1989/90 900SS dry clutch issues - Ducati.ms - The Ultimate Ducati Forum
post #1 of 2 (permalink) Old Oct 11th, 2006, 6:15 am Thread Starter
fester's Avatar
Guys I have recently purchased a 1989 build date/sold 1990, 900SS. As I am starting to find out there does not seem to be much in teh way of workshop manual information for this vintage.
Firstly I was wondering if the clutch actuation set up can be changed to that of the later bikes. Mine has the slave mounted on the clutch cover housing on the right side whereas the later bikes have it on the left. Is it possible to change it over to the later set up which I have heard is a smoother set up.
If this is not possible the other thing I want to do is ventilate the cover. I know I can easily get a mate to mill some holes or slots in it but I believe the factory race bikes of the era had a certain pattern milled into their covers. Anyone know where I can get a copy or photo of that pattern to keep some form of "originality' for want of a better word.
fester is offline
post #2 of 2 (permalink) Old Aug 11th, 2012, 5:41 am
Kiwihame's Avatar
Images: 17
Fester, I'm sure you've well solved these issues, but to offer an answer for those who may have the same questions:
1) Yes, you can convert to the later arrangement. Ive done so. You'll need a new clutch side engine cover to do so, and the later basket and hub (now alloy) and a push rod, etc.
2) Yes, you can also ventilate the early covers. The racing 851s had the best examples of factory ventilated covers. Pic 1 is a pic I found, looks great but factory? Dunno. Pic 2 is mine. Slightly ventilated.
Hope this helps. See my bike now; thread is: 1989 900ss Performance rebuild. (or something like that)
Cheers
Name:	Clutch cover Ducati MS1.JPG
ID:	115951   Click image for larger version
Name:	Clutch Cover 1.jpg
Hamish, ex Britten Motorcycle Company
'89 900SS now Superdue: '95 cases, close ratio box, XX9R Ohlins R&T front end, Monoblocs, Speedymoto Upper Triple, Apex Clip-ons, 5 spoke Marchesinis, Bespoke discs, Hel Lines, Carbon/Composite tank with c/f filler, carbon Supermono fairing, dual projector beam headlights, billet rearsets, carbon 955 Corsa tail, 944cc, Lightweight flywheel/Barnett clutch, Aluminium Plates, DP Cams, ported heads, 41mm split FCRs with 90mm CNC velocity stacks, 45mm Spaghetti pipes with carbon cans, Ignitech, Dyna Coils, Magnecor wires, Ohlins shock, 1000DS swingarm. Lots of Carbon and Titanium. EVERYTHING else is custom. Just about finished...
Plus
'95 900SS/SP: Bought May '11.
07 Aprilia Tuono: Sold. '06 GSX-R1000: Full Ohlins: Sold. (written off same day by MadMartin!) '03 Monster 620ie: Sold. '00 Aprilia Mille R: Sold. (Gone but not forgotten) Several 750 Pasos, ZZR-1100, VFR750 and other small Hondas etc
Kiwihame is offline
Clutch Hub Question '93 900ss TheToeCutter Supersport 5 Dec 16th, 2006 4:06 am
Buyers Beware www.motorcyclestyle.com! Dark_Daddy Apparel and Accessory Chat 10 Oct 5th, 2006 1:43 pm
Clutch issues on a '99 748 DrGonzo Superbikes 7 Apr 19th, 2006 4:54 pm
clutch swap 95 900ss duckgirlygirl Supersport 3 Mar 30th, 2006 6:12 pm
