749 - Issue downshifting into Neutral & 1st - Ducati.ms - The Ultimate Ducati Forum
LinkBack Thread Tools
Old Apr 8th, 2019, 7:29 am Thread Starter
Vin_'s Avatar
2005 749
Occasionally I will have an issue downshifting from 2nd gear. When I am approaching a stop and go to downshift I canít get into neutral or 1st unless I shift back up to 3rd and then down again.
Has anyone experienced this issue? I set the the gear selector properly using the Ducati tool, bled the clutch, measured the clutch plates and the clutch springs are torqued properly.
I donít have any issues downshifting from other gears. This is happening about 1/10 times I try to downshift into N or 1st
Vin_ is offline
Old Apr 8th, 2019, 9:02 am
Old rider's Avatar
Originally Posted by Vin_ View Post
2005 749
Occasionally I will have an issue downshifting from 2nd gear. When I am approaching a stop and go to downshift I can’t get into neutral or 1st unless I shift back up to 3rd and then down again.
I don’t have any issues downshifting from other gears. This is happening about 1/10 times I try to downshift into N or 1st
How did you bleed the clutch - did you discover the ingenious bleed valve inside the reservoir??
Does it go into gear with a clonk when you select first from neutral when stopped.
Have you replaced the plates recently??
Old rider is offline
Old Apr 8th, 2019, 9:25 am Thread Starter
Vin_'s Avatar
I wasnít aware of a valve inside the reservoir. And yes thereís a clonk into 1st from N. I have not replaced the plates
Vin_ is offline
Old Apr 8th, 2019, 7:58 pm Thread Starter
Vin_'s Avatar
I bled the clutch from the screw in the reservoir and from the slave today. Still having the same issue
Vin_ is offline
Old Apr 8th, 2019, 10:07 pm
sounds like the adjustment is off to me. what if you just lift the gearlever a touch, instead of going all the way into third? can you feel the hooks dropping over the pins if you shift it by hand with the engine off on a rear stand?
know all wanker
belter is online now
Old Apr 8th, 2019, 10:29 pm Thread Starter
Vin_'s Avatar
I tried a handful of times. I canít feel the hook dropping over the pin. Just goes into 3rd
Vin_ is offline
Old Apr 9th, 2019, 4:11 am
Old rider's Avatar
Judging by the clonk, it does sound as though clutch drag is an issue. However, if you have bled the system thoroughly and don't have new plates binding in the basket slots, then why??
How much play are you getting at the lever?? You only need to have a little play - 1-2mm, enough to ensure you are getting the full pressure of the springs holding the plates together. If you have more than that, you will not be getting full movement of the pressure plate.
Old Apr 9th, 2019, 6:01 pm Thread Starter
Vin_'s Avatar
I donít really have any play at the lever. As soon as I move the lever I can see the pressure plate move
Vin_ is offline
Old Apr 9th, 2019, 6:05 pm Thread Starter
Vin_'s Avatar
I aligned the gear selector with the 88713-3334 tool which replaced the 88713-1091 (the tool shown in the 749 service manual)
Does anyone know if these are different?
Vin_ is offline
Old Apr 10th, 2019, 8:14 am
BobbyBoy's Avatar
Images: 3
I had the same problem and it was stack hight.
This may be useful to you.
Clutch Tuning - Ducati Up North
Good luck.
Vin_ likes this.
'06 999s
'03 SS 1000 (Sold)
BobbyBoy is offline
Neutral Light Switch Fault - Hypermotard 1100 Evo SP notoriousrab430 HyperMotard 4 Dec 14th, 2018 7:28 pm
Neutral Switch - No Light Issue CinKo Superbikes 5 Jul 5th, 2018 7:24 am
2012 1199 Panigale - Engine! alert, loss of power in 1st gear ndefreitas Tech Forum 7 Sep 5th, 2016 9:11 am
Debugging an issue with starting a Ducati 749 benjamin.d Superbikes 2 Feb 25th, 2016 12:05 pm
