oil change info for 996 - Page 2 - Ducati.ms - The Ultimate Ducati Forum
post #11 of 13 (permalink) Old Aug 17th, 2006, 3:30 pm
The first time I did an oil change on my Duc I took it out. I played with it for awhile trying to figure out why Ducati put it in there. I gave up on trying to figure out why it was there.
NOW I KNOW...
I put it back in and have not had any problems with leaks. I guess I was lucky.... wait, I am never lucky.... who knows....
my996duc1 is offline
post #12 of 13 (permalink) Old Aug 17th, 2006, 3:34 pm
stan23's Avatar
Also, what size hex socket is that oil screen bolt?
stan23 is offline
post #13 of 13 (permalink) Old Aug 18th, 2006, 1:35 am
Supermoderator - I´m special!
amullo's Avatar
Images: 313
I believe the hex is a 10mm for the oilmesh. If you have a bike newer then -01 then it´s a 15mm bolt.
The small bolt UNDER the oilmesh.. well.. I´ve heard people using permanent loctite and getting a good seal with that, together with a new crush-washer.
Since you´ve put it back.. Leave it and see. If it starts sweating or dripping, then go with a crush-washer and loctite. Just make sure to clean the threads with brakecleen or some other de-greaser first.
//amullo
2010 Multistrada 1200s - engine mapped by tomtom, Öhlins mechatronics SCU and alot of mods to make up for poor skills
amullo is offline
750ss/800ss general info. jtex06 Supersport 24 Jan 19th, 2007 5:55 am
Q: SPS model info? vtwin Superbikes 5 Feb 14th, 2006 11:09 pm
Roto's XX For REAL Men Only Room - Job Change RotoRooterGuy Chit Chat 6 Feb 5th, 2006 10:05 am
999 sprocket change to 39T-Chain Options? alang Superbikes 11 Jan 27th, 2006 5:43 pm
