Need help, Ducati Corse slipper clutch in 1997 916 - Ducati.ms - The Ultimate Ducati Forum
post #1 of 16 (permalink) Old May 19th, 2019, 11:06 am Thread Starter
wetzel's Avatar
I've been restoring this 916 for the last half a year or so (see other thread) and finally have it running well. First time I went to try riding it the clutch just kind if didn't work.
I took it back into the garage and noticed that the top friction plate had slipped above the basket and gotten lodged...
I'd put more stack height in, but I'm also at the point where when the clutch is engaged, the top friction plate is at the very top of the basket... what???
I'm not sure what to do, or if I'm doing something totally wrong. Here is a video I took. You can see the clutch engagement looks fine if I only slightly depress the clutch, but if I fully open it, the pressure plate moves far enough out that the friction plate can become free. (and they often do).
https://youtu.be/VUYFSy0mfcM
wetzel is offline
post #2 of 16 (permalink) Old May 19th, 2019, 11:50 am
Moderator
jusutus's Avatar
Is that the ball bearing or ramp type slipper?
999S '06 "Isabella"
jusutus is offline
post #3 of 16 (permalink) Old May 19th, 2019, 12:36 pm Thread Starter
wetzel's Avatar
Ramp type. I heard the duca bike ramp type is exactly the same as this, not sure how correct that is.
wetzel is offline
post #4 of 16 (permalink) Old May 19th, 2019, 12:46 pm
Have you measured the stack height? Made sure the order of the plates is correct? Seems like for ďmostĒ slippers, the number is 36.5mm for the stack height. Looks like you have an extra plate somewhere in the stack. On the slippers Iíve installed (kbike), the last plate is never a friction plate but just a plain steel.
Here are pics showing the 7 and 8 friction plate setup/order of plates
ID:	943519   Click image for larger version
jsedacca is offline
post #5 of 16 (permalink) Old May 19th, 2019, 12:49 pm Thread Starter
wetzel's Avatar
Originally Posted by jsedacca View Post
Have you measured the stack height? Made sure the order of the plates is correct? Seems like for “most” slippers, the number is 36.5mm for the stack height. Looks like you have an extra plate somewhere in the stack. On the slippers I’ve installed (kbike), the last plate is never a friction plate but just a plain steel.
It's about 38mm right now, and yeah it seems like I should run a lower stack height, but if I lower it, the pressure plate doesn't come into contact with the stack. And as it is now, if I open the clutch, the friction plates can jiggle out of the basket... I could try putting a couple extra steels on the outside...?
wetzel is offline
post #6 of 16 (permalink) Old May 19th, 2019, 12:55 pm
Take a look at the pictures Iíve attached. You can add extra steels on the outside to get the stack within range where it works.
RockAZ likes this.
jsedacca is offline
post #7 of 16 (permalink) Old May 19th, 2019, 1:05 pm Thread Starter
wetzel's Avatar
That's interesting, the picture shows the first plate is a friction? But everything else I've seen suggests using a metal first. This basket also has a metal that screws into the basket itself, which I removed because I'm not sure what it's there for... maybe that acts as the first metal and so the first plate going in is a friction? but that metal is, again, screwed into the basket, so it works differently.
wetzel is offline
post #8 of 16 (permalink) Old May 19th, 2019, 1:08 pm Thread Starter
wetzel's Avatar
I also don't have any of those convex plates in either the pack from the clutch that was in the bike or the pack in the slipper I replaced it with.
wetzel is offline
post #9 of 16 (permalink) Old May 19th, 2019, 1:14 pm
If itís a true slipper clutch, the first plate is always a friction. Donít worry about the convex plate either. All the plate kits Iíve gotten for the slippers donít have the convex plate. Itís just a plain steel in that spot. Sounds like you need to disassemble and post some pictures to what is really in there. The metal you speak of should be on the hub, not the basket.
jsedacca is offline
post #10 of 16 (permalink) Old May 19th, 2019, 1:21 pm Thread Starter
wetzel's Avatar
If it’s a true slipper clutch, the first plate is always a friction. Don’t worry about the convex plate either. All the plate kits I’ve gotten for the slippers don’t have the convex plate. It’s just a plain steel in that spot. Sounds like you need to disassemble and post some pictures to what is really in there. The metal you speak of should be on the hub, not the basket.
Ok, give me a half hour, just went inside for lunch. I'll pull the pack back out and take pictures.
wetzel is offline
Which Will be More Collectible in 10 Yrs? rockitdoc Supersport 32 Jan 10th, 2019 4:43 pm
EVR Ducati CTS Racing Slipper Clutch Complete with 48T Sintered Plates and Basket moto Vendor Deals 0 May 12th, 2016 12:06 pm
