99 and up 750 swingarm on a 95 Cr? - Ducati.ms - The Ultimate Ducati Forum
post #1 of 2 (permalink) Old Jan 14th, 2006, 3:35 pm Thread Starter
SamsonNg's Avatar
does anyone know if this would fit? or what type of mods i would need to do to get this in?
I'm trying to fit a 99 and up 750 swingarm on a 95 900ss cr.. Thanks!!!
SamsonNg is offline
post #2 of 2 (permalink) Old Jan 15th, 2006, 1:09 pm
blade625CT's Avatar
I'm not sure what benefit there is to doing it [other than to replace a damaged unit] but,
Yes. a '99 750SS swingarm should bolt up.
But, the '99-750ss has a steel swingarm, and I believe your '95 cr has a steel swingarm. I don't see a benefit here.
I swapped an aluminum swinger from a '95 SS/SP onto my '99 750SS. It was a simple, direct, bolt up. I just had to install the pin to hang the rear brake on.
I can't remember for sure, but I believe it shaved about three pounds.
Mark has another '95 SS/SP aluminum swinger for sale [that's where I got mine]: www.woundedduc.net
blade625CT is offline
The rubber thing on the swingarm? 96DucSSCR Supersport 2 Jan 10th, 2006 5:00 pm
