996 vibrations on handlebars - Ducati.ms - The Ultimate Ducati Forum
post #1 of 11 (permalink) Old Apr 12th, 2019, 4:22 pm Thread Starter
petarr's Avatar
I noticed some vibrations on speed 60+ (100kmh+), like handlebars going front-back. its maybe few milimeters of move, but still I can feel it. front wheen/tyre is balanced.
is that normal thing on 996? or something to worry?
petarr is offline
post #2 of 11 (permalink) Old Apr 12th, 2019, 4:27 pm
Iwannaduc's Avatar
For sure not normal. Steering head bearings maybe....or maybe not proper torque on the top nut...sean
My garage: Twins:2000.5 Mille R, 2000 996, 1994 EX500 basket case 1993 900SS. Suzukis: 2004 GSXR600, 1992 GSXR750 oil boiler, 1983 XN-85 Turbo
Iwannaduc is offline
post #3 of 11 (permalink) Old Apr 12th, 2019, 5:00 pm
ducvet's Avatar
Not normal, check front wheel bearings as well.
ducvet is offline
post #4 of 11 (permalink) Old Apr 13th, 2019, 1:46 am Thread Starter
petarr's Avatar
checked both. no noise no play.
maybe I described it wrong. there are no play in handlebars, just one handlebar going front while other going back. like you steering left and right very fast. and its very subtle movement but can be noticed.
still not normal ? thanks
petarr is offline
post #5 of 11 (permalink) Old Apr 13th, 2019, 2:05 am
Disconnect the steering damper and take it for a ride.
ducvet likes this.
xracer is offline
post #6 of 11 (permalink) Old Apr 13th, 2019, 3:31 am
gamingthemarket's Avatar
Carefully check your tires. Cupping is hard to see but can cause vibration. How old is the fork oil? Was the suspension set to your weight? Were the forks pinched when the front tire was mounted? All prime suspects for wobble and easy to miss.
Tire wear caused this wobble!
2016 Hypermotard 939SP
gamingthemarket is offline
post #7 of 11 (permalink) Old Apr 13th, 2019, 10:09 am
Iwannaduc's Avatar
Definitely not normal. Are you putting alot of weight on the bars? Just trying to separate whether what you feel is induced or actual feedback.
Pinch the tank with your knees and flex your abs to hold your body weight. Keep a light touch on the bars and see if you still feel an oscillation through the bars. If not, the movement you feel is induced rather than something the front end is actually doing.
If you can definitely isolate it to the front end, tire pressure, tire wear or fork setting *might* be the cause. Don't over look the rear end though. An issue back there might be the cause.....sean
post #8 of 11 (permalink) Old Apr 13th, 2019, 10:36 am
Namor's Avatar
Make sure the forks are aligned. (prior wreck or drop)
Are the parts clamped in the forks correctly? You can check by looking on the front of the triples and make sure the locating pin is properly located in the upper triple. I can provide a picture of that does not make sense. (prior wreck or drop)
Is there enough air in the front tire?
97 916/996 "The Time Machine"
Namor is offline
post #9 of 11 (permalink) Old Apr 13th, 2019, 3:06 pm
bbradsby's Avatar
also do this: stand in front, grab front wheel tightly with your knees, grab bars with your hands, then push/pull bars back & forth and up & down. Do you feel any play in the system? If so, work to isolate where its coming from.
-bucky
2011 1198 - 2001 996 mono - 2002 ST4s ti - 2003 R1150RT
bbradsby is offline
post #10 of 11 (permalink) Old Apr 15th, 2019, 4:02 am Thread Starter
petarr's Avatar
thanks all on replies.
now going to check all things mentioned.
just one thing.. some pin in tripples. where is that pin?
bike never crashed but I had drop from sidestand.
petarr is offline
996 front rim and rotors on a 1098 Show a forks installed on my 996 track bike gary856 Superbikes 12 Feb 7th, 2019 4:28 pm
Parting out my 996 gary856 Parts and Accessories 4 Jul 16th, 2018 1:04 pm
FS: Fairings for 900SS, 996R, 996, and 851/888 nine16 Parts and Accessories 2 May 8th, 2018 1:56 pm
996 OEM exhaust parts problems Sitting Duc Superbikes 5 Mar 13th, 2018 5:18 pm
FS: ECU's, Eproms & Power Commanders - 996 748 916 998 749 999 GT1000 tom.i Parts and Accessories 9 Oct 9th, 2016 11:35 am
