1098 - clutch picking up too high - Ducati.ms - The Ultimate Ducati Forum
post #1 of 2 (permalink) Old Sep 9th, 2008, 1:53 pm Thread Starter
veteq's Avatar
Images: 9
I need some help....
I just got the open clutch cover, ducati pressure plate and new springs installed on my 1098. All seemed ok for the next 100miles but out of the blue the clutch started to pickup very high, I had to adjust the lever to all the way down to fell closer to normal (but still isn't) , it's not slipping.
I took it back to the place where I got the open clutch installed and after bleeding the clutch system, they said all should be ok, the problem remains. Is there a clutch adjustment that I can do?
any help would be greatly appreciated.
veteq is offline
post #2 of 2 (permalink) Old Sep 9th, 2008, 1:57 pm
Banned
Images: 15
I assume you mean the engagement point has moved. Its probably more related to your slave cylinder. If you didn't take it off, when you removed the push rod, you could have an issue with how the push rod is being set in the slave cylinder. First check your springs, make sure they're ok and then bleed the clutch system, I bet its ok.
100% free webcam site! | Awesome chicks and it is absolutely free! | Watch free live sex cam - easy as 1-2-3
tye1138 is offline
What's the deal of a dry clutch? azpinator Superbikes 63 Jan 29th, 2012 1:56 am
1098 Clutch Grabbing Spriss Superbikes 10 Apr 17th, 2008 6:04 am
The dreaded clutch question again Corse1 Sport Touring 23 Apr 13th, 2008 7:38 pm
1098 with a wet clutch 748girl Ducati Motorcycle Chat 7 Mar 6th, 2008 10:18 pm
New Rumor: The 1098 Tricolore comes with a slipper clutch AND traction control spalding12 Superbikes 34 Dec 11th, 2006 1:10 pm
