$2000 to spend - Page 2 - Ducati.ms - The Ultimate Ducati Forum
post #11 of 23 (permalink) Old Oct 7th, 2011, 4:38 pm
Retired Pipe Polisher C2H6O+
DuckMan's Avatar
Tires and gas. Lots of tires.
Mike
2006 999, 2007 S2R1000
DuckMan is offline
post #12 of 23 (permalink) Old Oct 7th, 2011, 5:10 pm
The days are getting longer!
va duc's Avatar
Images: 12
This, keep the money for future trips and tires, enjoy!
AMA Member
1998 Silver ST2$
Motto Guzzi G2 Moped
va duc is offline
post #13 of 23 (permalink) Old Oct 7th, 2011, 5:29 pm
VTGPDUC's Avatar
Front suspension first then wheels, Carrozzeria.
2006 749S (resurrected)
1995 900SSSP/track bike
2001 750SS/"rain bike"
1975 CB400F/Yoshima
1996 CR250R
2005 CR85R (for sale, still)
1971 Bultaco-project
2000 Z50R
VTGPDUC is offline
post #14 of 23 (permalink) Old Oct 7th, 2011, 5:33 pm Thread Starter
Spitfire's Avatar
That's an awful lotta votes for wheels....wow. Any input on heated grips? My hands get cold Below 50F no matter the gloves.
Spitfire is offline
post #15 of 23 (permalink) Old Oct 7th, 2011, 5:38 pm
VTGPDUC's Avatar
FCR's, lightend crank and head work will put you way over $2000. Unless you are doing it all yourself. I'll sell you my stage II Mikunis for $200 plus shipping. Don't split your cases unless your crank plug is bad.
1975 CB400F/Yoshima
1996 CR250R
2000 Z50R
VTGPDUC is offline
post #16 of 23 (permalink) Old Oct 7th, 2011, 8:32 pm Thread Starter
Spitfire's Avatar
Thanks guys!
I'm thinking of making slight improvements in
1 seeing behind me
2 being able to stop better
3 being more comfy
I could just save and buy some wheels (more than $2k) and do some suspension work
I could save and go FCR/944/crankwork. ( I know it's super expensive)
I hear FCRs REALLY make a HUGE difference in rideability.
Spitfire is offline
post #17 of 23 (permalink) Old Oct 8th, 2011, 3:14 pm
Images: 30
Originally Posted by Spitfire View Post
Thanks guys!
1 seeing behind me
3 being more comfy
(1) SEEING Behind you:
I use the little CRG Blindsight Mirror they are small and hardly noticeable--but I can pick out cops behind me no problem
(2) The sky's the limit on BRAKE mods--just like engine mods. However good pads like the FERODO "ST" Sintered Brake Pads: 1 Pin go a long way. I swapped out the master cylinders with BREMBO GP Forged Radial Brake Master Cylinder. These gave me a nice easy progressive 2 finger pull.
If I was to do it again, I would get the BREMBO "RCS" Forged Radial Brake Master Cylinder . It has folding levers, an adjustable lever ratio, integrated brake microswitch and an available matching clutch master cylinder.
I installed BREMBO 7850 Series "4 Pad" Cast Caliper: 65mm Axial and a ABM iron rotors. If I was going to do it again, I'd use the thinner BRAKETECH "AXIS" Iron Front Rotor for less rolling restance. The brakes are incredible though. They are better than the original brakes on my 999R.
(2) COMFORT: I've used the SARGENT "World Sport" Seat: 750/900 SS/CR '91-98 on my other bikes. They are wellmade, light and very comfortable for most people.
I installed adjustable bar risers by Cycle Cat on my SS. They are no longer made but be making a comeback.
moto is offline
post #18 of 23 (permalink) Old Oct 8th, 2011, 3:15 pm
Images: 30
I did the motor last because I wanted to have good brakes, suspension, light wheels and all the other mods on the bike before I built up the motor. The SS FE motor has dual plug heads, FCRs, cams, hi-comp 944 pistons...It is a lot of fun but I like it a lot more because of all the supporting mods.
I ended up adding a steering damper to the otherwise very stable bike because the front wheel can get very light...
moto is offline
post #19 of 23 (permalink) Old Oct 8th, 2011, 4:43 pm Thread Starter
Spitfire's Avatar
NICE!!
I like the 1 inchers.
I also like that Header....really nice. I bet that goes well with the motor work.
I'll get to brake masters and pads when necessary.
If anyone has a bead on period-correct light Marvic 2 piece wheels, let me know!!
I'm trying to keep the mid 90s look close.
Spitfire is offline
post #20 of 23 (permalink) Old Oct 8th, 2011, 5:23 pm
barnapkin's Avatar
1) Brake lines and fresh pads. Safety first!
2) Seat. Doesn't matter if you make it the fastest 900SS ever. If you aren't cumfy, you won't like it or want to ride it.
3) Dyna coils. It will improve your starting.
4) suspension. Race tech valves and springs for the forks. Keep an eye on eBay for a shock.
5) Take a riding school !!!!!
6) Wheels. It will really improve the handling.
7) Then engine stuff.
'03 Moto Guzzi V11 Lemans
'98 900 FE (#46)
'97 750M (904cc)
'93 900SS (track bike)
barnapkin is offline
Help spend my money -- 848 LittleDucker Superbikes 8 Oct 1st, 2010 8:41 pm
How not to spend a day riding DavidTaylor HyperMotard 44 Jun 27th, 2010 2:15 am
help! what's the best way to spend $2k on a stock gt? ducatidoc Sport Classic 28 Aug 27th, 2009 10:20 am
What to Spend 5kAU on anzac1967 Sport Classic 15 Aug 17th, 2009 7:00 pm
So I have money to spend......but on what? Movi Superbikes 28 Mar 5th, 2007 2:20 pm
