Belly pan - Ducati.ms - The Ultimate Ducati Forum
post #1 of 9 (permalink) Old Jan 28th, 2009, 2:57 pm Thread Starter
Belly pan
Hey guys quick question. I wanted to know if it is possible to mount the
996R/998R belly pan on stock 748 fairings? I have tried to search and
have come up empty. Any help would be appreciated.
Thanks
super dooper is offline
post #2 of 9 (permalink) Old Jan 28th, 2009, 3:04 pm
Banned
Images: 15
Depends on which belly pan you got. The Ducati corse pan might fit on the stock fairings. Even if it didn't, its so close, you might just have to make some small adjustments and obviously mount the brackets necessary for it to fit.
The aftermarket belly pans, are designed to work with the aftermarket fairings only, so they won't fit on the standard fairings. Most aftermarket fairings are 3 piece (nose/sides, belly pan, tail) where the Ducati corse ones are 5 piece (nose, right, left, belly pan, tail)
Obviously, there is a pro to using the corse fairing because its split up into more sections which makes it easier to replace only one section after crashing. With that being said, the aftermarket fairings are cheaper in the long run and also hold up better then the corse ones. So there is a trade-off and I highly suggest replacing all the fairings, instead of just adding onto the stock.
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
tye1138 is offline
post #3 of 9 (permalink) Old Jan 28th, 2009, 5:57 pm
Images: 30
You can cut the OEM side fairings--but it is much easier to buy the shorter sides or buy it as a kit.
CF Fairing: 996R/998R Side Panels & Belly Pan
-M
moto is offline
post #4 of 9 (permalink) Old Jan 28th, 2009, 7:17 pm
Thanks
Looking at one on Ebay?
If so then this one will only fit the 996R and 998R.
www.Shift-Tech-Carbon.com
Shift-Tech-Carbon Performance- High Quality Carbon Products!
Shift-Tech is offline
post #5 of 9 (permalink) Old Jan 28th, 2009, 11:56 pm
danny408's Avatar
here mine belly pan. i had to cut a bit off and drill couple holes to the stock fairing to fit it.
danny408 is offline
post #6 of 9 (permalink) Old Jan 29th, 2009, 6:21 am
Thanks
If your good with small modifcations, you can make it work with your stock bodywork.
Viper1 is offline
post #7 of 9 (permalink) Old Jan 29th, 2009, 9:41 am Thread Starter
Smile
Thanks for the help guys. And yes I was looking at the one on eBay.
And I do pretty well with cutting and small tools. So I would not mind
cutting and drilling my body work. Plus if I ruin it, it gives me a reason to buy
all carbon fiber body.
Thanks again
post #8 of 9 (permalink) Old Jan 29th, 2009, 9:45 am
94CobraR's Avatar
Images: 5
Sebimoto makes a nice 5 piece setup....
Jimmy
Go Gators
94CobraR is offline
post #9 of 9 (permalink) Old Apr 6th, 2009, 11:17 am
SuicideHz's Avatar
That's exactly what I want to do to my 748S. I love that pic of you on that bike and that CF belly pan. It's the sole reason I searched for and found this thread on belly pans.
Where did you get the pan? It fits over the stock fairings or you needed to cut them down?
Thanks
SuicideHz is offline
Photoshop Request- White Belly Pan on Red 1098 kabinski Superbikes 23 May 5th, 2009 8:24 am
748/996/998 Belly Pan dwnhillskater Superbikes 3 Oct 15th, 2008 8:12 am
looking for Belly Pan for classic 1000 mono? Classicrobeuro Sport Classic 11 Aug 15th, 2008 5:08 pm
Belly Pan diesel1218 Superbikes 2 May 14th, 2008 12:09 am
