1098 Yoyodyne Slipper whine on takeoff - Ducati.ms - The Ultimate Ducati Forum
  • 1 Post By skywurz
post #1 of 3 (permalink) Old Apr 10th, 2019, 1:14 pm Thread Starter
skywurz's Avatar
Hi All
I know I know another slipper clutch post. I have read many of them but wanted some input on mine . So i just installed this Yoyodyne on my 1098 i did as much research as i could before hand. It seems to be working well except on takeoff i get this whine that was not there before
. Im guessing it could be some glazing or something but am not sure. I kinda guessed at stack height when i was doing everything. I put a friction disk in first then stacked them steel friction steel and ended with a steel on the pressure plate with a stack of 37.5 (it was 38.5mm when i pulled it out before the upgrade)
Skywurz
skywurz is offline
post #2 of 3 (permalink) Old Apr 10th, 2019, 1:34 pm
Higgs's Avatar
Mine has started to do this occasionally as well, though not to this degree, so am curious what you find out. My assumption has been that it’s in need of adjustment. Sorry I’m no help.
--Chris
'07 1098 / '06 Sport 1000 mono / '10 Hyper 1100
Higgs is offline
post #3 of 3 (permalink) Old Apr 17th, 2019, 10:58 am Thread Starter
skywurz's Avatar
All Fixed!
Im not sure what fixed it as i did all of the things at once hoping it would solve the issue.
I did the Lithium Grease Trick
I sanded the steel plates with 220 grit sand paper.
I replaced the throw out bearing.
I made sure all of the plates were the same direction.
I made sure the stack was a good height
I made sure the springs were not binding on the pressure plate.
paulmm600 likes this.
Skywurz
skywurz is offline
749 Bucci/DP slipper clutch slipping on takeoff? Alabamarama Superbikes 8 Aug 29th, 2018 9:17 pm
1098 slipper clutch acting funky redp0rsche Superbikes 6 Feb 16th, 2018 3:28 pm
Yoyodyne 848 slipper clutch superhawk Parts and Accessories 1 Jun 5th, 2016 7:50 pm
FS: TSS / Yoyodyne 48 tooth slipper clutch tom.i Parts and Accessories 1 May 17th, 2016 7:58 am
FS: Corse Slipper Clutch 848, 1098, 1198 New $500.00 VikingThor Parts and Accessories 2 Jan 7th, 2016 9:39 pm
