Approximate life of a testastretta race engine - Page 3 - Ducati.ms - The Ultimate Ducati Forum
post #21 of 33 (permalink) Old Feb 10th, 2010, 10:54 am
Originally Posted by JohnMH View Post
My bad. A 66mm crank makes for 1120cc not 1180.
Still, in a 999R Fila streetbike it made a 21 hp difference:
http://www.ferracci.com/custombikes/.../fila-dyno.gif
My hp figure is a bit north of the 1120 Fila bike right now and the law of diminishing returns suggests I may get less than 21 hp, but I like the 9500 rpm power peak.
Take into consideration the piston speed for both engines at max RPM...
1020R 66mm stroke @9500 rpm = 4114 FPM
999R 58.8mm stroke @10500 = 4051 FPM
http://www.csgnetwork.com/pistonspeedcalc.html
-MATT
Bella749 is offline
post #22 of 33 (permalink) Old Feb 10th, 2010, 11:57 am
Banned
Images: 15
The 1198R @ 11000 RPM = 4900 FPM
The 999RS @ 13000 RPM (which is what you'd need to run it at to produce the same power) = 5416 FPM
Those are slightly more realistic numbers for 1098R power vs 999RS power at a given RPM. So roughly 500fpm difference in piston speed between the two and the 1198R will probably produce more power at 11000 RPM if tuned to the level of the 999RS.
Compare the Ducati corse numbers;
The 1198F10 @ 12,000 RPM = 5000 FPM (110+ lb torq and 197 rwhp)
The 999F07 @ 14,000 RPM = 5833 FPM (98lb torq and 194 rwhp)
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
tye1138 is offline
post #23 of 33 (permalink) Old Feb 10th, 2010, 12:44 pm Thread Starter
With the stock stroke at 11,500 rpm piston speed is 4437 fpm.
With the 66mm stroke at 9500 it drops to 4114. The question is how do I know how many rpm I need to hit a certain level of horsepower? Can I get similar hp with a longer stroke, more displacement and less rpm?
Cool website btw.
JohnMH is offline
post #24 of 33 (permalink) Old Feb 10th, 2010, 1:02 pm Thread Starter
Split liner, as expected. Nasty.
Name:	liner crack comp.JPG
JohnMH is offline
post #25 of 33 (permalink) Old Feb 10th, 2010, 1:18 pm
Banned
Images: 15
Ohh, that sucks!
tye1138 is offline
post #26 of 33 (permalink) Old Feb 11th, 2010, 6:30 am
Le Français's Avatar
Originally Posted by 955SP View Post
So what would the estimate be for a 999s 150 rwbhp engine?
To get 150 rwhp with a 998s/999s engine : the easy way is the use a big bore kit with 102mm pistal piston (1038cc).
Look this dyno curve (same bench) rear wheel power :
run file 006 : 1038cc + 54mm full exhaust
run file 022 : 1038cc + 57mm full exhaust + cylinder head work
and soon : 1038cc + 60mm full exhaust + 58mm throttle bodies with 12 holes injectors ( 5 bars fuel pressure ) + oversized airbox.
i have seen a 999R engine in 1078cc + cylinder head work, 57mm full exhaust and 58mm TB at 175 rwhp... But unfortunaly the owner don't give me the curve.
Panigale Stocksport race bike
Le Français is offline
post #27 of 33 (permalink) Old Feb 11th, 2010, 9:29 am Thread Starter
The 999R has a 104mm piston, but the Ducati recommended cylinder replacement interval for racing is 900km.
On the good side of the ledger, the engine is now completely apart, aside from some chroming loss on some shifter dogs the internals are pristine. New bearings and away we go! I guess 11,500 seems to be a good rev limit. I have lots of pictures, will try to post them later.
I am getting a RS alternator and new RS left side engine case installed. Major weight reduction for the flywheel and alternator weight.
This perhaps ought to be the subject of another post, but has anyone ever tried to install stock 999R throttle bodies inside a real RS airbox (the one with the gas tank which acts as a cover for the airbox). Am considering the next step as it looks like the bike may race again. The issue seems to be shape of the base of the TB and the height of the injectors (maybe not an issue as the RS ones are tall).
I am so happy that the bike may make it to the next race.
JohnMH is offline
post #28 of 33 (permalink) Old Feb 11th, 2010, 12:20 pm
Banned
Images: 15
How are you gonna fix that bore? Can you buy another one easily?
tye1138 is offline
post #29 of 33 (permalink) Old Feb 11th, 2010, 12:43 pm Thread Starter
Nothing a new $1400 cylinder wont fix. The first quote to fix the engine was $20k. Gulp.
Crank journal and piston from horizontal cylinder look ok:
ID:	62825   Click image for larger version
JohnMH is offline
post #30 of 33 (permalink) Old Feb 11th, 2010, 1:51 pm
Drat's Avatar
the R cylinders are closer to 3k US moneys... whats this 1400 you speak of? me likey...
2011 Sponsors
www.Speedymoto.com, Cheshire Motorsports, KFG racing/GP Suspension North,
Hilt, Bonfire Lounge
Drat is offline
Air Filters - Stock vs Aftermarket, and Airbox Resonance JEC Hall of Wisdom 12 Jun 12th, 2018 1:52 am
Lightweight Flywheel - Pros and Cons Shazaam Hall of Wisdom 30 Dec 13th, 2010 9:24 am
Engine Ice mbohn Superbikes 19 Apr 8th, 2007 1:53 pm
748 engine life expectancy? hwang8 Superbikes 4 Nov 25th, 2006 10:01 pm
NEW!!! 1098 Specs Info and New Pics!!!!!!! Harry Superbikes 54 Nov 10th, 2006 11:15 am
