996 front rim and rotors on a 1098 Show a forks installed on my 996 track bike - Ducati.ms - The Ultimate Ducati Forum
post #1 of 21 (permalink) Old Dec 26th, 2017, 5:11 pm Thread Starter
gary856's Avatar
Has any one tried this? Got a set of 1098/1198 forks and put them on my 996 track bike. Machined a custom axle and spacer to fit my 996 oz rim with brake tech rotors (don't want to buy new ones). Used the men shims that came with their rim to increase the offset to 14mm instead on 10 from the 996 standard to match up to the 15mm offset needed. Figured I can leave out the rim spacers for the radial calipers to reduce the realm rotor size to 320mm of my current rotors. Couldn't find any posts about this, so has any one tried it?
You can never have too many motorcycles, no matter what the wife says!!!!
2002 998 custom, 1999 996 track bike, Future 999, 998 hybrid project!
gary856 is offline
post #2 of 21 (permalink) Old Dec 26th, 2017, 5:43 pm
Come in Spinner :)
davy.j's Avatar
Images: 146
Don't see why not... so long as it's sound from an engineering standpoint you can do anything...
I just made up a pair of Yamaha forks with a 748 front wheel and discs with custom caliper brackets and 800 Monster calipers to go in a CB750 frame with a DR650 motor.
2000 853
2007 Cagiva Mito.
1980 and 1978 Ultra lightweight Yamaha SR500 Cafe Racers
1967 500cc Ultra lightweight Triumph Daytona Cafe Racer
davy.j is offline
post #3 of 21 (permalink) Old Dec 27th, 2017, 1:33 am
Needs bigger disks. You’ll stop quicker.
xracer is online now
post #4 of 21 (permalink) Old Dec 27th, 2017, 2:54 am
Come in Spinner :)
davy.j's Avatar
Images: 146
Yes! I might have to go back to 18" wheels like on the SR so I can fit them in
Midengine-man likes this.
2000 853
2007 Cagiva Mito.
davy.j is offline
post #5 of 21 (permalink) Old Dec 27th, 2017, 3:20 am
Does those extra brake caliper brackets not introduce additional flex?
900SSie 2002 - Senna
SalkinSalkin is offline
post #6 of 21 (permalink) Old Dec 27th, 2017, 4:30 am
Come in Spinner :)
davy.j's Avatar
Images: 146
No, no different to the stock cast in brackets on a 748/916
2000 853
2007 Cagiva Mito.
davy.j is offline
post #7 of 21 (permalink) Old Dec 27th, 2017, 5:27 am
DukeDesmo's Avatar
Images: 197
I have 1198S Ohlins forks in my 916, using a Marchesini wheel designed for 916/996 with the 6-bolt discs .
Needed a 30mm spacer to fill the void by the (no longer used) speedo drive and I have 15mm offset, 320mm brake discs which I prefer to using 5mm spacers but it fits and works fine with no other mods.
916, M900 & Guzzi LeMans II
DukeDesmo is offline
post #8 of 21 (permalink) Old Dec 27th, 2017, 7:13 am
Gersa's Avatar
Using Øhlins forks from a 1198 and radial calipers with 320mm standard snowflake discs and 5mm spacer on each side. Using Dymag carbon rim with 6-bolt for brake discs. Also using speedo-drive
Have made a couple of adapters so I can use the orignal front axle from the 996. Think I used a wheel nut from the 1198.
Everything is possible
ID:	881545   Click image for larger version
jules_1972 likes this.
Gersa is offline
post #9 of 21 (permalink) Old Dec 27th, 2017, 10:55 am
Tobytyke's Avatar
Yep anything's possible - GSXR spec Ohlins FGRT's, custom yokes + spacers, Suzuki axle, Ducati spec Marchesinis & PFM rotors
jules_1972, ProphetPVD and Doddste like this.
1995 748 Evo - 2001 748 Dimples - 2003 998 Schizo
Tobytyke is offline
post #10 of 21 (permalink) Old Dec 27th, 2017, 3:52 pm
trussdude's Avatar
848 Ohlins forks with 996 magnesium wheel on a 996
trussdude is offline
