What have you done to/with your SS today? - Page 23 - Ducati.ms - The Ultimate Ducati Forum
post #221 of 1180 (permalink) Old Mar 26th, 2015, 3:43 pm
Originally Posted by psyopper View Post
I wasn't lying when I said I was already about 75% done. It took a LOT of massaging of the plastic Ducati headlight adapter and coupling it with a standard sealed beam trim ring from a mid 90's GM pickup. There wasn't any work to do on the inside of the fairing, the lip was pretty straight and level from the factory. All I had to do was run a bead of glue and drop the cover into place.
Haven't been out at night with it yet, weather around here continues to be standard fare for an Oregon spring. Things should be nicer tomorrow - I'll try for some better photos and a night ride.
Should do an install thread on it. When looking at it versus the sock light, I was trying to wrap my head on how to mount it to the plastic mounting bracket and keep it clean looking. Would like to see what you did.
1998 900 SS/CR Project
1999 M750 Dark ~ Daily Rider
griffonsec is offline
post #222 of 1180 (permalink) Old Mar 27th, 2015, 7:07 am
S4RsRider's Avatar
Images: 4
Originally Posted by jens.bal View Post
Trial fitting an original carbon fibre sl seat.... Poll: paint it, or leave itcarbon with clearcoat? Awaiting new shoes as well: metzeler m7 sportec Rr
Both. I think you should paint it, with white number plates, but leaving subtle "flashes" of carbon fiber exposed (edges or a thin pinstripe or even a center stripe, something along those lines), then clearcoat the whole thing!
Example of what I am thinking of:
CF_S4Rs_020 by s4rsrider, on Flickr
2007 S4Rs, 2006 1000SS track bike, 2003 1000SS project bike
2000 Harley FXDX Super Glide Sport, 2006 Harley FLHXI Street Glide
1967 Honda CL90, 1995 MZ Skorpion Sport 660
S4RsRider is offline
post #223 of 1180 (permalink) Old Mar 27th, 2015, 10:04 am
Images: 36
Great Idea
Originally Posted by JaysinSpaceman View Post
Well I didn't really do it to the bike but I built it for the bike. I wanted a center stand type thing for maintenance and since I own a welding and fabrication business I thought I'd whip something up. I'll let the pictures talk...
Anyway, it should make my upcoming valve adjustment easier and help with lubing chains, etc... It uses the through hole in the back of the cases to fix to the bike to the stand with a 3/8" pin so the bike is super secure and stable.
That's was yesterday's little project.
Thanx,
Jaysin
So if you were to make and sell them how much would you ask?
SportBikeTrackTime
1999 Ducati 900SSie
John Deere 42"
Tora 22" sp
enjoy life ride a duc today.
curveman99 is offline
post #224 of 1180 (permalink) Old Mar 27th, 2015, 10:23 am
Images: 36
Winter
Winter To Do List Done...
-New rear axle
-New Tires
-Change and bleed Brake fluids
-Brake pads Frt/RR
-New speedo cable
-New (2) Titanium engine bolts and Nuts $$$
-New Oil/Filter
-Clean chain
-Spark Plugs
-Clean,Clean,Clean
I'm ready for summer Track Days..
Now just waiting for Winter to leave.................
SportBikeTrackTime
1999 Ducati 900SSie
John Deere 42"
Tora 22" sp
post #225 of 1180 (permalink) Old Mar 27th, 2015, 12:28 pm
psyopper's Avatar
That's been the Ducati Performance look on their body work for a very long time. Classic and beautifully Italian.
1994 900 SS/CR
2017 939 Supersport S
It's Italian. If I can get it to start, it'll win.
psyopper is offline
post #226 of 1180 (permalink) Old Mar 27th, 2015, 2:24 pm
Kevin T's Avatar
Does buying tools count? I just ordered a Carbtune to check the sync on my carbs. I wanted to hold out for one of these but who knows when they will be ready!
Kevin T is offline
post #227 of 1180 (permalink) Old Mar 27th, 2015, 4:35 pm
ian996's Avatar
I installed a radial clutch master cylinder and Tygon tubing to both reservoirs.
Name:	900 in the yard.jpg
Current Rides
2012 Multistrada 1200 S, 2000 996 mono track only, 1997 900 SS track only, 2002 BMW R1100S, 1970 Triumph Bonneville (restoration project)
ian996 is offline
post #228 of 1180 (permalink) Old Mar 27th, 2015, 8:44 pm
hawkx2's Avatar
+1
Originally Posted by curveman99 View Post
so if you were to make and sell them how much would you ask?
Originally Posted by jaysinspaceman View Post
well i didn't really do it to the bike but i built it for the bike. I wanted a center stand type thing for maintenance and since i own a welding and fabrication business i thought i'd whip something up. I'll let the pictures talk...
anyway, it should make my upcoming valve adjustment easier and help with lubing chains, etc... It uses the through hole in the back of the cases to fix to the bike to the stand with a 3/8" pin so the bike is super secure and stable.
Thanx,
jaysin
John D.
'98 900 SS/CR
hawkx2 is offline
post #229 of 1180 (permalink) Old Mar 27th, 2015, 11:07 pm
Center stand price...
Well they would change very slightly to make them easier to fabricate and be made about 1/2" taller (right now the rear wheel is only about 1/4" off the floor). That said, I haven't totally worked up a price (because I just made this one for myself) but off the top of my head I could likely do them between $75 and $100 and maybe even knock that down a bit if I MIG weld them instead of TIG (I TIG a lot of my own stuff just to keep in practice). I really don't have a clue what bike stands go for (when I need something I just build it) so I might be way off base.
What would you be thinking as a good price break?
And if there are any rules about posting things like this for sale please let me know. I don't want to step on toes or break some forum rules.
Thanx,
Jaysin
JaysinSpaceman is offline
post #230 of 1180 (permalink) Old Apr 7th, 2015, 5:58 pm
TheLimey's Avatar
Images: 2
I've been working on my new dashboard.
Just mocking it up using Lexan at the moment,
the final one will be a nice tidy sheet of carbon fiber.
'94 900SS
Marchesini's, FCR's, Staintune, Ignitech
TheLimey is offline
My bike featured today at Ducati news today.com bulldog002 Superbikes 20 May 18th, 2015 12:36 am
Today is 11-12-13 Bill_Anderson Chit Chat 15 Nov 13th, 2013 7:50 am
Loyalty Program Kicks off Today! Get Double Points Today ONLY! desmoworks Southern California 2 Nov 16th, 2010 9:20 pm
Saw This Today! BimotaDB4 Bimota 1 May 17th, 2006 12:30 am
