6-speed gear box in a 5-speed case - Ducati.ms - The Ultimate Ducati Forum
post #1 of 21 (permalink) Old Jan 5th, 2007, 10:10 pm Thread Starter
Would it be possible to convert the 750ss 5-speed gear box to a 6-speed gear box using the same case? We convert our racecars, but the tranny's are pretty different. Does the 900 use the same case as the 750?
whirlybird is offline
post #2 of 21 (permalink) Old Jan 6th, 2007, 2:09 am
gomura's Avatar
Images: 4
The 2003 Ducati Performance catalog shows a "complete six-ratio gearbox for small casing engines (5 gears)..." for SS/Sport 750 MY '98 and later. The description of the gears is limited and no ratios are provided. Maybe others on this list can chime in with more details...
=G=
'02 750 Sport
'02 SV650 Naked
'06 Triumph Speed Four
Time is an illusion... Lunchtime doubly so.
gomura is offline
post #3 of 21 (permalink) Old Jan 6th, 2007, 7:51 am
DukeDesmo's Avatar
Images: 197
I don't know about Ducati but I had a KTM 500, which was a 4-speed but a 5-speed conversion was available simply by buying and fitting the extra gears.
The same gearbox/shafts were used on both 4 & 5 gear models, I doubt Ducati make 2 different cases so would imagine it is a straightforward conversion?
916, M900 & Guzzi LeMans II
DukeDesmo is online now
post #4 of 21 (permalink) Old Jan 6th, 2007, 9:50 am
supersparky750's Avatar
The small case six speed, I belive originally found in the 400ss primarily imported to Japan, will fit straight in. So the tranny from any 800 or non-dark 620m, or even MTS620 will work (though I could be wrong, as the 620 has that funky "slipper" clutch and might have a different input shaft because of it). I assume the 695 will work as well. They do come up on ebay from time to time. For a complete breakdown on ducati gear ratios, go here- http://www.moto-one.com.au/performance/ducgearing.html. Brad Black really knows his stuff.
Andy
'99 750ss - dp high mounts, open air box, 996 forks(.85 springs and GP suspension valves),
Penske shock, 14-42 gearing, '02 alloy swingarm
And a whole pile of bits I may never have time to put on
supersparky750 is offline
post #5 of 21 (permalink) Old Jan 6th, 2007, 9:58 am
twpd's Avatar
As has been said. 6 into 5 does go. Quite a few of the lads in the DesmoDue race series in the UK do exactly this.
2 cylinders are all you need but 3 is a nice compromise
http://www.twpd.co.uk
http://www.twpdracing.com
racing blog
NGRRC 2007 Minitwins champion (800ss)
800ss road, 800ss race x2, 748RS
twpd is offline
post #6 of 21 (permalink) Old Jan 6th, 2007, 10:50 am
1fast750ss's Avatar
I have a small case 6 speed into my '01 750ss. A 6 speed from an 800ss will fit also.
Brian C.
'01 BCM 795SS / Track Toy
'03 999 w/50mm termi, S cams, BST wheels / daily commuter?
www.cittacorsa.com
1(888)763-4869
Whether it's the City or Track, it's Citta Corsa!
1fast750ss is offline
post #7 of 21 (permalink) Old Jan 6th, 2007, 11:37 am
call911mfc's Avatar
What effect has this had on the bike? From what I can gather, 5th has gone from an overdrive gear to a drive gear. With 1-3 being almost exactly the same ratios, does it just add to top speed or does it help in any other ways?
I looked at the site and numbers like that make me gloss at the eyes....guess that's why I sucked at math in college...
call911mfc is offline
post #8 of 21 (permalink) Old Jan 6th, 2007, 12:23 pm
twpd's Avatar
I think you'll find the biggest change is acceleration through the gears.
racing blog
twpd is offline
post #9 of 21 (permalink) Old Jan 6th, 2007, 12:25 pm
gomura's Avatar
Images: 4
If you look at the Gear Commander web site and compare the 750ss to the 800ss ratios, they are nearly identical through 4th gear. 5th on the 750ss is a little taller than 5th on the 800ss and 6th on the 800ss looks like an "overdrive". I'd think that you could increase the size of the rear sprocket several teeth to effectively "close up" the gear ratios of the first four gears while keeping 6th gear the same as the original 5th - does that make sense? Anyway, here is a link to the Gear Commander site if you want to check it out for yourself:
http://www.xs4all.nl/~ator0437/gc/
=G=
'02 750 Sport
'02 SV650 Naked
gomura is offline
post #10 of 21 (permalink) Old Jan 6th, 2007, 1:23 pm
twpd's Avatar
Yeah. The 6th on the 800 is a bit high although my tweaked 800 pulls it fine. I went to a 41t rear and this transformed the bike - it absolutely storms out of corners now.
I should think a 6-speed box combined with lower final drive ratio would really help the 750. However, it would just be easier and probably not much more expensive to go to an 800 and get a much much better engine.
racing blog
twpd is offline
Street Riding-"The Pace" zooom Hall of Wisdom 48 Nov 29th, 2011 6:47 pm
Speed / Gear / RPM demoni Supersport 10 Jun 15th, 2007 12:49 am
