rocker pin removal tool - Ducati.ms - The Ultimate Ducati Forum
post #1 of 10 (permalink) Old Dec 8th, 2010, 8:13 pm Thread Starter
what do you guys use to pull the rocker pins out of a desmoquatro head?? my local dealer says they cant sell me the ducati "tool"
ScrewDriver is offline
post #2 of 10 (permalink) Old Dec 8th, 2010, 8:25 pm
t_bare's Avatar
Images: 4
do a search in the ST forum, I read about using a long screw, a wingnut, and a socket to fit over the pin then the wingnut screws down on the fender washer and pulls the rocker pin. I can't recall the screw size, it screws into the rocker pin. It worked great even though I can't describe it worth a darn...
t_bare
1 Ducati = Ducatista
2 Ducatis = Mechanic
2013 Multistrada GT Touring Grey
2008 Ducati Hypermotard 1100s
2002 Ducati 998 Faster Banana!!!
2000 KTM 300 EXC
t_bare is offline
post #3 of 10 (permalink) Old Dec 8th, 2010, 9:43 pm
Italkart21's Avatar
Images: 37
Italkart21 is offline
post #4 of 10 (permalink) Old Dec 8th, 2010, 9:43 pm
Homemade mini slide hammer with proper size screw end(can't remeber size)
or a deep socket big enough to go over the shaft with a washer on end and long screw (same size as above) then just screwing in pulls out.
2000 748/853.
853MACHINE is offline
post #5 of 10 (permalink) Old Dec 8th, 2010, 10:07 pm
C-simian's Avatar
Not much on homemade tools, since it's all I can do to bust time out to do the work. Mike at EMS makes a very nice dedicated slap hammer. I've used it and can attest to it's efficiency: Ducati 2 Valve and 4 Valve Adjustment Shim Kits
Scroll down about twenty items to the "Rocker Arm Spindle Puller/Slap Hammer " LT Snyder also caries them at DesmoTimes.com. Mike's rocker depressor is another excellent tool for the job, and I can't imagine doing my desmoquatro valves without the full set of shims he has produced.
Ron
2005 999s Hephaistos polumetis
2003 ST4s ABS Senna Petrarca peregrinus ubique
C-simian is offline
post #6 of 10 (permalink) Old Dec 9th, 2010, 3:18 am
Mayor of Simpleton
nine16's Avatar
Images: 2
You can use either "homemade" method described, the special tool from EMS (DESMOTIMES may have them.too), or the best is to get an regular slide hammer that yo can use for other things and the M5 or M6 screw for the rocker pin.
'01 996R, 851 Adamo/Leoni racebike, '97 900 SS CR, '91 ZX-7R K1 homologation, '89 NSR250 MC18r5k, '01 Derbi GPR50/75,
nine16 is online now
post #7 of 10 (permalink) Old Dec 9th, 2010, 6:45 am
DukeDesmo's Avatar
Images: 197
I've got the EMS tool, works great and reasonable price.
916, M900 & Guzzi LeMans II
DukeDesmo is offline
post #8 of 10 (permalink) Old Dec 9th, 2010, 7:04 am
t_bare's Avatar
Images: 4
https://www.ducati.ms/forums/40-sport...djustment.html
Have a look.
t_bare
2000 KTM 300 EXC
t_bare is offline
post #9 of 10 (permalink) Old Dec 9th, 2010, 11:34 am Thread Starter
thanks alot for the ideas! this gives me what i needed.
post #10 of 10 (permalink) Old Dec 9th, 2010, 12:14 pm
Mr Leakered
tonered's Avatar
Images: 25
+3 I have all those and it makes the whole process go smoothly.
Have a good one.
tony b
2001 ST4 - Thumper
2013 Ural GearUp (sold)
tonered is offline
Tool Kit Removal 93Octane HyperMotard 29 Nov 8th, 2011 4:33 pm
closing rocker removal tool anatak Supersport 9 Jun 12th, 2010 7:23 pm
Product Showcase, Rocker Depressor Tool ducatimike EMS 0 Mar 18th, 2009 1:29 pm
closing rocker spring removal (benefits?) LeoLegend Supersport 0 Apr 20th, 2007 2:10 am
