999 Big Bore - Ducati.ms - The Ultimate Ducati Forum
post #1 of 3 (permalink) Old Oct 6th, 2008, 4:12 pm Thread Starter
999 Big Bore
What is the maximum the stock 999 ('03-04 base model) cylinders can be bored out to?
Current Stable-
'03 999 Slip-On Termis
'06 Ural Gear-Up Stock
The Hauler-
'90 454SS Lowered and Carbed
Past Steeds-
'07 Hayabusa Shortened & Raised
'75 Suzuki GT380 Cafe Racer
'00 Yamaha R1/R7 Hybrid
'70 Norton Commando 750 Bobber
'98 916
'05 Derbi GPR50
998Robbie is offline
post #2 of 3 (permalink) Old Oct 6th, 2008, 4:39 pm
BowHunter's Avatar
102 mm is well known to work fine - and also the only bigbore option, I think
Racing 1198R on 17" Dunlop KR's
70mm Full system - SBK airrunners
Nemesis ECU and TCS
GPX Pro datalogger
Ohlins w/30 mm cartridge
Ohlins w/ Zupin internals
30 mm Kyle triples
BowHunter is offline
post #3 of 3 (permalink) Old Oct 7th, 2008, 12:14 pm
Le Franšais's Avatar
Yes 102mm is the only option. Or you can try to install 104mm piston/cylinder from 998R with your crank, result you have a 1080cc engine
Panigale Stocksport race bike
Le Franšais is offline
748->853 big bore kit impressions boostedt0y Superbikes 18 Apr 19th, 2013 8:02 pm
What would net more gains? Cams or big bore pistons? garth Sport Classic 16 Sep 12th, 2008 3:32 pm
Big Bore kit thoughts Keyboard Superbikes 9 Apr 29th, 2008 9:51 am
800 SS Big Bore ? parrothead Supersport 9 Apr 18th, 2008 9:47 am
