best brembo rcs master(s) for 916 track bike? - Ducati.ms - The Ultimate Ducati Forum
  • 1 Post By nine16
post #1 of 6 (permalink) Old Yesterday, 12:19 pm Thread Starter
I want to upgrade the controls on the 916 and was curious what others have used. I have a 98' 916 for track use only with 65mm 4 pad brembo calipers for brakes and an aftermarket clutch slave cylinder (EVR i think).
Im currently using a stock clutch master cylinder and a 999 style brake master cylinder. They do the job well enough, but I would like better feedback and reliability.
For the brake MC, Im considering either the brembo RCS 17 or 19. I can't find any info on what size would work best on the track with my 4 bad brembo calipers.
For the clutch, id like to stick with brembo RCS, so my options are RCS 16 and 19?
Im considering these because of the rave reviews the RCS M/C's have and they seem to be at the top of what I consider a "budget" m/c.
Opinions?
2005 999s (BST's, carbon tank, Braketech rotors, titanium here and there)
1998 916 (carbon everything but the seat and tank, Arrow cans)
1995 900ss trackbike project (Full D&D spaghetti system, 39mm FCR's, mono seat)
jamesmorgan is offline
post #2 of 6 (permalink) Old Yesterday, 1:54 pm
Strega's Avatar
For the clutch MC, use a Brembo RCS 16 with either an EVR 29 mm or 30 mm slave cylinder.
Assuming your 4-pad calipers are 34/34 mm pistons, use a Brembo RCS 19 MC — a RCS 17 will have too soft a feel at the lever. The RCS 19 will give you a better feel at the lever than your 18 mm 999 MC.
Strega is online now
post #3 of 6 (permalink) Old Yesterday, 3:29 pm
Neither... Beringer. Kills brembo and I have had them all...
2015 Panigale 1299s, 2011 848evo (race bike), 2010 MV F4 (track toy), 2010 Mv Brutale 1090RR, 2007 S4RS (all custom)
ducatista01 is offline
post #4 of 6 (permalink) Old Yesterday, 7:48 pm
Namor's Avatar
Thanks for the tip. 21mm?
97 916/996 "The Time Machine"
Namor is offline
post #5 of 6 (permalink) Old Today, 1:19 pm Thread Starter
But at around $600 each, they are a little out of my budget for what Iím doing.
post #6 of 6 (permalink) Old Today, 4:08 pm
Mayor of Simpleton
nine16's Avatar
Images: 2
You've basically zeroed in on the best "bang for the buck" combination. RCS 16 clutch/19 brake, Brembo 4 pad calipers. Yes, there are improvements to be had, but with greatly diminishing returns for the money spent.
One other thing--there's a natural tendency when evaluating brakes, and especially tires. The new combination will feel like a bigger improvement than it actually is because in addition to whatever calipers/masters you've just replaced, you almost surely have fresh fluid/pads and there is no longer garbage caked around the pistons or air and moisture in the system. In the case of tires, the rubber isn't heat-cycled or hardened and the profile is nice and round instead of flattened by everyday use.
Namor likes this.
'01 996R, 851 Adamo/Leoni racebike, '97 900 SS CR, '91 ZX-7R K1 homologation, '89 NSR250 MC18r5k, '01 Derbi GPR50/75,
nine16 is online now
