What have you done to/with your SS today? - Page 81 - Ducati.ms - The Ultimate Ducati Forum
post #801 of 1211 (permalink) Old Apr 13th, 2018, 7:25 pm
grrss's Avatar
New shoes.
Name:	diablo rosso III - Copy.JPG
quack748 likes this.
grrss is offline
post #802 of 1211 (permalink) Old Apr 13th, 2018, 7:42 pm
Images: 4
They always feel soooo good !
duc96cr is offline
post #803 of 1211 (permalink) Old Apr 13th, 2018, 10:19 pm
Originally Posted by grrss View Post
New shoes.
Put the same ones on my SSie last year.
ID:	905434   Click image for larger version
900SSie 2002 - Senna
SalkinSalkin is offline
post #804 of 1211 (permalink) Old Apr 25th, 2018, 8:12 am
steveb64's Avatar
Images: 2
New shoes.
Hmmm. I haven't tried the Rosso III's. Yet. Maybe for next summer...
'95 900 Superlight IV #064
Mods are: K&N filter, airbox lid on with rubber trumpets removed, MBP collets, full SMI (SilMoto Italia) spaghetti exhaust with 'open' carbon cans, 41mm FCR's - #182 mains!, Barnett alloy clutch basket, Oberon slave cylinder, Ohlins fork springs, Ohlins rear shock, Verlicchi swingarm.
steveb64 is offline
post #805 of 1211 (permalink) Old Apr 25th, 2018, 10:38 am
psyopper's Avatar
They're a really nice tire. They came stock on my 2017 Supersport, and I just put a pair on my '94 900SS, I liked them well enough for that. I'll be replacing them on the 2017 with a pair of Road 5's though, I'd like to get more than one season out of tires on my distance bike.
1994 900 SS/CR
2017 939 Supersport S
It's Italian. If I can get it to start, it'll win.
psyopper is offline
post #806 of 1211 (permalink) Old Apr 25th, 2018, 10:49 am
I got my 95 900ss down off the stands (where it has been hibernating), disconnected the trickle charger, aired the tires, swapped in fresh non-ethanol gas, turned the key and thumbed the starter. Then I pushed it back into the garage and went out to buy a new battery.
Edit/Update: New battery installed and the old girl started as well, stone cold, as my fuel injected Japanese bikes! Thinking back to issues I had last season... the battery has been going for a long time.
psyopper likes this.
95 900SS/SP #210
thrasher_s is offline
post #807 of 1211 (permalink) Old May 3rd, 2018, 11:04 pm
Hot Air's Avatar
Finally got round to replacing a broken down pipe on the rear cylinder. (Flange where it mates with the exh gasket is broken off). But, OH NO! It’s different! Had to jam the broken one back in again. Big waste of time, sweat and a little cursing.
(A friend sourced the replacement for me from a breakers in NZ. He doesn’t own an SS so had nothing to check it against. I don’t know what year this pipe came from but it’s for one of the carby models. Mine is ‘96 900 so now I’m on the lookout for another. Ideally one that fits!)
899Panigale,900ss(1996)YZ450FX. Previous:FZR1000EXUP,FZR400 F3 racebike,RZ50 “bucket racer”,D50 “bucket racer”,RD350YPVS,YB125.Go VR46!(And if Rossi doesn’t win, may it be Dovi)
Hot Air is offline
post #808 of 1211 (permalink) Old May 5th, 2018, 6:20 pm
Today I bled the front brake and clutch lines and lubed up my lever pivots. The clutch pivot was getting pretty crusty.
Hot Air likes this.
Scott - 1993 900SS
spongocoel is offline
post #809 of 1211 (permalink) Old May 9th, 2018, 11:01 pm
Lelebebbel's Avatar
Installed my home made float-based low fuel sensor in the tank, replacing the OEM unit that probably hasn't worked since the 90s. So for the first time, all the warning lights on the dash actually work.
Also pulled out my flogged out Sachs rear shock and installed barely used showa unit from another 900SS, as a place holder until I decide what to do with the Sachs.
While the bike was on the stand, discovered that I have play in the front wheel, so i installed two new wheel bearings. Tip, dirt bike shops have tons of wheel bearings as they are a common wear item for them.
Currently pulling the airbox off to re-jet the carb and install new throttle cables.
Hot Air likes this.
- 2002 998
- 1994 900SS-CR
Lelebebbel is offline
post #810 of 1211 (permalink) Old May 17th, 2018, 11:39 am
rwantin's Avatar
Images: 22
Spring was WAY late here in Michigan, and as I commute on the others, this one was, sadly, last to be started and given a good look-over. The good news is that she's running great, and in some desperate need of some exercise.
beemerboy likes this.
Robert
Loud clutches save lives.
1992 Ducati 900 SS, 2009 Triumph Speed Triple
2007 Triumph Bonneville T100, 2005 Honda VTX1300S
rwantin is online now
My bike featured today at Ducati news today.com bulldog002 Superbikes 20 May 18th, 2015 12:36 am
Today is 11-12-13 Bill_Anderson Chit Chat 15 Nov 13th, 2013 7:50 am
Loyalty Program Kicks off Today! Get Double Points Today ONLY! desmoworks Southern California 2 Nov 16th, 2010 9:20 pm
Saw This Today! BimotaDB4 Bimota 1 May 17th, 2006 12:30 am
