Lightweight Battery - Ducati.ms - The Ultimate Ducati Forum
post #1 of 5 (permalink) Old Jan 19th, 2006, 6:17 pm Thread Starter
Stopwatch's Avatar
Lightweight Battery
I've decided that it's time for a new battery for my '96ss/sp and have been researching the options. Does anyone have any experience with the Yuasa dry cell batteries?
http://www.yuasabatteries.com/yuasa0...=B175&vID=1701
This has the same cranking amps as the stock replacement (6A) but only weighs 4.6 (!) pounds. Other options I've found can weigh up to 15 pounds but have greater cranking capacity.
I could always go with the standard Yuasa because of the greater cranking power and not that big a hit in weight reduction.
http://www.yuasabatteries.com/yuasa0...cle_search.asp
Here's another place I've looked with good cross-reference info:
http://www.batteryweb.com/motorcycle...=Ducati&cc=900
Stopwatch is offline
post #2 of 5 (permalink) Old Jan 19th, 2006, 9:09 pm
Stick's Avatar
I guess it depends on your needs. If it's a track bike, you probably want the lighter battery. You can bump start the bike as needed.
I prefer the larger CCA #. I went up on my ST2 to a 22Ahr agm battery, and I know it has more CCA than the 16 Ahr wet cell that it replaced.
Stick is offline
post #3 of 5 (permalink) Old Jan 20th, 2006, 12:07 am
I've been using the Yuasa gel battery on my SS for the last three years. It saved about one pound over the stock battery and on an SS as a part of a general lightening project, this makes sense to me.
The ST is so much heavier than the SS (over 50#!) and is made for a different purpose, so it may not justify this setup.
rz33v4 is offline
post #4 of 5 (permalink) Old Mar 1st, 2006, 9:00 pm
BmwDuc's Avatar
Visit Digikey.com
You can get this Panasonic battery (Below) for 44.68.
From the web site you provided with battery lookup:
LC-X1220P Sealed MF 12 20 7.2 3.1 6.6 15 $84.95
According to LT Snyder, a perfect fit and sealed. Someone on his forum bought this for a 93 or 95 SS and it was just right.
BmwDuc is offline
post #5 of 5 (permalink) Old Mar 3rd, 2006, 12:07 am
Images: 30
I use the Yuasa YTZ7S on my 916SP, MV, Monster and SS. It weighs 4.6 pounds. 130CCA. It lasts for about 2 years. It helps to have heavy duty cables, headlight switch and good alternator brushes...
moto is offline
STM Evoluzione lightweight alloy clutch BlueST2 Apparel and Accessory Chat 8 Apr 24th, 2006 7:45 pm
What GPS do you recommend? montducati Sport Touring 38 Jan 31st, 2006 11:01 am
