Measure Closer Shim w/o Tool? - Ducati.ms - The Ultimate Ducati Forum
post #1 of 16 (permalink) Old Oct 14th, 2007, 8:49 pm Thread Starter
Hello All,
I have a 999 and i'm doing my 6K service. I heard there was a trick to measure the shims by putting the opener upside down and measureing from there with a micrometer?
Its funny b/c out of all my shims, one shim actually came marked with "3.25".
Just curious if anyone has tips on measuring the closer shims w/o getting the tool.
Danny
Duc 1098S
Duc GT1000
Harley Street Glide
Husky SM450R
WR450F
m3elmo is offline
post #2 of 16 (permalink) Old Oct 15th, 2007, 12:20 am
1fast750ss's Avatar
You can measure the unloaded gap with just your measuring feeler guages, then push down on your closer rockers to measure a loaded gap. Of course measring both locations between the shim and opening rocker.
This way you get the same distance measured as if you did the closers.
Brian C.
'01 BCM 795SS / Track Toy
'03 999 w/50mm termi, S cams, BST wheels / daily commuter?
www.cittacorsa.com
1(888)763-4869
Whether it's the City or Track, it's Citta Corsa!
1fast750ss is offline
post #3 of 16 (permalink) Old Oct 15th, 2007, 1:37 am
Site Sponsor
ducatimike's Avatar
Sounds like you are using the opening shim as a tool to measure the closer shim? That won't work as you the OD of the opener will not go down past the taper in the closer shim. You need to get all the way down to the counterbore with the radius on it. The size of the closer shim is measured from that counter bore down inside to the bottom of the shim. Only the closer measurement tool, or something like it will get you the proper measurement.
Mike
ducatimike is offline
post #4 of 16 (permalink) Old Oct 15th, 2007, 12:12 pm
JEC
JEC's Avatar
If you happened across a micrometer that had the exact diameter as the inside of the shim, perhaps. Otherwise just buy the 10-15$ tool and take away the guess work.
Editor, Odd-Bike.com
http://www.odd-bike.com/
'97 916
'06 Aprilia Tuono 1000 R
'84 Honda VF750F Interceptor (gone)
'04 Suzuki SV650 (gone)
'87 Honda VFR400R NC24 (gone)
'85 BMW K100RS (gone)
JEC is offline
post #5 of 16 (permalink) Old Oct 15th, 2007, 12:15 pm
galaxy's Avatar
Images: 27
OK, I'm confuese becasue you keep jumping around in your post about opener and closer?? The title of your post says closer shim and then you start off asking about the opener?? Or am I missing something
You don't need any special tools to measure a closer (per the title of this thread) other than a micrometer or other favorite measuring device. The opener requires a tool like Mike mentioned.
www.ducati-owners-group.com
galaxy is offline
post #6 of 16 (permalink) Old Oct 15th, 2007, 1:55 pm
DesmoBob's Avatar
Galaxy I think he's talking about using the opener shim as a substitute for using the closer measuring tool. The opener doesn't require a tool, the closer does.
Danny - like Mike said, it won't work. Get the measuring tool, it's only $11.50 at emsduc.com, great company to deal with, and I think they're also a forum sponsor.
DesmoBob is offline
post #7 of 16 (permalink) Old Oct 15th, 2007, 2:07 pm
galaxy's Avatar
Images: 27
The small round one..the one that slides down over the top of the valve stem, that's the opener. No? The one that looks like a top hat, that's the closer. The opener is the one that requires an additional tool to measure. The tool fits down in the shim in place of the vavle stem. Am I not correct on this?? I've never used an additional tool to measure a closer.
galaxy is offline
post #8 of 16 (permalink) Old Oct 15th, 2007, 2:38 pm
I think you have that backwards...but it's hard to verify without pictures. In the pic I've attached, the green dots are the openers and the red dots are the closers.
2004 ST3
Superchkn is offline
post #9 of 16 (permalink) Old Oct 15th, 2007, 3:01 pm
galaxy's Avatar
Images: 27
No, I don't have it backwards...you just showed a picture of exactly what I described. The green dot is the opener, agreed, and fits my description. This is the one that requires a tool to perform measurements of the opener shim when searching for the correct size. The tool is a little thing that fits inside the shim where the top of the valve stem would normally reside.
I see where my description could have been misleading though..they both in fact slide down over the valve stem, but the opener rest on the very top. My bad.
Great picture though!!
galaxy is offline
post #10 of 16 (permalink) Old Oct 15th, 2007, 3:31 pm
Like I said, hard to say without a picture. I was confused by the "slides down over the valve stem" part. I would read the "one that looks like a top hat" part and think yeah, that's right, but then I'd go back to the other sentence and think, well maybe he has it wrong. I'm still unsure though, how do you measure the closer without the tool as it slips over the valve stem and it has the recess in it for the opener (which is just a flat shim)?
2004 ST3
4V Desmo Adjustment JEC Hall of Wisdom 55 Apr 27th, 2015 12:25 pm
Shim Understanding-NOT! ChasCrewChief Superbikes 16 Oct 28th, 2007 8:15 pm
Chain Tool Tip galaxy Ducati Motorcycle Chat 16 Mar 19th, 2007 7:52 am
Measuring Closer Shim Trick Gforce Superbikes 1 Feb 8th, 2006 8:07 pm
