848 / 1098 cat & slip-on question. - Ducati.ms - The Ultimate Ducati Forum
  • 1 Post By jwm2k3
  • 1 Post By bradblack
post #1 of 7 (permalink) Old Jun 9th, 2017, 12:25 pm Thread Starter
Jpeg's Avatar
Hi there. I recently got this 848 in a trade. I really like the bike, and it's allot of fun. It came with a Zard slip-on. my questions are:
Will the Zard slip-on have eliminated the cat?
Will there be any gains worth it, other than looks, buying Zard headers for it.
It's running really rough in the low revs. The previous owner claims, he left the stock ECU, but apart from the slip-on also changed to a performance air filter. Whats the way to go, power commander and a dyno run, or a simple ECU update?
Jpeg is offline
post #2 of 7 (permalink) Old Jun 9th, 2017, 1:51 pm
Nice bike. Good luck with it
Pulshion is offline
post #3 of 7 (permalink) Old Jun 9th, 2017, 10:45 pm
jwm2k3's Avatar
The 848 is very chug chug down below 4k RPM's. Its normal. You'll get used to it. Now, just adding Zard slip ons is not ideal. I would find a DP ecu and install that at least. If you dont change anything, it will be ok but it could be a bit better. Adding Zard headers would be cool, but I doubt it would add a ton of power.
The 'cats' are actually inside the stock exhaust canisters, so they have been removed.
Good luck, Ive had three 848's. I love them!
Johnny
jwm2k3 is offline
post #4 of 7 (permalink) Old Jun 10th, 2017, 5:04 am Thread Starter
Jpeg's Avatar
Thanks for a great answer Is it possible just to get the ECU updated at a ducati dealer to fit the purpose?
Anyone tried to polish up the original headers for a nicer result?
One of the mods I did was putting in a 190/55/17 tire, and a 14t front sprocket. Handles really well now.
Jpeg is offline
post #5 of 7 (permalink) Old Jun 12th, 2017, 4:07 pm
jwm2k3's Avatar
There are people who can 'flash' your ecu. Im betting the dealer is NOT one who can. Otherwise, you can purchase a pre-owned DP (Ducati Performance) ecu and have that installed.
The headers and pipes do look nice when polished.
Ive found the 848 handels better with the 180....and they are cheaper too! Not a tremendous difference going to the 190, the bike just seems to turn a smidge slower.
forsythem likes this.
Johnny
jwm2k3 is offline
post #6 of 7 (permalink) Old Jun 12th, 2017, 9:41 pm
forsythem's Avatar
I was going to chime in as well on that one...
I was surprised you said it handles well after going to a 190... but could that just be because your old 180 section was worn, with a flat spot?
I would personally stick with a 180, for better turn-in, but that would be personal preference.
I remember once going up from a 170 to a 180 on the rear of a tube-frame Buell, and it was noticeably harder to turn, and far less enjoyable to ride.
_____________
Black 2010 848 Superbike.
forsythem is online now
post #7 of 7 (permalink) Old Jun 14th, 2017, 12:54 am
the 848 should run nice under 4,000 rpm if tuned right. the std ecu as well as the dp ecu will be closed loop. get the ecu flashed with good mapping that is open loop, do a tps reset and set the idle mixture.
the std header design gives a mid range hole. zard used to do a 996 style header set, with two pipes up to the mufflers. that will help the midrange, not top end.
Brad The Bike Boy
www.bikeboy.org
bradblack is offline
FS: 848 1098 1198 Parts BMiller Parts and Accessories 8 Jun 5th, 2017 10:15 am
FS: Carbonworld Ducati 1198 1098 848 Carbon Fiber Tank Guard pcguru2k Parts and Accessories 1 May 10th, 2016 9:09 am
FS: Sato Racing Adjustable Brake Pedal Kit for Ducati 848 1098 1198 (D-1098BPD-BK) pcguru2k Parts and Accessories 0 May 8th, 2016 5:07 pm
SF 1098 owners with SF 848 tanks, question... stealthblack StreetFighter 1 May 4th, 2016 2:57 pm
