996 SSR Kickstand seems too long - Ducati.ms - The Ultimate Ducati Forum
post #1 of 28 (permalink) Old May 20th, 2019, 12:52 pm Thread Starter
C!ph3r's Avatar
Hey guys. I wanted a longer kickstand because we all know the gangsta lean on the 996 is pretty extreme. Well some of us do and I am one of those that do.
So a wonderful person donated a SSR billet kickstand to me in my search for a 1098 kickstand and I couldnt be more grateful.
The issue I have now is it seems too long. On the stock kickstand it could be scary at times how far it leaned. Now, it seems too upright. I have attached a pic in my garage. This doesnt do it justice how upright it is. My garage is of course very flat and level. But, when I park in the drive way or with the slightest incline in a parking lot I almost feel its going to tip over the other direction.
In fact, when putting up the kickstand I have had to actually lean it to the right for it to fold up.
Now, SSR says to adjust the rear ride height slightly to get more lean according to the instructions on their site. Anyone done this? I have never adjusted suspension on any of my bikes and worry about the negative impacts from raising the rear height.
Here are the instructions from SSR.
10) Test to see how much the bike is leaning over on the kickstand. If the bike does NOT lean over enough with the billet kickstand, loosen the locknuts on the rear suspension control rod and make it longer. That will raise the back end of the bike and increase how much the bike leans over. Raising the back end a little will have NO detrimental effects in terms of handling. As a matter of fact, it will quicken steering and most owners will find the bike easier to haul through turns.
Check out my Instagram for my various hobbies.
Hobby ADD
C!ph3r is offline
post #2 of 28 (permalink) Old May 20th, 2019, 1:09 pm
Buhgaboo's Avatar
Adjusting the geometry for a kickstand...lol... take it to a weld/fabrication shop
Buhgaboo is online now
post #3 of 28 (permalink) Old May 20th, 2019, 7:28 pm Thread Starter
C!ph3r's Avatar
That was my thought. Didnt seem like the logical thing to do. But I know a lot of people are using them on the 916 era bikes. Hopefully someone that has used one can offer some insight. Maybe it isnt too high and Im just not used to how upright it is.
Hobby ADD
C!ph3r is offline
post #4 of 28 (permalink) Old May 21st, 2019, 12:21 am
Namor's Avatar
I'll trade you whatever you have for my OEM. With my setup the out most point of the kickstand is all that touches the ground. The Time Machine leans way over. This is a result of geometry setup to be how I like it. And for the most part, if you have to raise the rear ride height or rotate the eccentric to get the bike to lean more, it's not a big deal. If you aren't at the track that stuff doesn't matter and you will likely like the change.
paulmm600 and nine16 like this.
97 916/996 "The Time Machine"
Namor is offline
post #5 of 28 (permalink) Old May 21st, 2019, 2:35 am
Nikk11's Avatar
Lean angle seems about right .
Im running a genuine 1098 leg on the 996 mounting plate , whilst sitting on the bike I have to lean slightly to the right sothat the stand clears the ground ,, its never fallen over & Ive never worried about it doing so ,, but I would constantly worry about it doing so with the stock 996 leg.
spinoli1 likes this.
2000 996
The best views are seen from within a motorcycle helmet
Nikk11 is offline
post #6 of 28 (permalink) Old May 21st, 2019, 4:21 am Thread Starter
C!ph3r's Avatar
Interesting. I’m still very much in the air on if I’ll ever track it or not. And I still have my stock kickstand but thanks for the offer.
I’m running a genuine 1098 leg on the 996 mounting plate , whilst sitting on the bike I have to lean slightly to the right sothat the stand clears the ground ,, it’s never fallen over & I’ve never worried about it doing so ,, but I would constantly worry about it doing so with the stock 996 leg
Wow thanks for that pic. Good stuff. Looks like it’s spot on. I’ll run this way for a bit and see if I get used to it or if things get to sketchy.
In the meantime I think I’ll look into finding a block of scrap aluminum or delrin plastic and make a “shoe” for the stock stand.
Hobby ADD
C!ph3r is offline
post #7 of 28 (permalink) Old May 21st, 2019, 6:10 am
Come in Spinner :)
davy.j's Avatar
Images: 146
Don't muck around, just take it to a shop where they weld alloy... boat builder for example and get it cut to the length you need and put a nice big flat plate on the end so it can stand on soft ground (or tar)
2000 853
2007 Cagiva Mito.
1980 and 1978 Ultra lightweight Yamaha SR500 Cafe Racers
1967 500cc Ultra lightweight Triumph Daytona Cafe Racer
davy.j is offline
post #8 of 28 (permalink) Old May 21st, 2019, 8:22 am
Mayor of Simpleton
nine16's Avatar
Images: 2
Three choices;
1. Live with whichever stand is closer
2. Adjust the ride height
3. Custom fabrication
I have the longer billet stand. I didn't need to increase ride height just for that purpose--that's where I already had it and in my opinion these bikes like it anyway. Why not adjust the rod, ride it, and see what you think? If you don't like it, lower it and figure out which stand to go with.
'01 996R, 851 Adamo/Leoni racebike, '97 900 SS CR, '91 ZX-7R K1 homologation, '89 NSR250 MC18r5k, '01 Derbi GPR50/75,
nine16 is online now
post #9 of 28 (permalink) Old May 21st, 2019, 10:29 am
Namor's Avatar
Typically it is a higher lean angle, but I am playing with the geometry.
Namor is offline
post #10 of 28 (permalink) Old May 21st, 2019, 12:13 pm
wetzel's Avatar
Jeez, I thought my 916 had a damaged kickstand or something, it leans over so far.
wetzel is offline
FS: Fairings for 900SS, 996R, 996, and 851/888 nine16 Parts and Accessories 2 May 8th, 2018 1:56 pm
996 OEM exhaust parts problems Sitting Duc Superbikes 5 Mar 13th, 2018 5:18 pm
My 996 sat too long and won't start Cal996 Superbikes 10 May 24th, 2017 11:25 pm
996 setup for poor man's long swingarm? timwu12 Superbikes 12 Dec 18th, 2016 2:51 pm
FS: ECU's, Eproms & Power Commanders - 996 748 916 998 749 999 GT1000 tom.i Parts and Accessories 9 Oct 9th, 2016 11:35 am
