996 showa into 800sport - Ducati.ms - The Ultimate Ducati Forum
post #1 of 9 (permalink) Old Mar 7th, 2006, 2:02 pm Thread Starter
anyone got suggustions. I just picked up from ebay a set of showa forks off a 996/998 with the aim of installing them on my 2005 800 sport which has basic suspension. however they top of the forks are 53mm and my yolks holes are 50mm. so this would require new top yolk & bars off a 996 etc. also the brake holes are 50mm apart and mine are 65mm apart so i need a set of calipers suitable. this is starting to get expensive.
so is there anyway to insert the internals of the showas into my folks which are marzzoci's (ignore spelling).
i spotted the forks last minute on ebay and got them for an excellent price. they are like brand new so its a shame to have to sell them.
Daren is offline
post #2 of 9 (permalink) Old Mar 7th, 2006, 7:18 pm
Are you sure the caliper spacing is 50mm? That would be very unusual. 40mm is more likley, and I believe somebody makes an adapter for the later 65mm caliper, though I couldn't say who right off the top of my head. As for the triples, I would say go for the cyclecat top clamp. Beyond georgeous. Although a lot of people have had success with having their top clamp milled out, and that costs about 1/10 as much. Dont even bother with the marzoccis.
supersparky750 is offline
post #3 of 9 (permalink) Old Mar 8th, 2006, 1:30 am
Chilehead
st2lemans's Avatar
Images: 115
996/998 forks are also 65mm, so they must be off an early 916/748, which are 40mm. You can buy adapters for the calipers, and bore out the top clamp.
Tom
st2lemans is offline
post #4 of 9 (permalink) Old Mar 9th, 2006, 9:06 pm
Have the upper clamp machined to fit the new forks, just get a shim the exact thickness of the gap in the upper. This helps the cutting tool make the transition over the gap easier.
Ducman851 is offline
post #5 of 9 (permalink) Old Mar 10th, 2006, 7:58 am
gorma900's Avatar
Here's what you need:
http://www.kaemna.de/cms_en/katalog....el&artikel=234
'04 Multistrada 1000DS
'97 900SS
'82 900SS
gorma900 is offline
post #6 of 9 (permalink) Old Mar 10th, 2006, 3:08 pm Thread Starter
Cheers for the advice & info and especially for that website gorma900, go to spend some money there. But i do not like the idea of adding plates between forks & brakes so i'll ebay them.
if i get 749 showa forks with both yolks and correct caliper spacing. i see that the yolks have the fixing for the steering damper does anyone know if this would foul the tank on the ss and if so can it be cut off.
Daren is offline
post #7 of 9 (permalink) Old Mar 10th, 2006, 6:38 pm
You may find that conversion even more expensive than the Superbike upgrade. You will need a wheel,axle and rotors as wele as the forks. The 749/999 rotors have a different offset than the rest of the Duc line save for some of the "R" Superbikes.
Also the steering stem may not be the same, nor the offset correct for the Sport.
The idea you had of putting the Superbike forks on your sport is a great upgrade. Using the caliper adapters is not an issue either. I know of several who have used them for years without issue. It would be far easier and less expensive to use what you have already and have the Sport Triples machined to fit the Supoerbike forks.
post #8 of 9 (permalink) Old Mar 12th, 2006, 1:16 pm Thread Starter
Thank ducman, saved me money.
I have just purchased a set of showas with 65mm spacing from a late model 996 and i'll get the yolk machined. I sure the adapters are fine but its something that would always bug me if i used them. the duc is a toy so i have to be happy.
thanks again for all you advice.
Daren is offline
post #9 of 9 (permalink) Old Mar 12th, 2006, 1:40 pm
No worries Daren. Thats what we are all here for. Id just hate to see someone else make the mistakes Ive made. Yes I thought about the 999 stuff but I got to looking at the differences between the two and the $$ started going through the roof.
