Guzzidiag for mapping the 15M ECU and 5x? - Page 21 - Ducati.ms - The Ultimate Ducati Forum
post #201 of 206 (permalink) Old Mar 14th, 2019, 11:28 pm
darca916's Avatar
i have light switch on my S4 so i can turn off light. yesterday had to go change tires. i was trying to red map from ecu but no sucsess. maybe its cable.but the works fine with jpdiag. i understand everything else that you wrote. its wise to have a backup map for ecu
S4 Senna
darca916 is offline
post #202 of 206 (permalink) Old Mar 15th, 2019, 2:47 am Thread Starter
Excel Addict
Punch's Avatar
Check the site where you downloaded IAW Diag.
There are instructions for setting up and/or testing connection/connectivity.
A good thing to test is the Device manager for the Com Ports.
It will tell you what device you have.
Hopefully it is the FTDI 232 as this should function well.
If you have the Prolific Chip, something like CH431, which is reported to be common on eBay and Amazon etc. sites, then they can cause problems, which apparently can be solved by soldering a couple of connections in the adapter.
1. Open Control panel.
2. Select System and maintenance
3. Then Hardware and sound
4. Then Device manager
5. Then Ports (COM & LPT)
6. Find the one named USB Serial Port
Then go from there on finding what driver you have.
Good luck.
Richard Collins - 2001 900SSie I have a 2 strike policy - 2 no responses from a poster = no more responses from me to any post by them. I have a good memory!
Punch is offline
post #203 of 206 (permalink) Old Mar 18th, 2019, 11:47 am
darca916's Avatar
hey. this weekend i had a buyer for my bike. but i quit from selling. today i bought Cetralina orginal DP for my S4. so i dont need tu flash 🙂 many thanks for advices and help
S4 Senna
darca916 is offline
post #204 of 206 (permalink) Old Jun 21st, 2019, 5:24 am
johnnyjellybean's Avatar
Glad I found this thread.
Decided to keep my 2004 M1000sie and I'm thinking I want to do a little tinkering with the tuning. I have some experience with Guzzidiag with my Tuono so I'm not a total newbie. From what I've read , my bike should have the Marelli 5m. Can anyone confirm this? Also, is TunerPro the way to go? What options are there as a tuner program? Does Tunerpro allow for changes to such things as rev limiter etc?
Thanks in advance.
2004 Monster 1000Sie ,1995 Monster M900, 2013 Aprilia Tuono V4, 2007 Harley Street Bob 120 RWHP
johnnyjellybean is offline
post #205 of 206 (permalink) Old Jun 21st, 2019, 8:34 pm Thread Starter
Excel Addict
Punch's Avatar
Thanks in advance.
You will have a 5AM or 59M ECU. That will be on the label.
To use Tunerpro you will need an XDF for your bin file.
If you use IAW Reader to read the bin file, post it heee by adding .pdf to the bin file and I will have a look to see if any of the XDFs I have are suitable.
I like Tunerpro as it is simple to use. The other good thing is that if you use Excel to modify the fuel maps based on logged data, you can copy and paste the tables from Excel to Tunerpro.
Yorik likes this.
Punch is offline
post #206 of 206 (permalink) Old Jun 21st, 2019, 8:47 pm
Just visiting your planet.
Yorik's Avatar
I just looked it up in the manual. It's a Marelli 5.9M.
2005 ST3
2003 749s
Yorik is offline
Flashing ECU / mapping void warrnty? Howard the duc StreetFighter 11 Oct 15th, 2015 8:34 pm
ECU Mapping Issues - Speedo Won't Work Socaldiablo Sport Touring 11 Jul 25th, 2013 11:10 pm
ECU mapping problem robob Superbikes 4 Sep 17th, 2010 5:55 pm
15M ecu - help! dirkwrong Ducati Motorcycle Chat 7 Mar 28th, 2008 7:46 am
