998 won't start if I wait after turning on ignition - Ducati.ms - The Ultimate Ducati Forum
post #1 of 11 (permalink) Old Jul 22nd, 2019, 9:44 am Thread Starter
Lelebebbel's Avatar
Is this some sort of leak in the fuel system or is it normal? It starts every time, if I crank right after it finishes priming. If I wait 20 seconds, it cranks but doesn't start. I turn the key off and on again, it primes again, and then it starts.
Battery is good, and I have big fat starter cables etc.
- 2002 998
- 1994 900SS-CR
Lelebebbel is offline
post #2 of 11 (permalink) Old Jul 22nd, 2019, 10:08 am
blitzboy54's Avatar
Check your clutch basket. If it's already open great if not take the cover off. Put the bike in the condition where it won't start. Watch the basket turn went he engine turns over. If it doesn't rotate smoothly or at the same rate as the crank you have a starter clutch on it's way out.
2005 Ducati SR4
Upstate NY
blitzboy54 is offline
post #3 of 11 (permalink) Old Jul 22nd, 2019, 10:18 am
Sherpa23F's Avatar
That's normal on my 998R. The ECU times out after a certain time interval (I think it's 15 seconds) and won't put fuel in when the bike is cranking. Turn off the key and turn back on and it should be good to go.
It doesn't have any kind of leak and it has always done it.
Tripod and ProphetPVD like this.
1996 900 SS/SP #C22, 1996 916 Corsa (ex-Ferracci), 1998 916 SPS #774, 1999 748R (race), 2001 996R (US), 2001 996R (Euro), 2002 998R #481, 2011 848 EVO (race), 2008 1098R #262, 2014 1199 Superleggera #213
Sherpa23F is offline
post #4 of 11 (permalink) Old Jul 22nd, 2019, 10:37 am
Strega's Avatar
Originally Posted by Lelebebbel View Post
Is this some sort of leak in the fuel systeml?.
Likely. When you turn the key the ECU turns on the fuel pump to build pressure in the system, then turns off. It then waits for a signal from the crank rotation sensor that tells the ECU that the engine is running and to turn the pump back on.
If you have a leak in a fuel line (most likely inside the tank) you'll depressurize the system quickly and without fuel pressure it won't start. Replace the fuel lines with Gates or NAPA submersible hose or hose that exceeds the SAE 30R10 specification for submersible fuel line hose.
Strega is offline
post #5 of 11 (permalink) Old Jul 22nd, 2019, 1:30 pm Thread Starter
Lelebebbel's Avatar
I'm getting some mixed signals here.. the fact that the fuel pump re-primes makes me think that the system maybe does lose pressure though. So time to open the tank before something fails? Any other 998 owners that can confirm this isn't a normal behavior?
It doesn't have anything to do with the starter or sprag. The engine turns over just fine, it just doesn't fire unless I turned the ignition on within 10 seconds or so of starting.
- 2002 998
- 1994 900SS-CR
post #6 of 11 (permalink) Old Jul 22nd, 2019, 2:56 pm
Strega's Avatar
Open the tank and check if you can see ripples on the fuel surface when the pump primes a good indication of a hose split or connection leak. Fuel line splits in the tank on early 9xx series bikes is not uncommon.
Name:	Picture 2019-07-22 at 3.56.05 PM.jpg
Strega is offline
post #7 of 11 (permalink) Old Jul 22nd, 2019, 4:06 pm
i'd check the fuel pressure and see if it has enough, if it maintains the pressure and what it does when you crank it after having the key on. i thought they won't even crank if you go past the 15 seconds, but i don't recall now.
know all wanker
belter is online now
post #8 of 11 (permalink) Old Jul 22nd, 2019, 5:21 pm
SS904's Avatar
As someone already said, it times out. My ST4s does it too after 15 or 20 seconds, same ECU. The older 1.6M bikes don't do it. Cycle the key off then on. If there was a fuel leak causing pressure to drop, I'd think it would show when running too.
Tripod and Nikk11 like this.
Dan. "Painfully mistaking my big talk for the truth" Samantha Fish.
2003 ST4s (The Truck)
1995 916 (Junk Yard Dog)
SS904 is offline
post #9 of 11 (permalink) Old Jul 22nd, 2019, 5:55 pm
Strega's Avatar
Yup, I'm wrong. Owners Manual.
Name:	Picture 2019-07-22 at 6.53.48 PM.jpg
Strega is offline
post #10 of 11 (permalink) Old Jul 23rd, 2019, 8:48 pm
i checked a 998 i had in yesterday. cranks, but won't fire if left for more than 15 seconds.
know all wanker
