So I picked up a $500 996!!! - Page 5 - Ducati.ms - The Ultimate Ducati Forum
post #41 of 54 (permalink) Old Jul 14th, 2018, 7:06 am
Originally Posted by ctbrace View Post
That’s exactly what I was thinking.
What I’m thinking here is I need an ignition relay (NAPA ar274?), the positive cable from starter relay to the battery and put a connector on the 2 red wires and connect those to a new battery. Correct me if I’m wrong please.
This battery box with this arm on the side looks different from all the rest that I’ve seen. No idea what goes on that bracket to the far right.
Thanks guys,
Todd
I've got the same arm on my. 2000 996 and I also have no idea what it's for.
ctbrace likes this.
Cal996 is offline
post #42 of 54 (permalink) Old Jul 14th, 2018, 7:08 am
Oh and you can get a new ignition/key on ebay for about $30.
ctbrace likes this.
Cal996 is offline
post #43 of 54 (permalink) Old Jul 14th, 2018, 10:54 pm
lastblast's Avatar
I live in Redding, ca, same city as the OP. I am guessing it sold so cheap because the nearest Ducati dealer is almost 3 hours away.
Most people in this town are not really familiar with Ducati or pretty much any motorcycles, its a back ass backwards meth head homeless haven.
I feel like I had seen that bike around town a few years ago. Did the Seller say how he wrecked it? Was he the one that wrecked it or did he buy it thinking he could fix it.
Not many Ducati's in this town so you rarely see them.
All I can say is it looks like you have a quite a handful of work ahead of you. If your patient you probably can find deals on parts you need.
2004 999s likes this.
999R Xerox........996 Bi........2006 DRZ 400SM........1971 Honda CB350......... 1970 Kawasaki A7 Avenger 350 SS Street Scrambler
lastblast is offline
post #44 of 54 (permalink) Old Jul 15th, 2018, 5:44 am
gary856's Avatar
Thatís exactly what I was thinking.
What Iím thinking here is I need an ignition relay (NAPA ar274?), the positive cable from starter relay to the battery and put a connector on the 2 red wires and connect those to a new battery. Correct me if Iím wrong please.
This battery box with this arm on the side looks different from all the rest that Iíve seen. No idea what goes on that bracket to the far right.
Thanks guys,
Todd
if you make a list of what you need i have a lot stock parts sitting around for it
ctbrace, paulmm600 and Mojo66 like this.
You can never have too many motorcycles, no matter what the wife says!!!!
2002 998 custom, 1999 996 track bike, Future 999, 998 hybrid project!
gary856 is offline
post #45 of 54 (permalink) Old Jul 15th, 2018, 2:43 pm
paulmm600's Avatar
Or one of these ignition bypass switches.
https://motowheels.com/i-7774716-cor...ss-switch.html
cheers
paul
916 biposto 96' current
https://www.ducati.ms/forums/56-super...ct-so-far.html
M600 00'
Mille S2 84'
paulmm600 is offline
post #46 of 54 (permalink) Old Jul 18th, 2018, 5:56 pm Thread Starter
Lol Lastblast, hey that’s my hometown you’re talking about!
yeah up here most people have no idea what to do with a Ducati.
I bought it from the guy who wrecked. Said it’s been sitting a couple years. Said him and buddy out riding, he came around a turn and buddy had stopped in middle of the road.
I’m looking at this thing and thinking it ain’t all that bad. I don’t have a single side bike lift so i rolled it outside, put in a higher gear and pushed it (gently), motor doesn’t seem locked up, compression out both cylinders.
Gary856, thank you. I’ll do that
Hey everyone, sorry been off for awhile. A little wildfire up here and hot and smoky as hell also.
So I pulled the clutch apart. Aside from the 2 broken studs on the hub looked ok. The push rod was kinda a pain but came out. I’ll replace the 2 o-rings since it’s out and the one from the clutch hub wasnt in there. Do I have to order the ducati part number or can I find a generic in town? And what are the spec’s (size) that I’d be looking for?
Thanks everyone!
ctbrace is offline
post #47 of 54 (permalink) Old Sep 3rd, 2018, 5:58 am
Supermoderator - Iīm special!
amullo's Avatar
Images: 313
Looks like a doable Project. Ignition replacemnet is easy. Pull the tank and the airbox together with the injectors (gotta be done anyway) and its just two 8mm bolts (As I recall) and a Quick connector. No biggie. All pre-2003 ignitions will fit, even those off a Monster or an SS. Then just go with a no-key tankcap and your good.
The headlight.. I dont know.. I might actually get a race-style upper fairing and just cut the hole for the lowbeam.. Skip the highbeam alltogether..
My old crash wasnt worse then this and that was fixed in 2 long weekends. That even cracked the rear alu subframe.
Turned out great. Aftermarket screen and fairings from Ebay.
Dukerdr likes this.
2010 Multistrada 1200s - engine mapped by tomtom, ÷hlins mechatronics SCU and alot of mods to make up for poor skills
amullo is offline
post #48 of 54 (permalink) Old Sep 3rd, 2018, 6:26 am
Tightly Clenched...
Satansfist's Avatar
Originally Posted by amullo View Post
...The headlight.. I dont know.. I might actually get a race-style upper fairing and just cut the hole for the lowbeam.. Skip the highbeam alltogether...
I was thinking the exact same thing, give it the ole 8 hour endurance squint look.
Satansfist is offline
post #49 of 54 (permalink) Old Sep 3rd, 2018, 10:08 am
Looks like a great project!
eBay has some full lockets for under $50, or I am sure there is someone here who is selling one!
Will be interesting to see if it turns over when you have a switch on it.
minitwin51 is offline
post #50 of 54 (permalink) Old Nov 5th, 2018, 3:11 pm Thread Starter
Hey, sorry been awhile. How difficult should it be to get the pushrod (clutch) out and back in. And it ate an o-ring when I pulled it back out
Thanks
Todd
ctbrace is offline
996 front rim and rotors on a 1098 Show a forks installed on my 996 track bike gary856 Superbikes 20 Aug 23rd, 2019 9:56 am
Parting out my 996 gary856 Parts and Accessories 4 Jul 16th, 2018 1:04 pm
FS: Fairings for 900SS, 996R, 996, and 851/888 nine16 Parts and Accessories 2 May 8th, 2018 1:56 pm
996 OEM exhaust parts problems Sitting Duc Superbikes 5 Mar 13th, 2018 5:18 pm
FS: ECU's, Eproms & Power Commanders - 996 748 916 998 749 999 GT1000 tom.i Parts and Accessories 9 Oct 9th, 2016 11:35 am
