 Jan 17th, 2007 5:42 pm
'99 900SS turn signal switch problems M5Marc Supersport 0 Sep 25th, 2006 12:32 pm
749 turn signal switch trivia: or why I hate boneheaded changes like this rustysrustyduc Superbikes 5 May 24th, 2006 4:50 pm
