we had a 998 years ago that one particular replacement chain rubbed on the inside of the frame above the swingarm pivot. i think something else got fitted and it was ok.
thank you ! I appreciate your answer. I have 1mm clerance. so it can be because thicker chain and front sprocket retainer worn/rear quick charge sprocket left-right play (~1mm).
Ok, I think I will go to vx chain, instead fat zvmx.
btw 15-43 bike is sooo much nicer to drive in city.
and chain still slightly rubbing the frame (not swingarm).
Can someone please measure chain width (standard chain), at widest point (pin/link), not rivet link,as rivet link seems a bit narrower than other pins.
It sounds like the rear sprocket assembly is out of line. As if it is stacked too thick and so moves the carrier out too far. Can you provide have a close up of thread count at the carrier nut and an additional picture of the back side of the carrier to show the space between the carrier and the swing arm?
miolta, how can I install it correctly ? I just put it on shaft and install retainer and two bolts.
edit: just tried both position for standard and JT sprockets. It was allredy in good position.
It seems 23mm chain is too thick.
Related Threads
2.5M posts
93.7K members
Since 2005
