Supersport Pictures - Let's See 'Em - Page 30 - Ducati.ms - The Ultimate Ducati Forum
post #291 of 3749 (permalink) Old Nov 17th, 2006, 12:07 pm
Chainlube's Avatar
I just installed my new Diopa solo seat from Kamna Ducati. The Vert. seat pad is attached by two snaps, and allows easy access to the under-seat storage . It only required minor adjustments to the mounting bracket for alignment purposes. I didn't like the screen material they sent for the vents, so I bought a very sturdy wire-mesh envelope holder from K-mart and made my own. I think I'll need to remove the tank pad for more....Rider clearance. Does anyone make a carbon fiber replacement for the stock tank pad? Is the stock tank pad attached by double sided tape only?
Dave
ID:	8023   Click image for larger version
ID:	8024   Click image for larger version
ID:	8025   Click image for larger version
ID:	8026   Click image for larger version
Just pin the damn throttle!
Chainlube is offline
post #292 of 3749 (permalink) Old Nov 17th, 2006, 1:46 pm
JDuc's Avatar
Images: 27
ooooooooo!!!!!!!
yippee!
I've been wanting to see more up close pictures of that tail...I've been putting off buying it for some time now.
I do have one question for you though.
How is the under tail room now?
Say when you remove your seat, and if you were to put the tail on a set of quick release bolts, or on hinges? Do you think that would be possible?
from what I know, the tank pad isn't something that you will want to remove. It's glued into place and there's a ridge under it.
There was a thread elsewhere in here about this very topic just a bit ago.
One solution is to get a different tank, they make some that are not only lighter, but hold more fuel as well.
https://www.ducati.ms/forums/showthread.php?t=12509
Jan
FOR SALE - 2002 900SS: Galfer Wave rotors + Carbon front fender + Ducati Performance levers & high mount carbon cans + Cycle Cat clip-ons & triple tree + Evoluzione Slave Cylinder + Motowheels Slipper Clutch + Power Commander w/ custom map + Air box mod & K&N + MBP Touring Wind Screen + Penske front fork rebuild
JDuc is offline
post #293 of 3749 (permalink) Old Nov 17th, 2006, 3:12 pm
Chainlube's Avatar
JDuc;
There is actually more room under the seat now because I'm not limited by the bottom of the stock seat. You can access it via the opening behind the vert seat pad. In hind sight, I should have opened that hole up just a little more to reach in a little easier (it gets a little tight when reaching in up near my elbow). You would not be able to put the seat on a hinge because it wraps around the subframe on both sides and needs to be rolled in either direction to rotate it off, but the seat is held on by only 3 bolts... one on each side and one through the access opening.
Dave
post #294 of 3749 (permalink) Old Nov 17th, 2006, 4:24 pm
just signed up, 1st post. One of my rides...
ID:	8028   Click image for larger version
1996900sp is offline
post #295 of 3749 (permalink) Old Nov 19th, 2006, 4:40 pm
RichieW's Avatar
Lovely!!!
Richie Worthington
Currently ride -
1998 900SS FE (No 257)
Have owned -
Yamaha FZR600R
Honda Bros 400
Kawasaki KE100
RichieW is offline
post #296 of 3749 (permalink) Old Nov 19th, 2006, 6:58 pm
Smile 1990 750 Sport
My baby after a little refreshining.
Name:	90 Ducati 750.JPG
ID:	8096   Click image for larger version
Name:	90 Ducati 750.3.JPG
yellerduck is offline
post #297 of 3749 (permalink) Old Nov 23rd, 2006, 12:24 am
John's Avatar
Images: 15
Sweet!
Present:08 1800 Goldwing,03 999R#189,Past:03 FLHRI Road King, 09 1125CR Buell, 07 1100S MTS, 04 999S, 95 916, 01 900SS, 05 600RR, 05 600RR totalled, 66 650 BSA, 68 Honda DOHC
Ducati-Owners-Group of Sacramento region.
John is offline
post #298 of 3749 (permalink) Old Nov 25th, 2006, 9:01 pm
DucatiNoz's Avatar
Here's my new baby, after a Ducati dry spell of about 5yrs (new family). Picked her up yesterday.
She's a 1998 900SSie with only 17,000klm, absolutely schmicko...
Cheers
Name:	1998 900SS ie.jpg
Mine 1998 900SSie, Honda CB250N Cafe Racer
Missus 2002 SV650S
The older I get the better I was
DucatiNoz is offline
post #299 of 3749 (permalink) Old Nov 26th, 2006, 1:14 am
96ssportsp's Avatar
96 Ss/sp
Here are a few pics of my 96 SS/SP. Touring and general day riding. Currently 47,000 miles and running great. Ride safe, Scott.
Name:	Laguna Seca 06 047.jpg
ID:	8454   Click image for larger version
ID:	8455   Click image for larger version
Name:	Laguna Seca 06 044.jpg
ID:	8456   Click image for larger version
Name:	Sat 5-6-06.jpg
ID:	8457   Click image for larger version
Name:	Bike Night 027.jpg
96ssportsp is offline
post #300 of 3749 (permalink) Old Nov 26th, 2006, 3:58 am
galaxy's Avatar
Images: 27
Originally Posted by 96ssportsp
Currently 47,000 miles and running great..
A-MEN That's friggin awesome!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
www.ducati-owners-group.com
galaxy is offline
