Another Supersport track bike/resurrection Thread - Page 4 - Ducati.ms - The Ultimate Ducati Forum
LinkBack Thread Tools
Old Apr 16th, 2013, 12:42 am
Jeff_H's Avatar
I am loving this thread! Thanks for posting the great pictures.
Jeff
"Keep your blood clean, your body lean and your mind sharp." ~ Rollins
'98 944 CR
'05 1000 SS (Track)
Jeff_H is offline
Old Apr 16th, 2013, 9:33 pm
Wow! I wish I had the time to do this. Very nice.
800SSRider is offline
Old Apr 17th, 2013, 8:10 am Thread Starter
Thanks for the suggestions and kind words everyone, Hopefully I can get it done before my first track day of the year... Barber April 28th!!!! Just ordered some Ca-cycleworks coils and plug wires and have a lot of carb tuning to do.
2005 999s (BST's, carbon tank, Braketech rotors, titanium here and there)
1998 916 (carbon everything but the seat and tank, Arrow cans)
1995 900ss trackbike project (Full D&D spaghetti system, 39mm FCR's, mono seat)
jamesmorgan is offline
Old Apr 19th, 2013, 12:02 pm Thread Starter
She is now TRACK READY!!!
The paint went on well, although not without complications... Apparently Rustolium professional paint isn't compatible with Rustolium Gloss Enamel, had to repaint all of it after the paint developed a wrinkle finish 5 minutes after spraying all the pieces... Left the clear coat off this time, went with a good medium cutting compound from Mcguires that works well enough.
So here is the rundown:
Rebuilt valved and sprung 916 front end
999 Radial front brake master
998 clutch master
XRAC sintered front brake pads
Michelin power one competition compound tires
99+ rear shock (raised the ride height about an inch, suspension guy said its perfect)
Sharkskins front fairing without headlight cutout
Ca-cycleworks coils (yet to be installed)
39mm FCR's
5.5" rear wheel
underslung rear brake
New front and rear brake and clutch lines in blue
Woodcraft rear sets
Full Ohlins and possibly a 1000DS engine are in the works for next year
When I bought it 7 years ago:
After years of neglect and an inspiration to have a dedicated track bike:
Old Apr 19th, 2013, 12:06 pm Thread Starter
A few more:
I welcome any critiques, suggestions or maybe some good deals on extra parts you guys have laying around!
Old Apr 21st, 2013, 4:56 am
Big fun!
Looks great!
I'm impressed by the fit of those cans and how they get closer together at the back. Looks cool. Freakin' loud, I'll bet. BTW, still got those polished cans laying around?
I may have to install the red grips I've had for years.
Looks like you need a longer shift rod. Downshifts might be a problem.
Mike in Tacoma
"an analog man in a digital world"
'96 900 SS/SP
'08 S2r 1000 Monster
'02 ST4s (gone bye-bye)
'08 DR650 (she gets lonely sitting in the corner)
IBA 38181
sofadriver is offline
Old Apr 21st, 2013, 6:35 am
Subaru2.5rsti's Avatar
The fairings Look great! stupid question but why does your calipers need bracing support?
Subaru2.5rsti is offline
Old Apr 21st, 2013, 7:02 am Thread Starter
sofadriver: I do still have the chrome stain tune low mounts, the last time I heard them on the bike they had a bit of a rasp so I think they need rebuilt? Make me an offer if your interested... The shift rod on the bike is adjustable and everything works like butter, had to adjust the length to move the lever down a bit so its more comfortable with my track gear on though...
Subaru: If your referring to the rear brake... The OEM CR rear set up has the brake caliper isolated to the swing arm, with that setup when you applied the rear brake it actually forces the swing arm down changing the suspension geometry while braking.. with it braced on the engine via the locating rod it applies no forces to the swing arm and does not effect the bike when the rear brake is applied... Im not trail braking yet, but I assume this will make it easier.
Old Apr 21st, 2013, 8:34 am
Thumbs up Nice!
DUCATI 900SS 900 SS SP CR 1991-96, FAIRING, FAIRINGS, BODYWORK, FRONT, FENDER, REAR, HUGGER, TAIL, SEAT, TANK, WINDSCREEN, COWL, LOWER, UPPER, SUPERMONO, TWIN, BEVELHEAD, DESMO
James, you've done a very nice job! Just don't chuck her down on the track like I did right after the first time I painted mine ! Scroll down the link to "Turn signal covers." You might want to consider them. Easy to glass in and really cleans up the front. Pic attached.
Sofadriver, he has Woodcraft rearsets. Very comfy and good fit for normal size feet. He may have to raise the shift lever a little to make it easier to get his toe under it and more room underneath for upshifting while leaned over. I'd also recommend repositioning the arm on the gear shift shaft ("gearchange control lever") down a bit more so it has a better angle for downshifts.
P.S. Be careful not to spill any gas on your paint if you don't clear coat it. I had to go to a friend who does automotive clear coat because I found out that rattle can clear coat (Krylon) wasn't gasoline proof.
Name:	1997 SSSP track bike 003.JPG
Joe-B is offline
Old Apr 21st, 2013, 11:35 am
[QUOTE=Joe-B;2026865]
QUOTE]
yep. that's what I was referring to (just didn't know the proper name for it).
looks like it will need a longer rod to get the right geometry.
Mike in Tacoma
'96 900 SS/SP
IBA 38181
996 track bike vs. 1098 track bike. N.E S4 Superbikes 11 Aug 16th, 2012 1:44 am
resurrection of 98` ST truegrit Sport Touring 11 Feb 29th, 2012 12:56 pm
Another 999r resurrection thread Nove-R Superbikes 17 Mar 1st, 2010 6:41 pm
Audio/Video Thread for Supersport Slipons ducatiti Supersport 11 Jun 19th, 2007 10:43 pm
