1098 slipper clutch acting funky - Ducati.ms - The Ultimate Ducati Forum
post #1 of 7 (permalink) Old Jan 30th, 2018, 6:45 pm Thread Starter
So my 1098 has a temperamental clutch and im not sure if it's me or the bike. When taking off from a stop, if I give too much gas then the clutch makes an ear shredding metallic rubbing sound and the bike lurches forward. And when I say too much, it's not that much gas at all. Any kind of aggressive start makes it the sound.
Do i simply need a new clutch or is something else going on?
'02 748 (gone baby gone)
"I think it's Italian..."
redp0rsche is offline
post #2 of 7 (permalink) Old Jan 30th, 2018, 6:54 pm
RobH is offline
post #3 of 7 (permalink) Old Jan 30th, 2018, 8:08 pm
if it has a dp slipper then they tend to like 4 of the spring plates to make them work nicely off the line. not sure why.
pull it out, beadblast the steel plates to remove the shine and give the frictions a light blast.
Brad The Bike Boy
www.bikeboy.org
bradblack is offline
post #4 of 7 (permalink) Old Jan 31st, 2018, 6:51 am
Tobytyke's Avatar
I had a similar experience a while back, turned out it was the spider spring broken into 3 pieces, at a glance you wouldn't notice it as it's held in place with the recessed washer/nut, worth checking
1995 748 Evo - 2001 748 Dimples - 2003 998 Schizo
Tobytyke is offline
post #5 of 7 (permalink) Old Jan 31st, 2018, 1:45 pm
Dennie's Avatar
Sounds normal! I experience the same sound with my Corse slipper. From time to time, I apply a new coating of white lithium grease which makes the metallic rubbing sound less.
Dennie is offline
post #6 of 7 (permalink) Old Feb 16th, 2018, 8:54 am
Does it make the sound go away or just less? I picked up a 1098 with a Corse slipper and did the white lithium trick. Improved the noise by maybe 30% and grabby-ness by 50%. Wondering if that's all I should expect.
9 Bikes, 1 Duck
pittmeister is offline
post #7 of 7 (permalink) Old Feb 16th, 2018, 3:28 pm
Dennie's Avatar
The sound stays.... I think it comes from rubbing between the pressure plate and last (i.e. top) steel plate in the clutch pack (the Corse slipper ends with a steel plate and not a friction one). You might try a convex steel plate as last one.
Dennie is offline
EVR Ducati 48T Conversion Plates & Clutch Basket Sets moto Vendor Deals 0 Apr 19th, 2017 11:06 pm
EVR Ducati CTS Racing Slipper Clutch Complete with 48T Sintered Plates and Basket moto Vendor Deals 0 May 12th, 2016 12:06 pm
